Question about Water Heaters
Hello - I have a 6-7 yr old Whirlpool EnergySmart 50 gallon 5500 watt water heater. (Two control boards fried and were replaced free). Symptom now is not enough hot water. No 'error codes' are blinking on the diagnostic light. I have removed the control board cover and check for voltage to the upper and lower elements. After a long period of none-use, neither element is receiving voltage (normal). After some use, the current is directed to the lower element (orange wire), and the supplied water still properly hot. I then opened a high output (basement) faucet until the water became luke-warm. Lower element still energized. Shortly, a relay was heard and the voltage was directed to the upper (yellow) element only. All seems normal, except perhaps the upper element might have come on sooner to prevent the supplied water from becoming unusably cool. Is this likely an upper sensor that is no longer of proper 'calibration'? Is this device something whose value would change with time, or is it a type that would either be OK, or failed? (clearly it still functions enough to trigger the switching the system from lower element to upper). Maybe I expect too much, but this seems to be a recent change in our domestic water supply. I also notice that the number of the control board has changed (last digit)(my boards look the same, unlike other writer whose first board lacked a reset), and that the heater in stores is now supplied with 4500 watt elements. Is this an industry wide change, or has Whirlpool perhaps found that their relays can't handle 5500W? I have 10 gauge wire, 30Amp breaker.
  • 20 Answers
Sorry to see you're having problems! Can you contact me directly so I can help?
www.whirlpoolwaterheaters.com/help
Thanks ~ Chris
Posted on May 26, 2011
1) Residential water heaters are non-simultaneous. Only one element works at a time.
Upper element comes on until top of tank is heated, and then lower element is switched on until lower part of tank is heated. Lower element keeps tank hot during standby hours
http://waterheatertimer.org/How-it-works.html
2) Typical Whirlpool energy smart has 4500Watt elements. Look at label on side of tank
If both elements were ON, that would draw 9000Watts or 37.5 amps, requiring 50 amp breaker and 8 gauge wire. V x A = Watts.
All dual-element tanks are 240V.
Whirlpool energy smart requires 10 gauge wire and 30 amp breaker so electronics are not starved during operation. If your wire or breaker are undersized, that is suspect for repeated failure.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
3) Typical electric water heater heats 21 gallons per hour. First hour delivery is higher since elements heat water as you use it. Overall however, electric water heater cannot re-heat as fast as gas because gas water heater burner carries more BTU punch per minute than electric element. Gas heats about 41 gallons per minute, with higher first hour delivery.
4) IF YOU HAVE OLDER energy smart and installed newer board, then you could have non-simultaneous operation is reversed so that lower element comes on first.
Read following post at Fixya:
http://www.fixya.com/support/t8263226-our_water_heater_doing
Contact Whirlpool 1-877-817-6750
5) Another potential problem is that you have sediment inside tank and that is reducing efficiency of lower element.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 10, 2011
Can i use a 4500 watt on a 208 volt system
Yes
Voltage and wattage printed is on end of each element
If element shows 240V 4500 watt, then element Wattage at 208V is reduced to 3375 watts and will heat 16+ gallons per hour
If element is rated 208 and 4500w, then element will operate at 4500 watt and heat 20 gallons per hour
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Gene
Aug 11, 2014 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Need a wiring diagram for rheem electric water 50 gallon 2007 model
1) Copy following links for standard wiring that applies to all brands electric water heater: wire colors vary, and do not matter.
You probably have ordinary residential non-simultaneous water heater.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
2) Look at tank label.
Typical label will show number of elements (upper and lower)
And give wattage for each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html#label
Notice also total connected watts.
If total connected watts is same as individual upper or lower element watts, then you have ordinary residential non-simultaneous tank.
Mar 07, 2013 | Water Heaters
Bottom element has no power
possible control board or temp sensor
Feb 17, 2013 | Richmond 6E50-2 50-Gallon 4500-Watt...
Where can i get a 21dv50 water heater to buy
21dv50 is discontinued. This is ordinary tank-type 50 gallon gas water heater.
Amazon sells 50 gallon 22V50F1 Rheem water heater for $420 with free shipping ... but who carries the warranty?
Frankly you can get in-store returns, and buy same quality gas water heater at local box store since Rheem makes GE water heaters at home Depot.
Other brands are equally good, as AO Smith makes Kenmore water heaters at Sears and Whirlpool at Lowes.
I prefer the AO Smith because maintenance is easier.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 17, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
Whirlpool water heater pilot won't light
Thanks! ~ Chris
American Water Heater, authorized licensee for Whirlpool Water Heaters
Jun 17, 2012 | Whirlpool 6th Sense 50-Gallon 6-Year Tall...
Where are the heating elements on an 80 gallon electric water heater? Model number : E 2 F8 0 H D 0 4 5 V
I don't know that model number.
Tank-type water heater elements are located behind panels on side of tank.
Open following link to help troubleshoot electric water heater problems:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
The water heater label also shows element wattage, brand, voltage, serial number, and type of operation.
For example 5500W elements, non-simultaneous, 240V are typical ratings found on water heater.
5500 Watt would be replacement element size.
Non-simultaneous would indicate that both upper and lower element are not turned ON at same time.
240Volt is typical voltage for water heaters.
Serial number carries date-of-manufacture, based on brand.
For common brands:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Add a comment for more free help.
Apr 13, 2011 | Whirlpool Water Heaters
Water heater pilot wont stay lit
try cleaning the top of the pilot light jet if you can get to with small brush then blow it clean with a compressor.
Aug 30, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
6 yr old electric rheem fury 50 gallon all of a sudden runs out of hot water. Only one shower of hot water now where before atleast two.
you have a couple things that may cause this. you may have a bad element a bad thermastat a tripped eco (emergency cut off ) or problem with electric suppling heater.if you have no electric backround or training you should call a pro
Mar 25, 2009 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
433 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
