Question about Sony KP-61S65 61" Rear Projection Television
How can I remove the screen to gain access to the guns and mirrors of my Sony KP-61S65 for cleaning?
All i do is unscrew the back 3 boards then pull the mirror out then there is plenty of room to work
Posted on Jan 11, 2012
How do I clean Sony KP-61XBR300
The mirror rarely needs it---access for it requires removal of entire screen unit------the lens (3) can easily be reached from rear with the back removed---you also at that time can look up to see if mirror is dirty or smudged.
Mar 25, 2012 | Sony KP-61XBR300 61" Rear Projection...
Screen has bright circle in center and dark around edges and corners
You may want to remove back cover and wipe/clean the three large black lens.
Also go to an unused video input and examine screen; Same problem?
Let me know what you find.
Steve
Feb 29, 2012 | Sony KP-61S65 61" Rear Projection...
We need to clean our Sony KP-53N77. We have some spider webs inside the protective screen and our color is a little fuzzy. We have never had the mirrors cleaned. How do we access the areas to clean and...
Remove the back hardboard cover by removing all the screws and lifting the cover up and toward you.
Mirror will be above but usually doesnt get dusty. Try not to touch it if you can. Same with back of screen. If you have a spider web just use a soft dry cloth to wipe it away.
You will likely find the upward facing lamp lenses covered in dust. Clean these with a soft cloth moistened with glasses cleaning solution. Glass cleaner works too.
Mar 20, 2011 | Sony KP-53N77 TV
How do i clean mirror on a sony KP-57ws520
Fairly easy to do.
Follow these steps:
1) Unplug the TV
2) Remove the lower access panel (the pressboard with all the holes in it) by removing the screws holding it in place. (This is the panel where where your connections are made)
3) Remove all the screws on the big black shroud on the back that actually holds to mirror. There are probably about 15 screws.
4) gently lift the panel off and set in on the floor or table where you can clean the mirror. (remember the mirror is attached to the back side of it) I usually put in on the floor.
5) clean the mirror with glass cleaner or non-streaking solution.
Reverse the steps above to re-assemble.
Feb 18, 2011 | Sony KP-57WS500 57" Rear Projection...
We have two of these projection TVs. One of them
clean the mirror,lens and screen.if the tv is losing brightness then it time to change the lamp.cleaning is required on all dlps and vacuum out the vents ,filter and chassis which
reqires the back to be removed.
Jul 28, 2009 | Sony KP-61S65 61" Rear Projection...
Bad boards Where can i find replacements? Sony KP-61S65
This seller can help you - http://myworld.ebay.com/elmira.lv
Apr 14, 2009 | Sony KP-61S65 61" Rear Projection...
Looking 4 a part
You can always cut to size a piece of plexi-glass from the hardware store, it just won't have the same glare reduction layer on it. Install into the bezel or get the tape/velcro to attach to the front of the screen. If you want the original part, call Sony for your closest authorized techs.
Dec 06, 2008 | Sony KP-61S65 61" Rear Projection...
Sony kp61s65 dull picture
well I had the same problem and my husband opened it up and cleaned it and now the picture looks very good. So u might try openning it up and cleanning it ur self.
Nov 27, 2008 | Sony KP-61S65 61" Rear Projection...
Dull picture on my KP61s65
You can safely clean the mirror and lenses, it can greatly increase your picture if its dirty. If you unplug your tv you can safely remove the back and gain access to the lenses. All it takes is a philips screwdriver. After you remove the back, you can remove the light barrier between the upper and lower half to free up some room. Take a dry scratch-free cloth and wipe the dust from the lenses. If they're grimy, use a little lens cleaner (liquids used sparingly here, electronics don't like liquids, be careful) You can look up into the top and see if the mirror is dirty. A flashlight shined on it will illuminate the dust/dirt if its there. If you don't smoke you likely won't need to clean the mirror, but it may need it. Use windex or similar for tough grime.. I can usually reach up to get the whole mirror but I've heard of using a swiffer mop to reach the top. Removing the screen is difficult but possible if needed to get inside. Don't touch the back of the screen but lightly with a rag to get cobwebs, etc.
Sony KP-61S65 61" Rear Projection Television Logo
66 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
