Question about Dual Electronics XDM6350 Car CD/ MP3 Player
When I connect my usb to my ipod it just says "reading"..
  • 12 Answers
ANSWER:
The USB is not going to work with your iPod. It is intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files.
REASON: The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer.
Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
SOLUTION:
You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
Good Luck!
- Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Posted on Jul 28, 2011
  • Fo Bu
    Fo Bu Oct 07, 2013
    You always post the same answer and it doesnt answer the question at all. The cd player is flawed. It used to work with my usb driver with 12 songs (and nothing else on it). All of the sudden for no reason it doesnt go into usb mode at all unless you stick a usb in. and it says reading forever and never stops.
I have a white apple ipod. Model a1136 (30gb) which i am having a problem connecting to the computer. When I try to connect it, it reads "One of the USB devices attached to this computer has...
Believe it or not, many people have resolved this issue just by unplugging (from the wall or the power supply, doesn't matter) the PC for 15-30 minutes. (This allows all the capacitors on the motherboard to fully discharge) If you have a laptop, unplug it and remove the battery.
If it only happens with the iPod and no other USB device, let the iPod drain down completely and plug it back in.
Other things to try: A new USB cable Uninstall ALL the USB ports from the PC via Device Manager and reboot.
Jun 29, 2011 | Computers & Internet
Tip
Connecting an iPod to a receiver
<p>People with a home theater to understand the importance of a receiver. The receiver serves as the centerpiece of a home theater or audio system and controls the various signals from a central location. With a receiver, you can use certain parts of your system, some minor changes to switch between different components. Connect an iPod to a receiver on your iPod data on your home theater or audio system. <br /> <p><br /> <p>1. Green Plug the AV cable to the "Y" port of the receiver, plug the blue "Pb" port of the receiver and plug in the red "Pr" port of the receiver. <br /> <p><br /> <p>2. Insert the white audio jack in the "left audio" red door and audio connectors for "right audio" port of the receiver. <br /> <p><br /> <p>3. Connect the dock connector cable for iPod. Plug the USB into the USB adapter. Connect the USB adapter into an electrical outlet to power is to keep your iPod without draining the battery. <br /> <p><br /> <p>4. Disconnect the iPod and the receiver. Browse your iPod to the media you want to see or hear through the receiver to select. You can watch videos on the screen you have connected to the receiver and hear the sounds through the speakers you have connected to the receiver. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How do I connect multiple iPods to One Computer
<p>Suppose you have more than one iPod that you want your computer. Or maybe you have two people with the same computer, otherwise synchronize their iPods. There are a few different ways to go about it. Windows and Mac OS you can run multiple iPods with USB cables and your music library to open. But you can use these methods to various media files to synchronize multiple iPods. <br /> <p><br /> <p>Create separate iTunes libraries <br /> <p>1. Keep the "Options" key while you open iTunes on your computer, if you use a Mac the same way, hold down the "Shift" key while you open iTunes and Windows. This will be a new dialog. <br /> <p><br /> <p>2. Click on "Create Library". Name the new library and save it. iTunes will open this new library you created. <br /> <p><br /> <p>3. Open "Preferences". Do this by selecting "iTunes" and "Preferences" on a Mac, and "Edit" Preferences "in Windows. Click the" tab "Advanced. <br /> <p><br /> <p>4. Check the box next to "Copy files to iTunes Music folder when adding to library." Click "OK". This will ensure duplicate files are not included in your new library. <br /> <p><br /> <p>5. Add the files you want to add in your new library, which are the files you want to go to your second iPod. To do this, drag the files from your hard drive in iTunes. You can also choose "File" and "Add to Library". Add to your library until you see the way you want. <br /> <p><br /> <p>6. Connect your iPod to your computer via USB. Sync your iPod to your iTunes library. Quit iTunes once the synchronization is complete. <br /> <p><br /> <p>7. Repeat step 1 to re-open iTunes. Select "Choose Library". Now your original or the new library you created to switch between the music from your iPod library. <br /> <p><br /> <p>Create separate user accounts <br /> <p>1. On a Mac, select the Apple menu. Choose System Preferences. Select the "View" menu and select "Accounts." Click the "+" to create a new user. Connect your iPod to iTunes and sync with this user. <br /> <p><br /> <p>2. In Windows, click the "Start" button. Go to the Control Panel. In "User Accounts and Family Safety", select "Add or Remove User Accounts." Click on "Create a new account." Connect your iPod to iTunes and sync with this user. <br /> <p><br /> <p>3. Log off your account and to switch between users. This way you can sync your iPod separately for each user. It can be useful if multiple users have different tastes in music. They may have their iTunes libraries and iPods. <br /> <p><br /> <p>Sync iPods with different playlists <br /> <p>1. Open "iTunes". Create multiple playlists to be synchronized with each of their iPods. For example, you can create a playlist of workout you just upload to your iPod nano, in turn, allows your entire library on your iPod touch. <br /> <p><br /> <p>2. Connect your iPod via a USB cable. You can do one at a time or simultaneously on a Mac Windows does not support synchronization of more than one iPod at a time. <br /> <p><br /> <p>3. Click on the first iPod in "Devices". In the "Music", select "Sync Music." Select "Selected playlists, artists and genres." <br /> <p><br /> <p>4. Click Apply. This will start the synchronization process. Repeat this process for the other iPods. <br />
Tip
How do I use my iPod With an HP TouchSmart
<p>The HP TouchSmart PC is a common computer, except it has a touchscreen. This allows you to tap the various icons on the screen for games, applications, and download files, and open your iTunes. Using an iPod with your HP TouchSmart PC is like using your iPod to another computer or MacBook. However, instead of using a mouse to navigate through your iTunes library, you need to tap your finger, or "click" on the items you want to open and upload to your iPod. <br /> <p><br /> <p>1. Turn on the computer end of the USB cable into USB port of your TouchSmart. The end of the computer's USB cable is the smaller of the two sides. <br /> <p><br /> <p>2. Connect the other end of USB cable to the bottom of your iPod. Normally, when you connect your iPod to the TouchSmart PC, iTunes opens automatically. If it does not open, tap the iTunes icon on the screen of your desktop to open the application. <br /> <p><br /> <p>3. Tap "File" at the top toolbar of iTunes. Select "Sync iPod" to upload music, photos and even files from your iTunes library to your iPod. <br /> <p><br /> <p>4. Select the "Eject iPod" icon in "Device: iPod" on the left side of the screen. This will allow you to safely remove the USB cable from your iPod and TouchSmart. <br />
Tip
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
Tip
How can I use my iPod while charging?
<p>If your iPod and it gets low on battery, you can continue to enjoy your music while charging your iPod. To charge your iPod, you can choose from one of two ways: Use a computer to add power to your iPod, or use an electrical outlet to charge the device. Either method will allow you to use your iPod while charging. If your iPod is so low that it does not turn, you may need something to load before you can use while charging. <br /> <p><br /> <p>Charging the iPod using a computer <br /> <p>1. Connect the USB cable to your computer and connect the other end into the iPod port. <br /> <p><br /> <p>2. Make sure your computer is on and not sleeping. <br /> <p><br /> <p>3. Open iTunes and choose the iPod that you connect to the source list to access the settings to get the iPod. <br /> <p><br /> <p>4. Open the menu "Options" and "Manually manage music" checked. If you change the settings to manually manage music, iTunes lets you listen to your iPod while it is connected to the computer and load. <br /> <p><br /> <p>5. Click "Apply" manually manage music, then use the iPod as you want on your computer while charging. <br /> <p><br /> <p>6. Eject the iPod once it is loaded by pressing the 'Eject' button in iTunes. Remove the USB cable from your computer and iPod. <br /> <p><br /> <p>Charging With USB Adapter <br /> <p>1. Connect the USB adapter for the iPod and an electrical outlet. <br /> <p><br /> <p>2. Continue to use your iPod as you want while charging through the USB adapter. <br /> <p><br /> <p>3. Unplug the USB adapter and plug the iPod and the iPod is charged. <br />
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
Tip
How do I Transfer Applications From an iPod to iPod
<p>Apple iPod Touch media player allows applications of the iTunes App Store and download applications on the device. If you prefer, you can synchronize these applications with the application iTunes media management, and here, shopping for another iPod touch in a few easy steps. <br /> <p><br /> <p>1. Connect iPod touch to your computer through the USB cable that came with the device. Double-click the iTunes application icon to start the program. <br /> <p><br /> <p>2. Click the iPod touch, listed under the "Devices" section and select "Transfer Purchases" option from the context menu. Allow several minutes for all applications downloaded to the iPod touch through the computer. <br /> <p><br /> <p>3. Click the 'Eject' button next to the iPod touch under the "Devices" section and turn off the iPod touch to your computer. <br /> <p><br /> <p>4. Connect the iPod touch in the second computer through the USB cable. Click new iPod contact listed under the "Devices" section. <br /> <p><br /> <p>5. Click on "Applications" tab and place a checkmark next to "Sync Apps" option. Click the "Apply" to apply the changes and synchronize applications to the iPod touch second. Wait a few minutes to sync process is complete. Once it does, and the computer a message, click the "Eject" and remove the iPod. <br />
on Aug 05, 2011 | Apple iPod touch
Tip
How do I update my iPod Touch updated to 3.2
<p>Apple iPod Touch is a touch-screen iPod that contracts with the iPhone and iPod parts. To update the iPod Touch, iPod Touch you have to program a computer running iTunes 3.2. Update the iPod Touch is free and takes only minutes. <br /> <p><br /> <p>1. Connect the iPod Touch to your computer using the USB cable that came with the iPod Touch. <br /> <p><br /> <p>2. Let iTunes opens automatically when the iPod Touch is connected to the computer. <br /> <p><br /> <p>3. Click the name of the iPod on the left side of the screen. If the iPod does not have a name, it will read "iPod". <br /> <p><br /> <p>4. Click "Sync" in the lower right corner of the iTunes program. Disconnect the iPod Touch during the synchronization process. Progress, looking at the status bar at the top of the iTunes program. <br /> <p><br /> <p>5. Disconnect the iPod Touch as the synchronization is complete. You said that the synchronization is complete by reading the status bar at the top of the iTunes program. He will tell you that it is now safe to turn off your iPod Touch. <br />
on Aug 05, 2011 | Computers & Internet
Tip
How to unlock the iPod Touch, if you forget the password
<p>The screen lock is available on the iPod Touch, as well as recent models of the iPod and iPod Nano, giving you a 4-digit password to set the screen. This is to prevent others from using your iPod, but it is not a safety device impregnable. If you forget the password, you can quickly and easily unlock the iPod by connecting it to the computer you normally use to sync your iPod with iTunes. You can then open the iPod and reset the lock to a more memorable password. <br /> <p><br /> <p>1. Connect the iPod Touch to your computer via the USB cable. <br /> <p><br /> <p>2. Wait for iTunes to access and synchronize with your computer. <br /> <p><br /> <p>3. Take your iPod Touch from your computer, clicking on the "Eject" to the input side of the iPod under "Devices" in iTunes. <br /> <p><br /> <p>4. Disconnect the iPod Touch from the USB cable. IPod touch will turn on and will be available. <br /> <p><br /> <p>5. Tap the menu "General" on the iPod Touch. Tap "Passcode Lock and tap either" Turn off access "or" Change. "When you click" Change Password ", you can create a new password. <br />
on Jul 21, 2011 | Computers & Internet
Dual Electronics XDM6350 Car CD/ MP3 Player Logo
142 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
