Question about Craftsman 3000 PSI 28 GPM Honda Powered Pressure Washer
I have a Brute 3000 power washer with a MTP pump 020303. While I was using it, the water became milky and the sound of the pump changed. Now, it only sprays water for a few seconds, quits - like it's lost it's prim, then will shoot water for a few seconds again - not a consistent stream with any power to get anything done. Where do I begin - I assume the pump seal is blown? Where do I go to get an exposed view of the inside of the pump with the part numbers? What all do I have to replace?
  • 2 more comments
  • dansharonhof Apr 09, 2011
    Is a Brute 300 the same as a Craftsman 300? What do I llok for as I take the pump apart, to tell me that's the part that's shot?
    Dan
    In reading your answer again, is the number stamped in the pump body or where do I find that number or a number similar to that?
    Dan
  • dansharonhof Apr 10, 2011
    Plate has this invformation: bar code 1167520303, Brute 3000, 2l5 GPM, model 020303, serial number 1014529462. the pump has a paper tag or label with MTP 093502 on it. As you said, I take these numbers to a sears parts store to order parts, correct? Do we have any idea as to what I order: seal, valve, entire new pump, etc.? I know you surely have an idea as to what let go or what it could be..
    Thanks
  • dansharonhof Apr 11, 2011
    I feel you have answered my questions very well. Thanks Kel.
    I didn't find any favorable comments on the Brute 3000. Seems they have a lot of trouble with the power washer pump. Motor is great - pump is not reliable.
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
It took a bit of research but I think I found the parts list here:
http://www.arkansas-ope.com/BRUTE_PW_020303.pdf (
There WAS a kit for this pump that the part number is B4182 and is no longer available. ( http://www.ppe-pressure-washer-parts.com/horizontal-replacement-pumps
The pump parts list you should be looking at is 020303-2
There are oil seal and water seal kits here: (Half way down the page)
http://www.ppe-pressure-washer-parts.com/brute-pressure-washer-020303-2-parts
You said you got a milky color then lost pressure. Until you tear it down you will not know if it is the water seals or the oil seals you need. Personally.... I was going to repair it for you I would install both sets of seals. What will be frustrating about the repair process is you usually do not get it going again on the first try. You will end up ordering other o-rings to complete the repair. If you get it by the 3rd attempt your doing great!
What may have caused this problem a lack of water supply due to a restriction somewhere. If for example there is an inlet screen to the pump and the supply line was mostly blocked the pump will cause a vacuum and draw the seals inward into the pump. ( I think this is what happened to your pump) Just make sure to check for any inlet strainers or screens. Who knows you might get lucky and just have to clean the screen / strainer.
Kelly
Posted on Apr 10, 2011
  • 1 more comment
  • Kelly
    Kelly Apr 10, 2011
    Hi again,
    I forgot to mention that you must use WHITE GREASE on all the seals when installing them. You can get white grease at any automotive parts store. They have #105 White Grease in a 3 oz tube that is more than enough for this pump.
    You asked what seals to replace.
    The unloader Kit PN 42118
    The oil seals Kit PN 2236
    The water seals Kit PN 42122
    The O-ring Kit PN 2237
    If you brought it to my shop for repair the parts above are what I would change before returning it to you.
    Kelly
  • Kelly
    Kelly Apr 10, 2011
    Check to make sure item 44 (Filter PN 1266330) of the link below is clean.
    http://www.ppe-pressure-washer-parts.com...
    Kelly
  • Kelly
    Kelly Apr 11, 2011
    Hi Dan. Thanks for the complement. If down the road you end up replacing the pump get an AR pump. It will outlast the engine! You pay more for them but... once you have had one... you have 4 letter words for all the rest of the pumps out there. This is the best pump on the market and I actually have this pump.
    http://www.pressureparts.com/ARpumps-C-A...
    I have well over 2500 hours of use time on the pump and have done nothing to it. There have been times when I had 3 workers using it for 2 straight days on 4 different occasions cleaning up mud from flooding.
    I have fixed pressure washers since the early 1970's and anytime anyone asks me what pump to buy... I tell them get an AR pump.
    Annovi Reverberi
    They all complain about the price but... 2 years down the road when they are looking for a new pump I just say... It would have been cheaper in the long run to buy the AR!
    Kelly
  • 43,501 Answers
It seems as though the pump blew internally....and if you do not know what you are looking for you may not even recognize the failed part...and there a a number of different parts that could have failed to allow the water and oil to mix...which is what happened when the white milky water came out...
To find parts you need to find the number on your unit that looks something like this...
580.762010
Then you can go to searspartsdirect.com and find the parts for your washer
heatman101
Posted on Apr 09, 2011
  • D. Floyd Kolb
    D. Floyd Kolb Apr 09, 2011
    That number would be on a plate on the frame of the unit somewhere... often underneath and out of site...
    or it will be in the paperwork or operator manual that came with the unit. But you will need those numbers to find parts...
Brute pressure washer not building up water pressure
I'd love to help but need the model #.
look on the base frame for the model # sticker.
Brute Pressure Washer replacement parts repair kits and upgrade...
look in the link for your model # to find the owners manual and replacement parts
May 03, 2014 | Honda Black Max 3000 Psi Pressure Washer
G2500vh engine problems
Hi Derek.
It is almost impossible for the engine oil to become "milky" under normal circumstances. If you have changed the oil and have used the wrong type, it may become aerated and appear milky. The only other way for water to be added to the sump is through the oil filler. I doubt this is the case as it is a neglect thing and indicates that someone has run the machine without the oil filler caps. Hopefully this is not the case, but as the engine has a low oil level sensor, it might be the reason why it wont start. It's a safety device.
There is no way that the engine oil can be contaminated by water from the pressure pump.
If you mean that the water pump oil is milky, this means that the seals have failed between the pump and the transmission. Difficult to check in a G2500. If this is the case the machine has probably been used beyond the manufacturer's intent and has overheated.
Nov 12, 2013 | Karcher Garden
Pressure washer brute
I had one to the same thing and the pump went out on the waser and you can buy a new pressure washer cheaper than the pum itself
Sep 21, 2013 | Garden
Oil milky white in pump
it may have a slow water leak inside the pump.
change oil and monitor the new oil.
if it goes milky the next time you use it then it has a bad leak and the seals will need to be
replaced,otherwise the bearings will rust & seize
Dec 18, 2010 | Honda Pressure Washer PSI 3000
What type of oil can i use
The engine and the pump can use the same oil. SAE 30 non detergent oil. No need to pay more for speciality oil. Check oil often and look for any unusual signs such as milky or foamy oil in pump which would indicate water leaking past seals. Good luck.
Sep 04, 2010 | Honda Black Max 3000 Psi Pressure Washer
What oil to use in the power washer water pump
Oil used in engine is SAE30, I would suggest adding bit of Nulon or similiar Teflon based before even first run as it will extend life of the engine, This is air cooled Honda and therefore overheat easy.
Oil used in pump is Universal Tractor Transmission Oil.
Except two, all pumps are equiped with sight glass, fill as indicated on sight glass or dipstick.
To extend life of your equipment, change oil in both, engine and pump after 50hrs.
If you live in colder climates, where freezing is possible, do not forget to drain pump and high pressure hose from water to avoid winter damage.
Hope this will help keep your equipment in top notch for years to come:-)
Jun 22, 2010 | Northstar Pressure Washer 3000 PSI
What oil do i use in the pump? The oil is milky and needs changing.
Well you can use direct recommended from Ace Hardware see link.
http://www.acehardware.com/product/index.jsp?productId=1340266
They recommend 250 hours, but i'd change more often, like you said when it's milky. If it begins to get water in the oil sooner, that indicates your piston to crankcase seal is beginning to leak.
Jun 21, 2010 | Mi T M WP-3000-4MHB Pressure Washer
Oil plug blew off top of metal housing during use
the only times Ihave seen this happen is when the pump seals were on the way out and water is pressurising the pump.the other thing that comes to mind ,you said you had just changed the oil , did you use non foaming oil? if not theoil will expand as it aereates but then it cenrerally looks milky but is does come out the breather etc
Sep 09, 2009 | Briggs & Stratton Prosumer 20324 Gas...
My Northstar Pressure Washer Pump does not boost water pressure
Pump will power up, but when I attempt to use the wand the motor sounds like it is running on one leg & blows circuit breaker----Ser# 1575551-1101 5160 Model #1575551E
May 11, 2009 | Northstar Pressure Washer 3000 PSI
Craftsman 3000 PSI 28 GPM Honda Powered Pressure Washer Logo
472 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
