Question about Frigidaire ATF6000ES Front Load Washer
Front loading washer basket is loose and pump is making noise
When washer is on it sounds like there is something loose in the drum and the water removal pump is very loud
  • 30 Answers
The loud sounds you hear when the washer is on is coming from 5 possible sources 1. unbalance wash load, 2. a washer that is not level, 3. a broken agitator, 4. a blockage in the water pump, and 5. a worn transmission.
Solution, balance your load, level your washer, removed the hoses from the water pump to remove any blockage. If these solutions don't solve the problem contact a service provider to service your agitator and or your transmission.
Good luck
Posted on Aug 06, 2008
SOURCE:
My maytag front loading washer door sounds Iike there is a loose bell inside..has something come loose?
I had somewhat of a similar problem. What I found was that over time you have coins and other things that get into a washer. These items are than pulled into the drain pump. Most drain pumps have a basket that collected these items. In fact they can get into the pump whereby you will get a lot of noise and this pump is located very close to door (just below it toward the front of the machine). Before starting this operation disconnected the power and turn the water off and take the bottom front panel off and you will see a large white nut. Unscrew this large nut and this will display the screen for catching the loose items in your pants pockets. Clean this and you should be in luck
May 19, 2012 | Maytag Neptune MAH5500B Front Load Washer
My washing machine is making an awful noise when its changing direction on the drum motion and changing programme. its sounds very much like some sort of ball baring has come loose. - what doi I do please...
put the machine onto drain position if it still makes the noise it is something stuck in the pump check and clear filter if makes noise only when drum turning then is highley suspect bearings have failed.
Jun 02, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Hi
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Loose washer drum, load noise on spin cycle
your basket hub is stripped and to gain has a specific tool to remove and not destroy the locking nut for basket the agitor and items need to be removed it may be best to call a tech in your area
Sep 01, 2009 | Kenmore Washing Machines
Maytag Epic Z Washer has object between drum and tub.
I had the same rattling during spin cycle of my Maytag 4000 series front loading washer. Noticed you could gently pull back on the rubber gasket between the tub and where the door seals. There was a quarter resting against the fixed ring the tub spins in. Problem solved. And I have further realized that long hair can build up in this same spot. But if you didn't know to pull back on the gasket you wouldn't see it. Good luck!
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Front load washer makes funny noise when pump turns on
The pump sounds like it may be plugged wih a coin or something like that. If the pump is plugged it will make a funny noise. Remove the pump and clear everything out of it
Jun 07, 2009 | Frigidaire Affinity ATF6000F Front Load...
Clicking sound.....
must likely something in between drum & basket or rear bearing going bad.call sears ask for service smart agreement it will cover rear shell with bearing &basket in warranty
Nov 13, 2008 | Kenmore Elite 45986 Front Load Washer
Noise sounds like loose change or screws.
You probably have something in your pump. Remove the lower front panel (3 #20 torx bit screws) In the bottom, middle there will be a large white pump. I usually remove the screw holding it in so I can get the edge of a bucket underneath it. Once you rotate the knob in the centercounter-clockwise and the water drains out, remove any forign objects.
Jun 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
57 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
