Question about Gaggia Titanium Espresso Machine
Rising cycle not stopping
After many times filling up the tank the rising cycle seems that is in a loop... I had a problem with the ventilate situation wouldn't come back to normal even resetting for the factory default settings, than playing arround with the menu I've started the rising cycle, and now I'm stuck.
I've seen some comments about this problems and some people advise that could be the water flow meter if this s the case is this something I can open the machine and clean it ?
thanks in advance
  • Hockalugy Aug 15, 2008
    My Gaggia Titanium was working fine until it got stuck in the rinse cycle and now refuses to respond to the menu button. It just empties the water tank continuously.Help please.
  • 515 Answers
Did the machine stop after a while?
If it stops after a half cup of water then you have to replace the flowmeter.
When the rinsing cycle run you have to let it go to the water tank is empty and the machine **** air in the system, then you fill up with new water. If it not reset then i think there are something with the printed circuit card.
Let me know if you get your machine to run again.
/Mirran
Posted on Aug 06, 2008
I'm having problems adding gas to my hyundai elantra, it will allow me to put about $2.00 and then the pump will stop?
Your Elantra like most cars and trucks has a safety ventilated fill tank...first try pulling the gas nozzle out of your tank about one inch or two while filling at the pump...this should keep the hose from auto shut/off but be careful as you are eliminating a safety shut off...you may need to do this several times at different stops for gas until you surprisingly notice that you don't need to do this any longer...the system will eventually bleed the air out, and return to normal fill operation. Hope this helps.
Jan 21, 2013 | Hyundai Elantra Cars & Trucks
Washing machine sticking in middle of rinse and spin part of cycle
If your machine is stopping at the rise cycle, then you have a faulty cold water inlet valve/solenoid.
To verify this, turn off your hot water tap and only leave the cold water on. Put your machine on a cold water cycle. If the machine does not fill up, it means the valve/solenoide needs to be replaced.
Also note if you had water left in the tank prior to rise cycle commencing, then the drain pump is blocked.
Ash
Sep 11, 2011 | Hotpoint Washing Machines
I have an Ideal 24mini with a mega flow, I have water dripping from my discharge pipe. But the preassure gage keeps rising up even if I release some preassure freom the heating system. Iv checked the...
Hello It could be a bad/defective EXPANSION tank if it(valve) leaks when the burner is running and the pressure rises at the same time .Otherwise swap the valve as they can wear out.
Sep 21, 2010 | Heating & Cooling
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
Solis Palazzo - dreaded ventilate problem
Hi
Your machine is still in the descale mode. You haven't finished. If you have run the descaler through, the water is ermpty the pump will still keep going until it stop on its own. If it doesn't stop on its own, the computer thinks its still in the descale mode. remove the water tank and turn the machine back on. The pump will run and then make a lot of noise, then stop. This can take up to 5 minutes. Let it run until it stops. You will get blinking lights on the panel. Put the water tank back on and close the steam knob then open it again. The pump will start the rinse mode. Let it stop on its own. Computer can't see that you ran a whole tank of water, but it can see when the flow meter stops that there is no water left. If you have already rinsed the machine start the pump flowing and just lift the tank off. When the pumps stops the rinse cycle the descale light will be gone but you will have the heater light blinking and the water light steady. Put the tank back on and close the steam valve then open it again. This will clear the water light and the machine will start to heat again.
Apr 15, 2009 | Saeco Incanto Classic Espresso Machine
Fill Water tank - Ventilate
Hi Mike,
Make sure the magnet flow up, if it flow up and you still get fill water tank then you have to replace the magnet.
If you get ventilate all time, try to remove the filter and try again.
/Mirran
Aug 23, 2008 | Saeco Incanto Classic Espresso Machine
Same problem with gaggia
/Mirran
Aug 06, 2008 | Gaggia Titanium Espresso Machine
Gaggia Titanium
Do you mean the brewing unit you not can get out?
Jul 12, 2008 | Gaggia Titanium Espresso Machine
My machine was stuck on rinse cycle now on ventilate...
Try first to continue filling up the water resovoir (UP TO FOUR times) to see if the machine completes the rinse cycle on its own. If that doesn't work contact Gaggia Customer Service in the US at 888-389-4123. Sally there was VERY helpful and should be able to resolve your problem.
Dec 31, 2006 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
333 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
