Question about Black & Decker 1000w Power Inverter
Have a 1000 watt black n decker converter and it is humming and making a loud sharp noise. The pump that it's attached to does work. We are trying to find out why it's making these sounds.
  • 591 Answers
When connecting a MOTOR to a DC to AC inverter the clipping sound comes from the fact that a inverter produces a switching voltage (Square wave) not a sine wave, than the motor's winding acts as a transponder and emits a clipping sound.... always check the specifications to see if you can plug any kind of motorised device to the inverter... electric motors have a different load ratings than other electric/electronic devices due to the mechanical impact (if it turns freely or has restriction) it affects the power rating...
Posted on Apr 09, 2011
Why does it make a loud Humming noise?
Something is still in the main wash pump, you hear the motor trying to turn the impeller and it can not
Mar 27, 2016 | Dishwashers
240 v should work right?
no, voltage is not the issue, what is the amperage you need. If you need more than you have, then you could have 2000 volts and it will not work. Also your taking AC to AC, or DC to DC. There's a big difference in what you need for each.
look up Ohms law for for the calculations needed for voltage vs amperage using one socket.
good luck
Apr 30, 2013 | Health & Beauty
Transformer
look at your charger,on sticker you have the power it drain.
Oct 31, 2012 | Black & Decker Black And Decker 12 Volt...
Black and decker electric hedge trimmer makes a loud noise, motor hums and blades won't work. Loaned it to friend. Big mistake.
thats a BIG 10-4.. GOOD BUDDY . loosen the bolts that clamp the blade together. NO DRINKING WHEN WORKING ON THE FINGER TRIMMER !!!.. after the bolts are lose try it again. it may just have a bent tooth.. if not you can't do any harm, just start taking it apart, take pictures,. so if it is something stupid wrong you can reassemble it.. make up a repair bill for 25.00 on you computer and give it to him
May 27, 2011 | Garden
Our KitchenAid microwave works well, heats food, etc., but makes a constant loud and annoying humming noise (close in frequency and tone to the hum of cold fluorescent tubes) even when not in use. When...
hi it could be a bad neutral connection on your plug or inside on your high voltage transformer check the plug for burning and try plugging it in a different socket
Mar 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
2006 ford fusion 34000 miles. Has loud buzzing/humming vibration noise at approx 1000-1100 rpm. Seems to come from near alternator area.Any ideas?
hi iv had a simular noise on a fusion i done and it was the water pump bearings making the noise the only way to solve this is to replace the pump ,
Sep 30, 2010 | 2006 Ford Fusion
Loud noise in front/side. When make a sharp turn
most likely a cv axle if it makes popping noise in turns
Jul 07, 2010 | 1991 Subaru Legacy
Making loud humming noise only.but if you plug
If I understand this correctly: with NO input or cable attached it hums; with an RCA cable attached it works. (What does 'some' mean in this regard?)
You say that connecting the RCA cable improves its sound. That tells me you're supplying a ground through the RCA cable for stray voltage in the sub.
It seems there may be a basic power issue if it hums with no input. Sometimes a given power source in a home may be wired differently than others or may insufficient grounding, which can result in hum. Try reversing the sub's power plug or move it somewhere else.
Since the sub contains its own electronics it is also susceptible to strong external magnetic fields. Keep it and any signal cables leading to it some distance away from other electrical devices like TV's.
Apr 08, 2010 | Velodyne CT-100 Speaker
I bought a Sharp Carousel 1100 watt microwave about 8 months ago but now it makes a louder noise when it's on and it doesn't heat. Can I easily fix this myself or is this now trash?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron.
Since it's less than a year old, it's fully under warranty and Sharp will fix it free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online to get it fixed.
Jan 30, 2010 | Sharp Microwave Ovens
Describe your Black & Decker Power To
No. You will need typically 35-40 watts for a LCD monitor. 20 watt may not even run DVD's on your laptop. Look for something 80 watt or so.
Jul 07, 2009 | Black & Decker Power To Go Cordless AC/USB...
Black & Decker 1000w Power Inverter Logo
250 people viewed this question
Top Black & Decker Electronics - Others Experts
PNiss
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
