Question about Dishwashers
I need the faucet connection for this dishwasher
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that will help you to get better results from your question onFixya.
How to ask a question on FixYa
heatman101
Posted on Apr 09, 2011
Do I need to replace the adapter for the faucet areator for my portable dishwasher.
Probably. If you didn't discard the package of extra fittings that came with the dishwasher, you may find the correct adapter/aerator fitting in there. Otherwise, try contacting the manufacturer of the dishwasher. Be sure to provide the make and model of the new faucet along with the model number of the dishwasher.
Jan 03, 2015 | Dishwashers
Kitchen faucet quick connect adaptor like portable dishwasher, read on
You can't find a portable dishwasher connector? Try an appliance parts supplier.
May 17, 2014 | Plumb Pak Faucet Adapter
Do you leave the water on from the faucet?
Hi Melva,
You need to turn the water off to connect the dishwasher, but the water from the faucet should be on to run it. See the video below for more information:
Sep 24, 2013 | Danby DDW1899WP Portable Dishwasher
How to install
Free standing dishwashers do not need "installation". Inlet hose simply connects to standard faucet and exhaust set in sink. If you have a fancy faucet that is incompatible with your faucet, you could get creative and unscrew the faucet head and connect the dishwasher inlet hose to it.
Dec 02, 2011 | Bosch 24 in. SGS43C12 Classixx...
I have a Maytag LWC202 free-standing dishwasher w/butcher block on top. Bought second and I don't have owners manual. When I connect it to the faucet the water shoots back up instead of going into the...
There is a connector the has to be on the faucet in order to connect properly to the faucet. Go to a hardware store and tell them you need the connector for your dishwaher to connect to your kitchen faucet. There are two dif ones. They are only a couple dollars each.
Jun 24, 2011 | Maytag Dishwashers
Portable dishwasher won't stay connected to the kitchen faucet
it the faucet connector has a lever u push in order to latch on to the faucet, just jam something under it so it maintains upward pressure and wont come unlatched when the water starts flowing
Jan 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
I have to connect a 'Y' piece connector to my dishwasher as there is currently no cold water getting to it. How do i go about doing this?
If I'm not mistaken only hot water goes to the dishwasher. What you have is a valve with two outlets usually 1/4 or 3/8 one goes to supply side of sink faucet and other to the supply line of the dishwasher. This valve connects to the hot water supply line of the house. The stub outs should be close to the D/W. If you want to use cold water then you will have to connect this valve to the cold water supply and then connect one side to the dishwasher and the other to the the cold side of sink faucet. Also I believe that dishwashers need the water to be at a certain temperature +/- 150 degrees.
Home Depot/Lowes sell the valves fairly cheap. Hope this helps.
Jun 26, 2008 | Dishwashers
Faucet Attachment Leaks
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Dec 09, 2007 | Maytag 22.1 cu. ft. Bottom Freezer...
The o rings need to be replaced and plumbers lube added on the interior of the connection point.
May 15, 2007 | Kenmore 17259 Free-standing Dishwasher
Dishwashers Logo
157 people viewed this question
Top Dishwashers Experts
