PHILIPS DVD 3007. IT SHOWS NO DISC DISPLAY WHEN DVD IS INSERTED
  • 6,993 Answers
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Posted on Apr 09, 2011
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
When i plug my AV coil in my philips TV the screen goes dark
If the DVD player is playing and you have the Scart lead plugged in, check what the playback system is, Your TV is probably Composite Video and the DVD player may be set to RGB for example.
Mar 14, 2014 | Televison & Video
Have a philips pet800 portable dvd player which won,t read dvd discs.the display shows the dvd loading then after a minute it stops and displays that there is no disc
The problem is the lens of your dvd. You will see the optical lens when you open the the dvd and put the disc. Cleaning the lens of the dvd, you must be very careful, never touch the lens with your hand,Use a cotton buds to wipe the the lens gently.
May 14, 2011 | Philips Televison & Video
Philips lx3600d dvd surround home theatre system dvd player fault
when the dvd is inserted it shows up no disc so it is not loading
Jan 09, 2010 | Philips LX3600D System
Shows unformat when DVD+RW inserted
Disc need formating. While disc is in the unit press Function on the remote then arrow down to Other Function then OK button then select DVD Management then select Format disc.
Sep 21, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Philips PET710 DVD player shows 'no disc' when disc inserted
I have the same problem with my portable dvd player and found that cleaning the lens of the player using a non-alcolhol wet nap for cleaning eye glasses worked well. I also found the rail that the optics runs along while playing needed a very small amount of silicone greese applied using a Q-tip. You may find that the optic unit may be "stuck" somewhat but can be resolved by gently moving the optic along its guide using a finger.
This changed my unit from not working at all, to working intermittantly sometimes having to vary the player on and off to recongnise the disc. Hope this works
Jul 28, 2009 | Philips PET710 Portable DVD Player
No disk inserted
you could have a dirty laser lens try a lens cleaning disc. if that does'nt work you have either a bad laser or spindle motor.
Feb 13, 2009 | Philips Magnavox MWD200G DVD Player
Philips DVR model HDRW720/17 Display screen shows "Blocked"
Do you have a disc locked up inside? I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Oct 30, 2008 | Philips HDRW720 DVD Recorder
No read on all DVDs inserted
simple, lens have dirt or oil residue so just pop down to your nearest **** smith or radio shack & purchase appropriate cleaner.. test it when you get home & sure enough lens will be able to properly read discs again!!
May 20, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
