Question about JVC XL-SV22 CD Player
Can you confirm the key change in fact slows or speeds up the disc very slightly
    Brigadier General:
  • 8,546 Answers
Logically, it would have to change the disc speed or the read cache would eventually over- or under-flow.
CD rotational speed is always varying to provide a constant linear velocity as the playback radius changes even without Key Change.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-XL-SV22BK-CD-Players-manual/id/313ag925/t/2/
Posted on Apr 09, 2011
Turns over slow, backfires , then starts.replaced battery, starter is ok. replaced plugs. what else?
If the unit runs normally after it starts it is probably a defective coil that isnt changing timing relative to crank speed. It is running advanced even at slow speeds and that is the backfire. You could also have a slightly bent flywheel key. This is what sets the primary timing so it is always a good idea to check it when you have the engine cover off!
Jan 25, 2013 | kawasaki Garden
2003 rav 4 2 ltr petrol changed front discs and pads now have lots of high pitch noise have taken apart and used lots of copper slip and its still happening talked to local toyota garage who said i mave...
someones trying to pull your chain.....the pads fit both sides of the disc(rotor)BUT if the discs were scored then the noise is the pads trying to bed into the scores/ridges....if you can feel a ridge of more than 1mm on the outer edge then you should replace the discs.(dont bother to undercut)then you would have no noise at all.as a matter of interest the front discs last no more than 30.000 miles.fact...unless you use the gearbox to slow down and not the brakes.then 40.000.
Sep 18, 2010 | 2003 Toyota RAV4
Playing podcasts fast
With podcasts on the ipod touch you can vary the speed of play. From normal speed to 1.5 times, 2 times and half speed. Just under the play indication is a button which is probably reading 1.5x or 2x press this button and you will be able to change the speed back to 1x. Hope this helps.
Mar 18, 2010 | Apple iPod touch
I have a vision fitness T9450 treadmill. My wife was using it and it slowed to 2mph. That is all the faster it goes now. Elevation controls work fine and everything else functions.
first thing to do is to enter the calibration mode. First remove and replace the safety key. Press and hold the elevation up and the speed down buttons until the machines beeps at you 3 times consecutively. You should also see either the model "9450" or the software code which varies from machine to machine. You should now see one of two things - "eng1" may be displayed in which case just use the elevation keys to get to "eng4" and hold enter for 3 seconds - then press start - this will calibrate your machine and confirm if there is any speed reading issues.
If your machine displays more numbers as it would on the deluxe and premier consoles of this brand then you should see the model of your treadmill at the top left. hold enter from here until "eng1" appears and the perform the steps as above. If the speed is not calculating properly during the calibration the magnet or the speed sensor may have been moved or the magnet could have gone bad - usually slowing to one speed and not changing is the sign of a bad speed sensor. If the control board had any irregular voltage it would shut down as a safety precaution.
Feb 06, 2010 | Dmm Vision Fitness T9500 Treadmill
I get a better connection speed on the wireless pc then the pc connected directly to the router. Why is this.
There could be several reasons why this is, but the most common one is that the computers adapter can only handle a speed that is less than the wireless adapter card, so it would seem that the wireless connection is faster, but I need to confirm this. What is your computers manufacturer and model, and what is your laptops manufacturer and model? Or it could be that the laptops clock speed is faster than the desktops, making it seem that the hard wire is slow, when in fact it may just be the computer.
Ryan Frame
Creative Energy Associates Technical Center
Nov 09, 2009 | NetGear DG834G Router
Touchpad has no tap, left key not working.
I had this issue and resolved it by doing the following:
-Open the start menu by using the windows button
-Use the arrow keys to highlight run and press enter
-Type 'control panel' and press enter, find the mouse properties and enter
-From the buttons tab in mouse properties, go to double click speed and change to slow and confirm the changes
-At this point it probably still wont work, so do the above again but change the double click settings to fast and confirm.
-Restart your PC and this should resolve the matter. you can alter the double click speed again if you wish :)
Hope this helps,
tbo
Apr 06, 2009 | ASUS Eee PC 1000H Laptop
Turntable speed
There is no pitch control on this unit.
Apr 03, 2009 | Intellitouch Communications INTELLITOUCH...
No read no write
One possible source of difficulty is there are different blanks for "slow" recorders (1x - 4x), "high speed" recorders (4x-10x), "ultra speed" recorders (12x-24x), and "ultra speed +" recorders. The disc manufacturers had to change the way the discs were made to accommodate each successive improvement, so older recorders don't work with the newer disks.
It is possible for some 4x-capable "slow" drives to use the "fast" blanks with a firmware upgrade, but there is no advantage to doing so since you're still limited to 4x recording (unless, of course, you're unable to find "slow" CD-RW blanks).
CD-RW discs for the faster drives are labeled with a "High Speed", "Ultra Speed", or "Ultra Speed +" logos. Make sure you buy the right blanks for your drive.
Jan 15, 2009 | LG (GCE-8527B) CD-RW Burner
JVC XL-SV22 CD Player Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
