Question about Leadtek WinFast TV2000 XP Expert (44842862T) TV Input
Fails to build graph - Leadtek WinFast TV2000 XP Expert (44842862T) TV Input
Syntax error for graphs
That hardly seems possible. Try graphing the function y=x.
There are a few ways to draw curves on this calculator
  1. Drawing functions
  • Type is y=f(X), the [X,theta, T] key enters X when pressed
  • Type POLAR r=f(theta), key [X,theta, T] enters theta w. pressed.
  • Type PARAMETRIC, requires an X=f(T) and Y=g(T) functions
  • Inequality graphing. You can also draw some functional inequalities such as y> 2X^2-3
  • Dynamic graphing (graphs where some parameter may be changing)
Drawing Relations
There are some other relation you can draw X=, X>, X< , and the drawing of general conics.
I hope that the foregoing remarks help you sort out the problem you are having. If they fail to do that, I suggest that you read the manual that shipped with your Prizm.
Sep 27, 2012 | Casio Prizm FX-CG10 Color Graphing...
When i open the Acer crystal eye webcam it gives me the error " can't build the graph.
Dear Friend,
Try to reinstall the driver by visiting the Acer website:
http://us.acer.com/ac/en/US/content/drivers
Good Luck!!
Nov 11, 2011 | Acer Aspire Computers & Internet
Acer aspire one says "cant build graph" when i
Hi
Do One thing
Run A disk defragmentation on C: Drive & than U try it run again
Thanks
Jan 04, 2011 | Acer Aspire One PC Notebook
Camera says graph render fail what does this mean
Ok what that means is the DirectX "Graph" or set of instructions that tells windows graphics, how to perform, what Filters to use, and how to and what to, do with the signal to be displayed. This is generally an error to do with TV cards, Display cards etc. usually again, it means that the correct CODECs aren't installed, and when the "Graph" tries to "load" them, it cannot "Find" them, and thus fails, and displays that error message.
May 12, 2010 | Computers & Internet
Cant build the graph on webcam
Install WebCam application (Cyberlink YouCam).
To download, go to this link:
http://www.freedownloadscenter.com/Network_and_Internet/Video_Chat_Tools/CyberLink_YouCam.html
May 04, 2010 | Computers & Internet
My graphing calculator only allows me to graph one line at a time
Once you enter an equation the corresponding equal sign is highlighted by default. Before you draw the 2 graphs, move the cursor to Y3 or Y4 and verify that the = signs for Y1 and Y2 remain highlighted. If one is not highlighted, move the cursor on it and press ENTER.
Once all the = signs for all the functions ypu want to draw are highlighted permanently, press the [GRAPH] key.
Depending on the functions ane the window dimensions certain graphs may not show up and one can Zoom out or adjust the window.
If you still have problem, press [2nd][STATPLOTS][4: PlotsOff] [ENTER]
Command PlotsOff echoes on main screen. Press [ENTER], screen displays Done.
If all else fails, just reset the RAM by pressing [2nd][MEM][7:Reset][1:All RAM][2:Reset], press [CLEAR] to clear the message.
You shouild make it a habit to clear the RAM every time you start a new type of problem.
Hope it helps.
Oct 19, 2009 | Texas Instruments TI-84 Plus Calculator
List disapearance and graph problems
You have accidentally deleted lis 1 and list 2 instead of clearing them. Press the stat key. Select #5 (set up editor). You are now back at the home screen. Press enter. Screen will show "done". Your list one and list two will now be there when you press stat and select edit.
Jun 09, 2009 | Texas Instruments TI-84 Plus Calculator
How to create a dynamic graph in php
try this links and download source code from there :
http://www.wellho.net/mouth/1104_Drawing-dynamic-graphs-in-PHP.html
or
http://www.lestercat.net/dev/svg/SVG_graph/
or
http://code.google.com/apis/chart/
May 15, 2009 | Computers & Internet
Leadtek WinFast TV2000 XP Expert (44842862T) TV Input Logo
694 people viewed this question
Top Leadtek Televison & Video Experts
Are you a Leadtek Televison and Video Expert? Answer questions, earn points and help others
