Question about Sewing Machines
The bobbin after having changed the needle and cleaning still cloggs and bunches the thread.
    Genius:
  • 1,788 Answers
It is in your top threading, make sure that you have a fresh needle in, then totally rethread your machine, Do this with the presser foot up, now pull the top thread after you have threaded it, the thread should pull smoothly, now lower the presser foot, the thread should barely move. This seats the thread in the tension discs. You should be set now.
Posted on Apr 10, 2011
Thread bunching on the bottom of My Excel 23X suggestions how to adjust
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 06, 2014 | Sewing Machines
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
Thread on the bottom side of stitch is all bunched up
1. Change needle
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
Oct 09, 2012 | Sewing Machines
The bottom thread bunches up
try changing to needle
check the top thread tension--try 3 or 4
clean under the needle plate for lint or loose threads also in bobbin area
make sure bobbin is in correctly
Aug 04, 2011 | Necchi 3620 Quilter Mechanical Sewing...
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
When sowing the thread bunches up in a ball. The inner rotary make noise, how to correct problem?
first change the needle
clean under the needle plate where the feed dogs are for lint
also clean the bobbin area for lint or loose threads
rethread the machine-top thread & bobbin
some time the top thread can come off some thread take up levers--that should be watched when sewing
check to make sure the bobbin is always wound correctly--and incorrect wound bobbin can cause sewing problems
Nov 17, 2010 | White Sewing W3300 Computerized Sewing...
I have a WHITE 3300 EMBROIDERY MACHINE and the thread bunches up at the bobbin site. I have tried a new needle, adjusted upper thread tension , changed bobbin threads and nothing helps, it keeps bunching...
Refer to your machine for cleaning the bobbin area.
You will need to clean this area often as lint and thread snips can build up can cause the bobbin feed to malfunction.
If this continues after you have cleaned the machine, the timing may need to be adjusted by a sewing machine tech.
Mar 18, 2010 | White Sewing W3300 Computerized Sewing...
Bobbin thread gets bunched up and loud clicking sound
The problem is never the bobbin when you have this problem. It's the top thread. Take the thread off the top of the machine and rethread the top. Make sure the small tension dial is on 4 or 5 (the larger dial on the front left is for the pressure on the foot, not the thread tension.) After you thread the machine, put the pressure foot down but NOT on the thread. Then pull gently toward the back of the machine. When you do, the needle should bend slightly backwards before the thread comes through the machine. If it pulls with no resistance you could simply have "fluff" or remants of thread between your tension discs. If you do, put the dial on zero and using an old needle, clean between the discs and try threading the machine again with the "pull test" I described earlier.
No tension on the top of the machine, lets the bobbin tension win and it pulls all the thread to the bottom of the fabric.
Sep 20, 2009 | Husqvarna Lily 540 and 550
Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Sep 05, 2009 | Sewing Machines
Bunched bobbin thread
Try changing the needle. If you're using the wrong needle for the type of fabric, this could happen.
Mar 24, 2009 | Sewing Machines
Sewing Machines Logo
16 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
