Question about Canon imageCLASS MF8180C All-In-One Laser Printer
I have deleted all of the drivers for my mf8180C but it still says that there is a older version on my computer in turn not allowing me to install the new driver.
  • 55 Answers
To unninstall completly your printer from your computer you must delete form registry and from windows folder, To do this you must folow this steps: A - add/remove program: 1. start/control panel/add remove program 2. select your printer adn unninstal all features B - printer folder 1. Click Start, Control Panel and double-click Printers and Faxes. 2. Delete all the Printers available, by right-click and selecting "delete" option. 3. Click File menu and select Server Properties. 4. Select the Drivers tab. 5. For each entry, select the entry and click Remove. C - Windows registry Before modifying registry, take a backup of it.
1. Click Start and click on Run. 2. Type Regedit and from File menu, click on Export Registry. 3. Select "All" option for backing up every key of registry. 4. Give a destination file (say Regbackup) and save it on to the Desktop. 5. Now, click "+" beside HKEY_LOCAL_MACHINE\SYSTEM 6. Click "+" beside CurrentControlSet 7. Click "+" beside Control 8. Click "+" beside Print 9. Click "+" beside Environments 10. Click "+" beside Windows NT x86 11. Click "+" beside Drivers 12. Under this key, there will be the keys Version-2 and Version-3 (some may be absent, which is normal) 13. Click on each Version key to find contents in the right-window pane. 14. Delete all the sub-keys inside Version-2 and Version-3, but not these keys themselves. 15. From File menu, click exit. C - deleting folders 1. Click Start, Run and type "cmd" (without quotes). 2. Key-in the following commands:
net stop spooler net start spooler
3. Type exit. 4. Open Windows Explorer and navigate to: %systemroot%\system32\spool\drivers\w32x86
NOTE: %systemroot% is usually C:\Windows, but it might be "winnt" or something else; this is set when the OS is installed. 5. Inside w32x86, there will be folders with the names 2 and 3 (some may be absent, which is normal) 6. Delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves. 7. Inside w32x86, there may be other folders with names starting with "hewlett_packard", "hphp" or something else; delete these folders also. 8. Restart the print spooler (as in 2nd step, above) 9. Restart the computer.
At this point, the system should be pretty well back to the way it was before any printers were installed. The printing subsystem is then "clean" and ready for printers to be added using printer drivers. Install the all-in-one software, now."
Posted on Apr 09, 2011
Install driver canyon web camera f/2.0 f:4.8mm
Drivers could be installed for older Windows versions. When you camera is from the time before Windows 7, for that check the box it came in, you ran out of luck. Since Windows7 Microsoft only allowes certified drivers in their OS. The drivers you still have for older versions, you can't get them in windows 7 or 8. You always could try a generic driver, but if you webcam has special functions, they most likely won't work on newer OSn.
May 23, 2011 | Computers & Internet
I have lost my drivers cd of msi Vclass drivers cd of ms7312 how to download from net for free
http://majorgeeks.com/DriverMax_d5260.html Win7/Vista/XP . DriverMax is a new tool that allows you to download the latest driver updates for your computer. No more searching for rare drivers on discs or on the web or inserting one installation CD after the other. Just create a free account, log in, and start downloading the updates that you need.
You can also export all your current drivers (or just the ones that work ok) to a folder or a compressed file. After reinstalling Windows you will have everything in one place!
Most of the situations when Windows is running slower are caused by faulty driver installations. Windows stores all versions of older drivers just in case you want to go back; sometimes it messes up older versions with more recent ones. The Export Wizard will only export the drivers you select by copying the needed files to a folder or a compressed ZIP file.
After reinstalling Windows all drivers will be back in place in less than 5 minutes - sparing you of searching, inserting disc after disk and losing precious time. The Import Drivers wizard allows you to install all the drivers that you exported earlier. The entire operation might take up to 5-10 minutes.
Just one single computer restart will be required after all drivers are reinstalled!
DriverMax is able to display a complete report of all drivers (versions, release dates) installed on your system. This feature can also be very useful when you want to analyze the differences between the drivers installed on different machines. Hope this helps
Apr 10, 2011 | MSI K8MM-V Motherboard
USB 3.0 drivers are crashing the system
Apr 06, 2011 | ASUS Rampage III Formula LGA 1366 Intel...
I need driver for Phoenix webcam
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver
hope this helps also
http://majorgeeks.com/DriverMax_d5260.html . DriverMax is a new tool that allows you to download the latest driver updates for your computer. No more searching for rare drivers on discs or on the web or inserting one installation CD after the other. Just create a free account, log in, and start downloading the updates that you need.
Apr 04, 2011 | Computers & Internet
Where can i download the latest driver
Apr 04, 2011 | MSI StarUSB3 USB adapter PCI Express x1 ...
I need a driver in order to be able to use my Sony voice recorder ICD-P520 on Windows 7 64 bit
Unfortunately, Sony does not support this recorder under Win7 64-bit. See http://esupport.sony.com/US/perl/swu-list.pl?mdl=ICDP520&SelectOS=27 for the available drivers. You can try the Vista or WinXP driver with the compatibility mode. (This may involve allowing unsigned drivers since there is no information on 64-bit compatibility on either the Sony or Microsoft Vista Compatibility site.)
To try this, download the driver and right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
I hope this helps.
Mar 14, 2011 | Sony ICD-P320 Digital Voice Recorder
I need a driver for lide80 canoscan scanner
What OS do you have? The drivers (supported OS versions) for the LiDe 80 are available here: http://www.cusa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_80#DriversAndSoftware . If you have Win7 64-bit, the Vista x64 driver doesn't work even in the compatibility mode.
If you want a work-around for the 64-bit OS, Win7 Pro and Ultimate allow you to download and install XP mode free. This takes two programs, Virtual PC and the XP mode, that you download from Microsoft and install. This will run a virtual computer under Win7 and you can install the scanner to the virtual computer. To share files with the real computer, you should store them on external media.
Alternatively for Win7x64, you can install any of the other Virtual computer programs (Parallels, VMWare, etc) with a licensed older version of Windows. Then do the same as above. Another option is a dual boot computer with the older licensed version of Windows with the scanner installed to the "machine" with the older OS. I don't see a Unix driver for this scanner so you need a valid copy of Windows.
I hope this helps.
(If you have Win7 x64, the only other options are 1) to try and get Canon to extend their drivers (since they do support Win7 32-bit) or 2) get a new scanner.)
Sep 15, 2010 | Canon CanoScan LiDE 35 Flatbed Scanner
Canon MF 8180c - MFToolbox does not find scanner on Vista 64bit
Hi ...
As per my knowledge, MFToolbox does not work with Windows Vista 64 bit ....
But just to be absolutely sure about it, I checked for this information in multiple locations including canon official website but got the same answer ... it does not work with Windows Vista 64 bit ...
I know I can't help to resolve your issue ... But do vote ...
Cheers ... :)
Jul 26, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Scanner
You need to uninstall the existing driver first and reboot the computer then try downloading the vista driver and install it back that should take care of the issue.
Regards
Sep 18, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
73 people viewed this question
old marine
old marine
