Question about Frigidaire GLTF2940ES Front Load Washer
My washer won't drain completely, leaving water standing in the molding at the front of the washer. It makes the inside stink and get mouldy. I wish I could return it. Sarah Thompson Jackson, MO jodi63755@yahoo.com
    Brigadier General:
  • 6,277 Answers
(Ensure the draining holes in the moulding are clear so that the water drains back into the drum as it is meant to then)--->I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Posted on Apr 09, 2011
Clothes come out musty
I would put in some bleach and clothes that can handle it without damage and run a wash cycle. Leave the door open when you are done using the machine, or at least un-latched. There are commercial products, but bleach will do the same thing. You have stuff growing on the gizzards inside the drum, and bleach will likely kill them. They like dark & humid places.. guess what... that's your washer with the door kept latched.
Aug 15, 2014 | Kenmore Elite HE5t Washer
The clothes come out smelly mouldy and I want to clean it out
Just a suggestion but if you let the water level to the lowest level and then use several gallons of bleech in the water, it should kill any mold that is growing in the unit. And you won't have to take things apart to see if it works.
I would run the bleach solution first, and then run another load with just rags or something and see if there was an improvement or not.
Then do another load (without clothes) with a lot of lemon juice to finish the cleaning process.
Jun 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
Why does My washer have a moldy musty smell?
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Apr 30, 2011 | Asko W6021 Front Load Washer
It has a horrible odor. Also the little door on the left bottom front of the machine holds water. How do you keep the water (stinking) from standing in that area?
Front loaders are known for building up mold and the smell.
It's caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It's caused by using fabric softener. Dilute it 50/50 with water.
It's caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
If the standing water is your fabric softener you'll have to clean it out to unstop it so it will drain.
Here's a DIAGRAM which may help with the cleaning.
Mar 12, 2011 | LG WM2233H Front Load Stacked Washer /...
Why do I get the sewage smell when the front load washer first throws the water out. Help me , it is really bad.
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, leave the lid, or door to the unit open after every wash for a week. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again(warm), to avoid damage to the clothes from the bleach left standing in the wash tub.
Aug 10, 2010 | Washing Machines
The loading door gasket-- the big rubber liner doesn't drain
Some front loaders have a door boot drain hole, most do not and it is normal for some water to accumulate at bottom of boot. To help with mold and mildew use a washing machine cleaning solution, follow directions. Also a bleach solution of 2 parts water 1 part bleach sprayed on area helps. If mildew is really bad, nothing will completly remove it. Make sure you use only a high efficiency detergent.
Feb 03, 2010 | Washing Machines
Sewer smell when I use the front load washer
try rid-x see if that helps pour down drain pipe for washer then add water you may also want to pour rid-x through toilet as well and bleach out washer
Dec 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machine Stinks
Nov 21, 2009 | Dryers
Washing machine smells like stagnant water...making clothes smell bad as well. No visible water laying anywhere
Oct 31, 2009 | Electrolux EIFLW55HIW Front Load Washer...
My front loading washer has a smell????
Oct 19, 2009 | Whirlpool Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
37 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
