Question about Lincoln Electric K1297 AC/DC 225/125 Stick Welder
How di i wire my 225 ark welder came without a plug
  • K W May 02, 2011
    Can you describe the wire? Are there different colors? Green is the ground if there is. The other 2 wires don't matter which blade on the plug you connect them to.
    Guru:
  • 509 Answers
I'm assuming the cord is there and it's the flat 3 wire type. The center wire is the ground and the other 2 are the power. It doesn't matter which power wire goes on which blade, they are both the same.
Posted on Jul 15, 2011
Mechpro 100amp mig welder
It won't arc without wire in it. If the motor runs then there may not be enough tension on the feeder wheel to push the wire thru. If you had a bad kink in the inner liner it will not feed. The trigger switch in the handle applies arc voltage to the copper nozzle. It may be bad or have a broken wire.
Dec 15, 2013 | Welding Tools
Lincoln Arc Welder AC 225 Wiring Diagram
won't have reverse polarity. There are only 3 wires, 2 power and one ground. It does not matter what power lead goes to what side.
Apr 19, 2012 | Lincoln Electric K1170 AC-225 Stick Welder
Have a ground and wire is running but will ark intermited
There are two items I would like you to do:
1) Change your contact tip and try again. Make sure the wire is running smooth thru the gun. If this not cure the problem then go to step two.2) Change your wire. If it is too old probably is rusted and not making proper contact.Hope this help.
Nov 30, 2011 | Welding Tools
I have a 125 lincoln wire feed welder. wire will feed but will not arc to weld
check you ground cable, try to strike and ark on the ground cable, if no ark test the ground circuit if the circuit is ok you will need to have the transformer tested and for that you need some specal tools.
Aug 28, 2011 | Lincoln Welding Tools
Coming out of the breaker box going to the welder plug what size wire should i use to run a lincoln 225 welder
It depends on how far away you are going to be away from the breaker box, using a #2 wire should be fine for your welder.
Nov 04, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
No ark
no ark
prolly means no bible
Aug 15, 2010 | Lincoln Electric LE 83180 Century...
Will feed wire but will not start an ark to weld
Make sure that the ground clamp is securely fastened to the workpiece.
Ensure that the power pin is fully seated into the housing where it receives the current.
Ensure that voltage and amperage settings are correct.
May 04, 2010 | Hobart 500526 Handler 210 Professional...
Welder doesnt turn on...
Have you connected the feed from your breaker box to ADJACENT lugs on a dual pole breaker? By code you must use a ganged breaker.
You should use a voltmeter to verify the plug is getting power on teh desired pins.
Sep 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln Electric K1297 AC/DC 225/125 Stick Welder Logo
179 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
