Question about Marshall MG 50
I am trying to get inside my marshall MG30. I have removed all the screws and the top handle, put the back still won;t come off. What is the correct procedure for getting inside the amp.
  • 7 more comments
  • Nicolas Rowley Apr 09, 2011
    Just to clarify the problem with my Marshall MG30 (not MG50 as the FixYa heading says):
    I have removed the 4 long screws with washers from the top of the cabinet, and the carrying handle. I have also removed all the screws from the back panel.
    However, I cannot removed the back panel - it seems wedged tight and even moderate leverage won;t move it. And the gold panel at the front of the combo containing the pots and switches does not come out either. it moves slightly backwards if pushed.
    In other words, I can't seem to get at the amplifier OR the speaker.
    Would be very grateful for advice on how to get the gold panel/amplifier out and how to get the back off to see the speaker.
    The amp is a MG30FX with a solid back panel. The speaker is not visible.
    Sorry but there may a confusion here. It's a Marshall MG30FX. The back panel is solid and has nine screws. There are 4 large screws on the top. Even with the screws removed it is impossible to remove the back and impossible to move the gold front panel ...
    Sorry man - I saw this on the web as well but it doesn't help. Even with the top screws removed, the chassis simply won't move forward or back. That's the point; even with the screws removed everything apparently immovable,. What exactly do you do or where do you push to get the chassis out? All best N
  • Nicolas Rowley Apr 10, 2011
    A mini jack broke off at the tip in the headphone mini jack socket. Can find no way of removing it without getting inside. Obviously no output from amp until get broken part out
    yes that is a good trick but it's a mini jack socket and it's only the tip of the jack that has broken off so hard to get enough 'purchase' ro remove in this way. Have you got experience of disassembling an mg39fx? All best. N
    Thanks man. Am working this aftenoon but will try when get back to studio later. All best. N
    Unfortunately, none of the tips were able to get the lodged tip of the jack out, though they were great ideas. I managed to get the back off by screwing some oversize screws into some of the screw holes in the back and then pulling firmly and symmetrically. It was just VERY tightly wedged! Once inside, it is not difficult to remove the amplifier, and - as you said - there is no need to remove the knobs etc - the whole things comes out in one piece after removing three screws and and cable restraint for the power cable. Also very easy to replace without putting strain on any of the boards or connections. Unfortunately though, the headphone mini jack is a sealed unit with a resistor wired outside it, so have still not been able to remove the offending jack tip. Looks like have to replace the whole minijack assembly and wiring ...
    Really grateful for your help, and the really smart ideas.
    All best
    N
    Supertech_11 made some really smart suggestions and really thought about the problem carefully. Many thanks!
  • 1,591 Answers
First, I'd like to know why you are trying to open it, just in case you don't need to. No audio for instance sometimes is an issue that can actually be solved without opening up the head of the unit.
Give me an idea what the issue is, and I'll tell you if you even need to open it up.
Posted on Apr 10, 2011
  • 3 more comments
  • Norman Skinner
    Norman Skinner Apr 10, 2011
    Ok, here's a nice trick to try when something like that happens - get a drywall screw, and gently tap it into the broken off headphone jack shaft.
    while twisting the drywall screw clockwise, gently pull a little at a time until the headphone shaft is extracted.
    Much easier than complete disassembly, and if you make it big some day, comes in real handy when someone trips over your cord 15 minutes before a show!
  • Norman Skinner
    As I recall, that back panel should come off now (although it can stick), but to get the amp out, I think you still need to take the knobs off, and take off the retaining nuts on all the controls and 1/4 inch jacks before it slides out the back.
    I could be wrong, it's been a while since I've seen one of those, but that's what I remember at the moment.
  • Norman Skinner
    Trick for mini jack that tends to work (another road trick) is chances are there's still some plastic left in the jack tip....unbend a paperclip and heat it with a lighter.
    Quickly insert the paperclip into the jack tip being careful not to hit the walls of the amps jack itself.
    The paperclip will cool quickly and the plastic will bond to the paperclip, and you should be able to remove it fairly easily.
    Another trick is cut the end off a round toothpick and put a tiny drop of crazy glue on it, and fish the jack tip out that way.
    Honestly though, the hot paperclip / pin trick is less likely to cause damage to the amps jack.
  • Norman Skinner
    OOH, just had a thought, that might be one where the whole chassis comes out from the frame.
    place the unit on it's face now that all the screws are out, grab it at the sides, and shake it a bit and see if the chassis comes out the front.
    If not, flip it over and see if the whole chassis comes out the back.
    I think one of these 2 will be your solution if you don't manage to get a quick fix to work.
    In fact, try this BEFORE REMOVING any of the nuts around the controls or jacks in case one of the jacks falls inside the unit.
  • Norman Skinner
    Not a problem
On my son's MG30, the input jack loosened and fell into the amp. I just opened it. To access everything inside, simply remove the 10 screws on the back panel, and then use a small (thin blade is key) flatblade screwdriver to pry off one side of the back panel. Piece of cake. There is no need to remove any of the top screws on the MG30. In fact, two of the screws on top do nothing at all and are just cosmetic.
Posted on Feb 13, 2016
  • 5,370 Answers
Refit the 2 middle large screws in the back they hold the amp onto the back then remove the 2 large screws in the top and take the whole back out backwards but hold on to the amp.
First of all remove the back panel (four simple ph2 size screws). Then remove the four black ph2 size screws from the TOP of your amplifier (make sure you remove the correct screws, not those that holds the plastic protectors on the corners). Gently pull out the metal bracket but don't do it too hard, because you might damage the speaker cable. Now you can see all the inside components.
The input jack is soldered into a circuit board.So pull it carefully.Its easy to break.----------
Check out.Keep updated.Thanks.Helpmech.
Posted on Apr 09, 2011
  • raj somaiya Apr 09, 2011
    Ok, on Marshall MG30FX the back is not removable.the back panel is not removable, as it is part of the chassis. You must remove the entire chassis to get the the guts. The chassis is made from heavy tin sheeting, and the front & rear panels are folded-up, and the top is open except for a "lip" where the top screws hold it. The front is annodized in brushed gold, and the bottom & back are painted black. There are scews in the top that hold it in place, then the entire chassis slides out through the back of the cabinet.----------- this should help.thanks.Helpmech.
  • 635 Answers
If you notice on the top of the Marshall MG30 on either ends of the box there are 2 screws on each side with a ring washer. These are long screws which hold the amplifier. The amplifier above the speaker is suspended by this screws ( 4 in all ) . When you unscrew make sure the MG30 is lying on its face down or the Amplifier module will fall on the speaker when you unscrew the 4th screw.
Disconnect the speaker cable and gently pull out the amplifier.
  • 3 more comments
  • Jacob Paul
    Jacob Paul Apr 09, 2011
    Remove the screws shown by the red circle. You have to view it from the top . Could not get a top view picture.4 screws in all.
  • Jacob Paul
    You don;t have to remove any other screws other than the one marked by the red 0.
    If you remove the other screws the box might fall apart !!
  • Jacob Paul
    Remove the screws marked by the red 0 in the picture. You have to view the MG30 from the top. Could not get a top view picture.If you unscrew any other screws the box my fall apart !!!.
  • Jacob Paul
    If you have a solid back model hold two knobs in the two ends of the front panel and pull out towards you. In the picture shown the Amp module has to be pushed from front to back. In your model from back to front.
  • Jacob Paul
    If its a MG30 there are 5 screws in all on top and not 4 as mentioned before
Had lots of buzzing coming from the back of Marshall AS50D. Removed the back cover and buzz gone. Any problem with leaving back cover off? Warnings on the back say not to remove the cover!
It was probably just loose screws and the cover was vibrating. Reinstall it and check that the screws hold in tight. If they're not, fill them with glue and some toothpicks, redrill the holes (the bit has to be as thick as the center of the screw, so that just the threads dig into the wood) and reinstall the grill.
If the vibrations persist, that means something else is loose. Try first with the screws that hold the metal chassis. Check for loose speakers, too. Then try the screws and nuts that hold the transformer, PCB, etc. These should have thread locker and not be loose, but if they are, clean it well with thinner and reapply some thread locker.
Only do this if you have experience and know what you are doing, and the safety precautions you have to take. Don't think you know, read safety precautions when working with electric equipment. The safest bet is to take it to a tech.
Also, removing the cover changes the sound of the amlifier. It should sound more bassy. It doesn't have tubes, so it shouldn't be a big deal, except that you should keep it for resale.
Jul 22, 2017 | Marshall Music
How do i remove chassis from marshallmg50dfx
You should see four screws on the top (not the ones that hold the corner protectors) - these are large Phillips screw tops. Remove the screw and put the amp on its side and remove the chassis from the back (there may be a back behind the speakers you need to remove first).
Apr 09, 2014 | Marshall Mg50dfx 50-Watt Combo Guitar...
How to fix an output jack for a marshall mg 100 fx. Came loose and is inside the amp
You have to remove the amp from the case. These jacks are JUNK and it likely will have to be replaced. In any event, the amp has to come out to work on it. Several screws in the case and OFTEN the screws holding the handle. Be careful of the speaker leads.
May 23, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
My marshall mg100 combo took a spill now the front of the input jack came off and the jack itself fell back inside the amp. I don't want to just start unscrewing stuff. whats the proper procedure to get...
Yep! These poor quality jacks become "unriveted" and break in half. This is a fairly common occurence. Don't be afraid to unscrew stuff. USUALLY the corner protector screws are NOT necessary to take out. OFTEN the screws for the handle need to come out and any other screws from the top and the sides in the vicinity of the amp portion need to come out. Just keep track of where they go. The jack MAY be a part of the circuit board and you will need to get an exact replacement. NOTE: If it is mounted on the circuit board do NOT overtighten the panel nut as that can "de-rivet" the brand new jack !!! They are really poorly made...
Apr 06, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Okay i need to know how to get inside my amp to tighten up my input jack cause i cant play at all on my amp cause i cant get inside it i took off all the screws in the back and trying to get it off is a...
One can overtighten the input jack and "un-rivet" the jack. They are not made very well !!! OFTEN when they appear loose, they HAVE un-riveted the threaded sleeve from the metal inside the jack... that USUALLY requires REPLACEMENT of the jack itself.
The cabinet backs on a lot of these have to be PRIED out as the Tolex covering often makes them tight.
The amp portion is often retained by screws from the top and or sides AND even the two holding the handle on... there are many different configurations. Sometimes the amp comes out the front, sometimes the back. It is easy to shear off the speaker wires when removing some of them.
Dec 18, 2010 | Marshall 15 Watt Guitar Amp
The fan on the back of my marshall mg 100HDFX is making a weird noise when i first turn it on. It eventually sounds normal after about three minutes. Im not sure what i need to do?
You can either oil it up OR replace it for around 20$
Both ways involve removing the amp from the casing by unscrewing the 6 screws on top and sliding it out and then getting the fan out
locate the fan; locate the 4 outside screw covers that are next to the fan grill screws and pop them open. Remove the four screws that are under those plastic covers. The fan should separate. Take Fan out and remember how it was in there.
To oil: lift the sticker and locate the rubber plunger in the middle of the fan; remove it. Then, put ONE drop of regular 3-1oil NOT-wd-40, pb blaster or bike lube. re-assemble
To replace: just unplug old fan and then replace with new fan. I recommend replacing the fan when it gets to the point of bearing noise because oil doesn't always fix this.
Oct 02, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Want to take it apart
Usually there are screws, sometimes including those holding the handle that support the amp. Sometimes there are a couple from the sides... USUALLY the corner protector screws are not involved.
Hint, the amp is easier to handle and remove by setting on the side.
Jul 18, 2010 | Marshall MG10CD 10 Watt Combo Amplifier
Power switch replacement
Some of the rocker switches can be PRIED out from the outside as they have plastic "springs" at the ends... look at you new one.
IF you can pry the old one out you MAY have long enough wires to allow the old one to come out a bit and transfer to new one and push it back in.
ELSE you have to take the amp out.
USUALLY the speaker and the board it sits on remains in the cabinet.
There will be screws that hold the amp in... You kind of have to try to find which to remove to release the amp chassis. You may have to remove the speaker wires or wires to a reverb tank... MARK ALL these and restore to exact same places.
HINT: Once the screws are out, OFTEN the Tolex cabinet covering loves to catch on the chassis so you have to fight to get the chassis out... a real pain and THEN putting it back in the Tolex fights you again !!!
Dec 15, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
I need the schematics for a Marshall MG30DFX guitar amplifier in order to repair it.
If you still want the schematics for the Marshall MG30DFX Steve I have them and can email them to you if you want
Dec 10, 2009 | Marshall Music
Marshall MG100 DFX manual
If you just bought it new, Marshall will replace any parts, or the store you got it from. If its second-hand I would have a look on ebay for parts.
The user guide can be found here...
http://www.marshallamps.com/product.asp?productCode=MG100DFX&pageType=DOWNLOADS
Good luck, its a sweet little amp!!!
Feb 13, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall MG 50 Logo
2,502 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
