Question about Pioneer M10X 2-Channel Amplifier
Mi amplificador pioneer sx-250 le aprece muting, y no ce como quitarcelo,, si me aydan porfis
4 Suggested Answers
  • 3247 Answers
SOURCE: My Pioneer Receiver (SX-255R) won't
Just to be sure we are talking the same unit I have included the link to the user manual for SX-255R
http://www.pioneernz.co.nz/Site/Pronto/Files/user_manuals/SX255R%20USER%20MANUAL.PDF
Suggestions
1. have you tried to press the Muting button on the remote unit.
(item 11 remote unit diagram)? does it make any diffrence - what if the button is stuck?
2. Have you tried to play the Tuner radio - what happens then? do you still get Muting.
3. You mentioned something about speaker wire coming out.
I understand that Pioneer receivers shut off if any of the speakers is faulty, ie, correct impedance is not showing at the speaker input point.
Usually the newer units give an "overload" message. It is possible this could be happening and the SX-255R gives the "muting" message instead. Some people have reported very minute shorts where strands of the speaker wire touch the body and it causes "overload".
One way to check is to remove speakers wires one by one and see if the "muting" goes away. Then you can check the offending speaker if that is what is happening.
Good luck
Please do drop a comment to say how you progressed.
Posted on Jan 02, 2010
  • 11800 Answers
SOURCE: Bonjour, Mon amplificateur pioneer vsx-D701S qui
L'amplificateur se met en POWER OFF parce que le syst?me de protection de la planche d'alimentation a ?t? active par un cour-circuit. Comme tous les fils ont ?t? enlev?s il est clair que court-circuit est interne - une composante importante a failli.
Remplacer le fusible n'aboutira a rien: il sera instantan?ment brule quand vous allez tenter de l'allumer. L'amplificateur doit ?tre test?e, la composante qui a failli trouv?e et remplac? - la pi?ce plus probable est un des circuits d'amplification. Ceci est un travail de professionnel, et il va ?tre cher - au moins 150€.
Posted on Jan 25, 2011
  • 52175 Answers
SOURCE: Como reparo mi cd player se quemo un ic203 del main board solo se ve la letra L quiciera saber si se trata de un regulador.despues que se quemo la pieza prende pero no lee los cd.gracias muchas.
sounds like it is replace it time
Posted on Jul 15, 2015
Necesito codigo dish para amplificador philips MCM704D
Hola Rodrigo! Mi nombre es Kimberly Escobar con DISH Network. Estoy aqui para responder cualquier pregunta sobre DISH Network que tenga. Tenemos ciertos codigos que pueden ser integrados a su control para que funcione con su amplificador. Aqui tiene nuestra pagina web la cual provee ayuda y detalles en como programar el control y los codigos, este es el link a seguir http://www.dishnetwork.com/SupportSection/remote-setup. Si tiene preguntas adicionales o necesita mas ayuda puede contactarme directamente a mi correo electronico kimberly.escobar@dishnetwork.com seria un placer asistirle.
Nov 03, 2011 | DISH Network IR Remote Control
Mi impresora es una canon mx 300 multifuncional pero al tirar la impresion truena como si fuera el rodillo pero no se que es-... porfis si alguien me puede ayudar.... mil gracias!!!
Pardone jo ablo frencais o anglais y un pecito espangol, but what I undrestand is that the printer make a noise when printing??? if that is the case, you should look for debri stuck in the mechanisme (peace of paper) it could also be a worne sway plate gear
hasta la proxima amigo!
Mar 10, 2011 | Canon Office Equipment & Supplies
Unlock huawel modem ce0682
how do i unlock modem ce 0682
Feb 07, 2011 | Computers & Internet
La camara de mi movil desaparecio
En primer lugar tener una tarjeta de memoria si tiene una en su tel?fono y luego apagar el tel?fono. Reinicie el tel?fono sin la tarjeta de memoria en el tel?fono e intente de nuevo la c?mara. Si esto no funciona entonces le sugiero que visite nuestra p?gina de Motorola Software Update para ver si hay actualizaciones para el tel?fono. Copia de seguridad de su informaci?n al ordenador mediante Microsoft ActiveSync o Windows Mobile Device Center para asegurarse de que no se pierde ninguna informaci?n durante la actualizaci?n. Maestro lo Perd? mi realmente el ?ltimo recurso si no otra cosa se puede resolver, pero en este caso, tambi?n aseg?rate de que tienes todo lo que una copia de seguridad como toda la informaci?n se perder? desde el tel?fono.
Dec 16, 2010 | Motorola Mobility Moto Q
Como programo la caja del dish
Hola mi nombre es Mayra Diaz con DISH Network con mucho gusto le puedo ayudar a programar su caja de DISH. Si por favor me puede dar mas detalles de lo que pasa como el modelo de la caja, es un recibidor nuevo? Ya teniendo estos detalles le puedo asistir con un mejor conocimiento.
Aug 04, 2010 | DISH Network IR Remote Control
Mi Equipo de sonido KENWOOD modelo UD-551M se apaga solo...
hola mi equipo kenwood ud551m tiene averiado micro funciones del amplificador donde lo puedo conseguir al componente gracias ana desde uruguay
Sep 19, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Mi camioneta ford f-150 no me le trabaja el tablero y tira los cambios muy brusco como si algo de la caja no esta funcionando bien. Por favor si ahy otra persona que le alla pasado lo mismo que me diga...
yo tuve una experiencia con una f-150 en mi taller que hacia cambios bruscos de velocidad sobre todo empezaban a correrla y tambien paracia brincarle las velocidades cundo se frenaba pero nada con el tablero y en mi scanner detectaba fallas en los solenoides de la transmission y resulto derivado de que otro mecanico le habia efectuado un tune-up y le dejo el harness que corre desde el conector en la pared de fuego de el ladop del pasajero debajo del hood a la transmission,entonces creo que podria ser un caso de corto circuito muy similar
Aug 02, 2009 | 2006 Ford F-150
Accord 1981
Help to find a manual on 1983 honda accord, for engine major repairs.icon_confused.gif
Jun 27, 2008 | 1983 Honda Accord
Pioneer M10X 2-Channel Amplifier Logo
74 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
