Question about Refrigerators
Where is the drain in the freezer? We need to unplug it, as we're getting water in the refrigerator section.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 09, 2011
Gladiator Freezerator wont stay frozen in the bottom portion. It will go to temp when temp is mved, but then start to warm up. Why?
If the bottom freezer section of the Gladiator Freezerator is thawing out the usual cause is from the coils in the back of the top refrigerator section being iced up. The ice blockage prevents the fan from circulating cold air into the bottom freezer section. These units have a design flaw due to the defrost drain freezing up preventing water from draining out from under the coil. The long-term solution is to remove the back wall of the refrigerator section to get to the coil, thoroughly defrost the coil making sure the drain tube is clear, then wrap a couple turns of #12 or #14 copper house wire around the bottom of the defrost heater element and run it a few inches into the drain tube. Advise unplugging the unit when you do this.
I've had this fix on my Gladiator for a couple years and it has been working perfectly ever since. The freezer stays a constant 0 degrees F and no more thawed out food.
May 09, 2014 | Gladiator Freezerator Top Freezer...
Fridge filling with water
OK usally this indicates that either your defrost drain leading down from the freezer has a blockage of ice, gunk or both. Unplug refrigerator and remove the rear panel inside freezer and on the back wall of many refrigerators.
I noticed you did not post your model number so I have to assume your freezer is on top above the fresh food section? If the water is trickling down the wall inside the fresh food compartment it is possible you have a small bowl that catches the water coming from the freezer and the drain line then turns and leads out of the fresh food section and down the back of your refrigerator. If yours does have that catch bowl this is the likely place for the drain line to get clogged. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrianAnd in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
If the quick movie on You-Tube is not below click HERE
Nov 08, 2012 | Refrigerators
Under the freezer is leeking to the first shelf of my refrigerator. why & what can I do Thanks
do you mean the freezer is on top and water is leaking down into the fridge section,if so most likely you have a blocked drain in the freezer.take everything out of the freezer but first unplug it or if you know where the timer is advance it into defrost or just unplug it,remove the inside back wall of the freezer and melt out all the ice with a hair dryer and the drain area,pour hot water into the hole and get a turkey baster or something that will blow down into the drain,i use a steemer to clear out the drain,keep pouring hot water into the hole and heat it with the hair dryer until the water drains down through the drain hole,also next time send the brand name and model number so i can help you better.hope this helps
Sep 24, 2011 | Refrigerators
Water is getting into the refrigerator. there is
If the fridge has the freezer on top - the problem is in clogged drain under the evaporator.Whenever the defrost cycle is activated (every 6-12 hours), the water will drain not to the drain pan underneath the fridge, but into the air vents between the sections. Depending on the make/model to get to the drain line you may need either:
  • to remove the back cover in the freezer section;
  • remove the bottom of the freezer section;
  • remove the console with controls on the ceiling of the fresh food section
  • get behind the fridge, find the drain line going to the pan under the fridge remove the drain line and clean.
Good luck.
Vlad
First Choice Appliance
Mar 13, 2010 | Refrigerators
I keep getting water in the refigerator. Everything works fine, but the water just drips and drips
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | Haier RRTG21PAA Refrigerator
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Water is pooling inside at the bottom
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section (not on all models, but this is the most common way), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups (in the top back of the fresh food section) can be removed for cleaning. A turkey buster can be used to help clean out the drain system. Fill the buster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On an S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now (Whirlpool makes many of the Kenmore branded refrigerators) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Thanks
Rylee
May 30, 2009 | Refrigerators
My ge refrigerator leaks water
During defrost cycle, the water produced is suppose to drain away through a small drain hole located behind the racks in the freezer section where you'll need to remove the rear panel to see the drain hole. This hole it very likely clogged.
Be careful to unplug the refrigerator before doing any work on it!
May 29, 2009 | Whirlpool GD2SHGX Refrigerator
Whirlpool fridge getting water from upper freezer compartment
well if you hat the freezer on top normaly air leaks inside freezer through the drain tube, that air turns into condensation and creates a ice and cloges your drain. now water can drain down to pan everytime ref goes into defrost , and water leaks to bottom section to air ducts and air returns. there are several ways to solve this problem the cheapeste way is to unplug refrigerator for 2 days then plug back up and it should go back to normal another way is to install a heat probe on your drain attached to your defrost heater , and add a grommet on drain tube that will let water drain but it will keep air out and that will solve your problem.
Oct 12, 2008 | Whirlpool Refrigerators
Refrigerator condensation
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Mar 11, 2008 | Refrigerators
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
