Acer aspire desktop cd rom will not open. When button is pressed, a nois can be heard but tray does not open.
  • 4,737 Answers
It must be hardware problem with the CD rom. There are few gears inside the unit with some plastic levers that regulate opening and closing of the Tray. If the problem persists, you will need to repair or replace the CD rom. In the meantime, as a temporary solution, straighten a paper clip (a a long needle), push in through the tiny hole just below the tray while you press the eject (Open) button. You'll need to press inside the pin/clip with possible force and it will automatically eject out. Push in the pin/needle straight, you don't need to find anything inside the hole, just push it straight in.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Posted on Apr 09, 2011
How do I open the cd rom door on my acer aspire e15
There is a button on the CD-Rom tray on the RH side of the laptop. Push it and wait a few seconds, and it will open (see attached image) 25343306-sh5aycsslpxcg1igdkhvctrc-4-0.jpg
Dec 29, 2014 | Acer Computers & Internet
CD tray wont open! how can i open it?
There is a small hole on the front of the drive. just push a straightened paperclip into the hole and it will pop open.
Mar 20, 2012 | Acer Aspire X1200-B1601A PC Desktop
Acer 5742 cd rom is not openin. Please advise
INSERT A LONG NEEDLE IN THE SMALL HOLE NEAR THE CD TRAY AND SIMULTANEOUSLY PRESS THE EJECT BUTTON.THIS WILL PUSH THE CD TRAY OUT.
PLS REPLY OR COMMENT. THANKS
May 16, 2011 | Acer Aspire 5742Z-4200 Notebook
How to restore my acer aspire 6920 to it's original setting?
http://acer.custhelp.com/app/answers/detail/a_id/161
In order to recover the Operating System using Acer Recovery Media please perform the following:
  1. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. Using the keyboard arrow keys, arrow over to Boot.
  3. Refer to on screen instructions to set the first device to CDROM.
  4. Press the CD-ROM drive eject button and insert the System CD.
  5. Close the CD-ROM tray.
  6. Press the F10 key, and then the Enter key to save the changes and reboot the system.
  7. The computer will boot from the Acer Recovery Media, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media they may be purchased at our Acer Recovery Media Order Form.
Dec 01, 2010 | Computers & Internet
Acer desktop computer can not open cd-rom drive
try:-
1. select "my computer", right click on cd drive, and click on eject
2. switch off pc,then manually eject cd tray by inserting a strong paper clip in the small pin hole on the front of the cd drive,insert the clip for about 1.5 cm (half inch) in the pin hole and you will feel it press on a lever to open the tray slightly.
Apr 30, 2009 | Acer Power 1000 PC Desktop
DVD Door Won't Open
I have this problem with my DVD rom too. I don't know if we have the same ones or not. I took mine apart to try and diagnose the problem, and it turns out that there was this thing inside that wasn't dropping down all the way to allow the tray to slide out, it was staying locked in place.
I was unable to find a cure for this.
However, I found that when I press the button to open the DVD rom, when it fails to open, I give the top of mt computer a slap, and it un-locks the mechanism and the DVD tray slides out properly.
I hope this helps.
Jan 04, 2009 | Acer (91.48R37.002) CD-RW/DVD-ROM (Combo)...
Acer aspire cd/dvd drive not working
Most likely if you have to use a paperclip to open the door, your drive is bad and needs to be replaced. They are pretty easy to install, directions depends on if you have a desktop or laptop Aspire.
Nov 05, 2008 | Acer (91.AB264.023) Internal 32x CD-ROM...
Help
Your CD-ROM may still be functional. The tray may just be stuck, instead of broken. First let's remove the CD.
Get a large paperclip and bend the end out straight. Look for a tiny hole underneath the CDS tray. Push the end of the paperclip into it, and it should open the CD tray a little. Then pull it out the rest of the way and get your CD out. Then try pushing the eject button on the CD-ROM to get the tray to go back in. It may take several trys. If that does not work push the tray in, slowly. Then try the eject button again. I hope that works.
If it does not you can continue to use the CD of course (lots of CD-ROMs have paperclips hanging out of them. And I've seen the problem go away, occasionally, after continued opening and pushing back the tray.
Mar 10, 2008 | Acer Aspire L100 PC Desktop
How to instal a laptop dvd rw
open cd rom tray.open laptop lcd screen flat, remove the 2 screens on the back of the hinges.carefully remove the bezel(just above the keyboard, with the power buttons etc )from right to left.remove 2 screws securing keyboard.you will see one screw that holds the cd/dvd rom in place.remove screw,pul on tray carefully, cd rom will slide out. replace with new cd rom.
Dec 07, 2007 | Acer Aspire 5100-5033 Notebook
CD Rom Driver door won't open without using the straightened out paper clip or pressing the driver door button upwards of 15, 20 or maybe 25 times. It will eventually open after repeatedly pressing for...
If this happens with all your CDs and everytime, I would suggest you should replace your CD Rom Drive with a new one. After use of some years CD Rom Drives have such problems. Otherwise a software might locking your drive. you should find a tool which unlocks the drive and then press the eject button.
Oct 06, 2007 | Acer Aspire M1640 Refurbished Intel...
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
