Question about Audiovox D1708 Portable DVD Player
PVD73 model Had it about 4 months and used it maybe 3-4 times now it will ot work at all
  • Anonymous Jan 05, 2009
    I am having the same problem with my Audiovox PVD73
    did anyone help you
  • wilddanielle Apr 28, 2009
    only had my player a year dont use it all the time. my daughter used in the car on thursday april 23,2009 and now it wont work at all. it wont even turn on.
M dvd audiovox pvd73 want come on even while trying to charge. Can you help me or send me some solution to fix this problem.
Posted on Oct 18, 2008
SOURCE:
Reset ecu on Nissan hardbody 2006 model.stoped it at home,now wont start.maybe for second or two.Nats light not working on dash. keys still opening doors,enjin turning,does not start.enjin check light
Give this a try.....Timing is not as critical with this method...no stop watch needed. Just count in your head...one-one thousand, two-one thounsand, etc, or usestop watch. The most critical step is step #3....wait 10 sec, instead of 7.
1. Ignition "ON", count to 3.
2. Depress/Release pedal 5 times...hard and fast.
3. Count to 10 (not 7!) and fully depress pedal
4. Count to 12 (SES should be blinking), release pedal
5. Count to 10, depress pedal
6. Count to 10, release pedal.
7. Turn off ignition, then 81377951893%26mt_id%3D570%26mpre%3Dhttp%253A%252F%252Fwww.ebay.com%252Fitm%252Flike%252F181377951893%26mid%3D446528%26sdc_id%3D%7Bsdc_id%7D&DealName=12v%20Electric%20Push%20To%20Start%20Engine%20Ignition%20Button%20With%20Red%20Led%20Light%20Up&MerchantID=446528&HasLink=yes&category=0&AR=-1&NG=1&GR=1&ND=1&PN=1&RR=-1&ST=&MN=msnFeed&FPT=SDCF&NDS=1&NMS=1&NDP=1&MRS=&PD=0&brnId=2455&lnkId=8070676&Issdt=150102050536&IsFtr=0&IsSmart=0&dlprc=19.99&SKU=181377951893">start engine. Done!
Jan 02, 2015 | Nissan Cars & Trucks
Some\key\are\ot\workig.\ackspace\is\ot\workig\
You could have your keyboard settings set to a different language.
option 1 (Language Settings)
1) Click [Start]
2) Control Panel
3) Regional and Language Options
4) Click on the Languages tab
5) Click on the [Details...] button
6) Check if the Default input language is set to English US
and
under installed services, check if the keyboard is set to 'US'
option 2 (Driver issues)
1) click [Start]
2) Control Panel
3) Keyboard
4) Click on the Hardware Tab and select the Keyboard then:
a) use the [Troubleshoot...] button or
b) click on properties, select the Driver Tab, Uninstall driver and press [Ok]
reboot your laptop. It should reconfigure your laptop keyboard drivers.
option 3 (Hardware issues)
If you have a PC, try connecting that keyboard to your laptop and see if that works. If it does then your keyboard maybe bad.
Jun 10, 2011 | Dell Latitude E5500 Laptop
I use my benzomatic to fire metal clay and when it ran out of gas I refilled it and it hasn't worked since. I thoight maybe I over filled it ot tried to use it to soon after filling so I let it sit for...
Tell us more what model benzomatic, if the valve works, do you hear gas, etc.?
Perhaps there was some splatter from the metal clay you were heating, and it become plugged?
Jun 10, 2011 | Garden
Audiovox PVD73 I wanna play video games on it but I can't figer out how.
I believe the PVD73, is a player only. Not a video game player.
Read Ya,
Z
Jan 01, 2010 | Televison & Video
Button works intermittently on Kensington Wireless Mouse P/N 6439
battarys maybe running low on juice or the ball may have oil on ball, look for reset switch on buttom of mouse press on it,
if info ray type clean the light area, reset the mouse and the usb plug in usb mouse adapter, it may be colored ot not, should be the same color as the mouse one is reset both at the same time.
rod
Feb 06, 2009 | Kensington PilotBoard 64385
Inferior Kodak Printheads
I called Kodak tech support and they are sending another printhead within 3-5 business days. Hopefully this will solve the problem I'm having and last awhile.
Jan 10, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
PLAYSTATION 3: I INSERT ANY OF MY THREE GAMES THAT I HAVE AND NEITHER ONE PLAYS. THE PLAYSTATION GOES TO THE MAIN MENU AND STAYS THERE. IT WONT GO DIRECTLY IN TO THE GAME, OR IN THE MAIN MENU IT WONT SHOW...
you meesed up your firmware. go on internet and search 2.40 firmware update ps3. download to memory stick and put in ps3 go to external devices click on flash drive do the update the ur done.
if it dont work, bring it to sony or place u bought it at. get a replacement.
Jul 07, 2008 | Sony Playstation 3 (PS3) Console
No text
i had a problem like this and i called tech support, they told me to turn the phone off & then back on... it worked. maybe you should tell your sister to try that too
Nov 05, 2007 | Motorola Mobility MOTORIZR Cellular Phone
Durabrand Portable DVD Model # PDV-705
hi sir. any rechargable battery is to be treated like that way 1 -never leave the empty battery without charging any way because if you get it uncharged for one day you loose life time 2- charge it emmideatly after use for two hours or to end charging sign 3- evry two months try to completly discharge it and re charge 4- don't leave the batt, not working for more that 4 months 5- if you want to leave for more that 3 months charge it well and comletly please don't forget to do excelent rate cause i here to help you regards
May 06, 2007 | Durabrand DUR-1700 Portable DVD Player
About replacement filters in refrigerator
grand, on this model the filter is designed to be used for up to 8 hours of open valve time or one year of calendar time. In other words if it takes you 8 seconds to fill a glass, that would be 8 seconds of open valve time. When 90% of the filter time elapses, either open valve time or calendar time, (which ever comes first) the main control board will indicate the amber light. When 100% elapses, the light will go red. As far as recycling..you would have to give GE a call..Catriver..post back
Mar 19, 2007 | GE GSH25JFR Side by Side Refrigerator
Audiovox D1708 Portable DVD Player Logo
205 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
