Question about Campbell Hausfeld Air Tools & Compressors
I have a Campbell Hausfeld Iron Force PA2123 - Pressure Regulator. It has the main air inlet and outlet. It also has ports on both sides, one is used by the pressure gauge and one is plugged. Is the plugged port another regulated outlet?
5 Suggested Answers
  • 8 Answers
SOURCE: Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Posted on Mar 15, 2009
SOURCE: air compressor needs a new hose from engine to tank
Go to the manufacturer's website and order it
Posted on Oct 08, 2009
  • 170 Answers
SOURCE: have a campbell hausfeld 2 gal. compresser
try pulling up on the cap then turn
Posted on Jan 17, 2010
SOURCE: Need new pressure regulator for Campbell Hausfeld
Friend had some pressure regulators and one of them fit. It is also a step up from a direct replacement OEM part. Thank you for your responce to my question.
Posted on Feb 01, 2010
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
WL510000
Your problem can usually be traced to the tank check valve. The valve lets air into the tank then closes when the pump shuts down and the pressure regulator bleeds off the head pressure so the motor can restart when the pressure drops to where the regulator tries to turn the motor back on. If the tank check valve is stuck open the motor has to fight the tank pressure to restart the air pump. If it can't turn over, it will blow the breaker on the motor or the breaker for the outlet you are using. The copper line from the air pump is attached to the tank check valve which is screwed into the side of the tank. Some can be cleaned to work again but most have to be replaced. You'll need C-H part number CV221503AJ or similar check valve.
Mar 20, 2012 | Campbell Hausfeld Air Tools & Compressors
1.Air leak from under plastic cover
Hi my name is John. Welcome to FixYa. Take the cover off and check the pressure switch, and outlet coming out of pump and regulator. Thanks for choosing FixYa...John
Nov 27, 2010 | Campbell Hausfeld 55 HP Air Compressor
AIR PRESSURE PROBLEM
The issue suggests that the head gasket is blown between the two cylinders or the reed valves are not seating or broken. The only other condition that would cause this is a leak. Here are a couple of simple tests. For leak spray soapy water on all connections and fittngs including the pressure regulator and the bottom of the pressure switch while unit is running. Repair as needed. If no leak is found, run compressor untill it reaches 60 or stops increasing and feel for suction at the air filter intake. The best way to check for suction is to remove the air filter and feel for suction at intake port-hole. The suction should be very strong. When valves are leaking it almost feels that the air is blowing out thru intake. If little or no suction, remove head and valveplate and replace parts as needed. Parts are available at www.chpower.com or www.toolpartsdirect.com. Good luck and post again if you have other question.
Jul 28, 2010 | Campbell Hausfeld 5HP 20 Gallon Single...
Can't find a part #
http://www.chpower.com/webapp/wcs/stores/servlet/chCat_10051_10001_10661_-1
service center, find a part. write inlet outlet valve
May 15, 2010 | Campbell Hausfeld Airless Spray Guns &...
their web site is chpower.com can order on line if not to old can check warranties also they can direct u to service location in ur area
Feb 01, 2010 | Campbell Hausfeld Air Tools & Compressors
Campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Oct 05, 2009 | Campbell Hausfeld 28 - Gallon Air...
Air Tools & Compressors Logo
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
