Question about Dell Dimension 4700 PC Desktop
I have a Dell Dimension 4700, the problem is that recently, i went to start it up, nothing would happen, the 4 ABCD lights don't light up, and i notice this steady amber light. So it was determined that a device is incorrectly installed or malfunctioning. I made diagnostics by trial and error.. the video card, sound card, and memory cards all work properly (i still get the steady amber with none of them installed, including USB peripherals!) I checked the hard drive and the CD drives, both are functioning properly .. the only time it works is when i tap the case right where the processor sits, and miraculously, i push the power button and it boots up. Then, after i turn it off, and turn it back on, the problem reappears and i'm back to square one. my guess is it could be that the CPU is failing..? Dell Dimension 4700 Windows 7 Ultimate 32-bit Intel Pentium 4 3GHz VANTEC 3GB RAM Hitachi HDS724040KLSA80 SATA 400GB nVidia Geforce 9500GT 1GB GDDR2 Creative Soundblaster X-Fi Titanium
  • Dell Master
  • 998 Answers
You can try to reseat the CPU (processor) chip. Inorder to do that you have to remove the heatsink and then reapply thermal paste (compound) to the surface of processor. The processor rarely goes bad.
Posted on Apr 10, 2011
  • tdsam321 Apr 10, 2011
    i attempted reseating the CPU, but the problem still persists, with or without the CPU
Dell desktop 4700 problem
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
If the LED Is SOLID amber, it is likely either a component connected to the Motherboard or a bad motherboard
May 15, 2010 | Dell Dimension 4700 PC Desktop
Dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz pentium 4 2.8 ghz microsoft xp pak 2 moterboard light= green abcd lights=green reset bios to factory settings computer keep shutting down.. windows dialog box...
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Apr 17, 2010 | Dell Dimension 4700 PC Desktop
Dell dimension 4700: top fan makes a lot of
some fans are just loud, they tend to speed up and get louder when the computer heats up, it keeps it from over heating... if it always runs hard and loud the internal thermostat could not be working right.
Feb 23, 2010 | Computers & Internet
I turned on my Dell Dimension 4700 computer,but the amber light started to blink . I held the start up button for 5 seconds and the light went out. I tried to start it up again and got the same thing,...
Vaughn it sounds like the power supply is going bad, try another known good working power supply. If that doesn't work then the motherboard would need to be replaced. If the power supply isn't giving the correct voltages that could cause the computer not to turn on. If the motheboard isn't able to convert the voltages properly then the motherboard could be faulty.
Dec 23, 2009 | Dell Dimension 4700 PC Desktop
Dimension 4700 wont light up the monitor.
Hi Cactus,
My name is ArmyMason, let me get this straight. You have a Dell Dimension 4700 and the Monitor isnt working with the PC? This could be one of two things. Either the monitor is bad, to test this I would connect it to some other computer to verify its not the monitor. It could be the video card. According to Dell it the light combo you gave me indicates their is an issue with the floppy or hard drive and you should check to see if all the cables are correctly seated on the motherboard and on the Drives.
I really think it could be an issue with the video card. To resolve this I would consider purchasing a new card or rip one out of an old know good computer to see if that is the issue.
Thanks,
ArmyMason
Feb 23, 2009 | Dell Dimension 4700 PC Desktop
Dell wont start up
On the back of the chassis, there are 4 LEDs above the PS2 connections marked ABCD what do they indicate? During the boot process the lights normally flash on and off green, when the boot process is complete, they should all be green GGGG.
If any are Amber then they are indicating a power on self test (POST) failure. AAGG is bad memory for example.
Post the indications
Aug 06, 2008 | Dell Dimension 4600 PC Desktop
Newly installed HD now PC does nothing
Check the BIOS and make sure it's doesn't still have to old HD in there. Are you seeing anything on the screen?
Hit F12 to get into system setup and find out what HD options you have.
Jul 05, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 CD/DVD drive not reading
The CD Drive has probably gone bad. You will have to buy a replacement drive. I recommend newegg.com. The price will be about 30$ for a DVD burner. If you want just a DVD player or CD Burner then it will be even cheaper. Dell provides a very easy to read step by step guide with pictures on replacing your drive here:
http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
Good Luck!
Hope this helped!
Apr 22, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 PC Desktop Logo
269 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
