Question about Philips Philishave HQ7850 Electric Shaver
The cord for the charger (jet clean system) has broken - where do you get a replacement cord?
  • Philips Master
  • 1,602 Answers
You will find a replacement cord for model HQ7850 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-shaver-wall-charger-transformer-cord-p-270.html
Posted on Apr 10, 2011
Battery problem
follow this test and fix it. God bless you
Bad cable connection
Check the USB cable for damage and dirt, especially at the ends. Then try using the wall charger, as this will provide greater power input than the computer/USB.
Broken charger or USB cord
Try using different chargers to see if you may have a problem with your charger or cord.
Obstructed/bad dock connector
Inspect the 30-pin dock connector at the bottom of the iPhone for dirt, lint, and damaged pins. Clean out the dock connector very carefully with a tooth pick or soft toothbrush. If the dock connector is broken, you will have to replace it.
Nov 06, 2013 | LG Cell Phones
Iphone wont charge
follow this steps and fix it. God bless you
Jul 31, 2013 | Apple iPhone 3G
Samsung gt 55830 is not charging the battreies
follow the instruction and fix it. God bless you
Jul 27, 2013 | Samsung Cell Phones
Telefunken mr701 diagram
Jul 11, 2013 | Cell Phones
Turn off audible alarm when changing towers
God bless you
Jun 01, 2013 | HTC Cell Phones
No power
Try another outlet, cord/charger, with the EXACT same power specs. Has the cord plug been pulled while pluged in damaging the AC jack? Does the computer boot on battery power?
Feb 20, 2013 | MSI A6200-059US Laptop
Battery is not working well
Step 1:
which operating system ? and type of laptop ?
If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 20, 2013 | Computers & Internet
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
My power cord has broken at the tip. Can I
Braun Syncro 7570 power cord is Braun 7030458 adapter charger cord.
Feb 08, 2010 | Braun Syncro 7570 Electric Shaver
Lost jet clean charger for philips architiect
Hi, it may be worth your while looking at e-bay to see if anybody is selling a broken shaver with all the bits still working, You can usually pick things up that way, plus, they are often Very cheap! Best of luck, Nick.
Nov 09, 2008 | Norelco Arcitec Electric Shaver with Jet...
Philips Philishave HQ7850 Electric Shaver Logo
113 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
