Our home central air conditioner system will not run. The thermostat is indicating a (- AC) on the screen.
  • montereykh Apr 09, 2011
    Thanks for the info. The fuse on a circuit board inside the interior unit was blown 5amp.
    I replaced it and the new one blew. Whats next?
  • montereykh Apr 11, 2011
    Thank you for the help, I have not found the actual short yet.
    I will post the results when successful
  • 1,420 Answers
Ok, I need to make sure that the power to the outside unit is on both at the breaker panel as well as at the outdoor disconnect.While you are checking, make sure the power is on to the indoor unit. Now make sure the filter is clean to allow air circulation. If the thermostat is calling for ACt, the fan at the outside unit should be spinning. if you hear just a humming, take a stick and see if you can spin the fan. It may be rusted and not able to spin. If it still won't spinn and you cannot hear a hum, check the fuse in the air handler unit. It may be located on the PC Board or in-line of one of the wires. If still no luck, time to call your local AC tech.
Posted on Apr 09, 2011
  • Chandler Ede
    Chandler Ede Apr 10, 2011
    If the internal fuse keeps blowing, you either have a short in the wiring or a bad thermostat.
    Master:
  • 324 Answers
It sounds like your thermostat is calling for AC. Since we are just coming out of the winter months, there is a list of things you need to check:
1- Make sure the breaker in your panel for the AC unit is on.
2- Outside where your A/C unit is, there is normally a power cutout or breaker. Make sure it is on.
3- On your thermostat, make sure that the fan is set to ON and not AUTO or OFF.. AUTO is in most cases reserved for the furnace.
4- Make sure your furnace/oil burner is still on, (not running, just that it still has power) and the emergency switch and breaker is also on. The fan/blower is interlocked through the furnace, and usually powered on the furnace circuit.
-If you still do not have A/C, let me know and we will follow through. 99% of the time, it is one of the above.
Thank you for using FixYa
Posted on Apr 10, 2011
Not sure what type of thermostat to hook up to run it
Hello, most programmable thermostats will work with your unit. Honeywell and white rodgers makes good quality thermostats. Here is a link to some thermostats....http://yourhome.honeywell.com/home/Products/Thermostats/
Apr 02, 2011 | Ruud Central System Air Conditioner
My lux TX1500a home ac thermostat unit is ''locked'' help !!
you press Next, Next, Next, Hold. This locks and/or unlocks the thermostat. I had the same problem but found the manual online.
May 18, 2010 | Heating & Cooling
Tempstar phad42n1k1 heaters come on in ac mode and compresor or fan wont run in heat mode. was able to make heatpump go in defrost mode and compressor runs.
sounds like u have the thermostat wired wrong or bad wires i would check that first make sure you have the wright thermostat
Jan 05, 2010 | Ruud Central System Air Conditioner
I want to connect 4 ton central ac to mobile home I have a license to connect ac units, but I have never done one in a mobile home. I have learned the hard way that things are done differently in homes...
does the mobile home have a modular duct system? i have converted a mobile home from a split system to a package unit and all i did was wire the package system outside 240v and 24v thermostat and we connected the existing ductwork that was in the house already to the package unit . not really sure about the code because we didnt have any requirements but it runs like a champ ..
Dec 08, 2009 | Heating & Cooling
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Nov 07, 2009 | Ruud Central System Air Conditioner
Goodman CK30-1A Central AC Unit will not run by thermostat
double check your t-stat wiring your not getting 24volts to the contact at the cond. unit outside
Jun 20, 2009 | Heating & Cooling
My york central air condenser keeps running. It cools but, it just keeps running.
Some possible problems..turn thermostat where AC compressor should not run. measure lo voltage to the contactor in the compressor housing. If there is voltage there then thermostat is defective. Remove one lead of lo voltage at contactor. Compresor should stop. If not contacts are stuck. Replace or burnish contacts..
Apr 27, 2009 | Samsung AW0503B Air Conditioner
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Central air
Most thermostats have a setting for the fan called, "manual". That keeps the fan on continuously. The electronic thermostats can fail in a "fan on" condition. That would require a new thermostat. I also saw one air conditioner with a fan relay welded "on" by electrical surge. That would require a new relay.
Jul 20, 2008 | LG LWHD1800R Wall/Window Air Conditioner
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
