Question about EPoX EP-8K9A2+ Motherboard
I have EPOX EO-8K9A2+ motherboard, 20 Gig HDD, CDROM, RAM M368L1713CT1-CB0, i am trying to install windows xp professional and everytime I try installing it says there was a fatal error caused by hardware error. I tried everything I could , making both CDROM & HDD master or master & slave, nothing works. The BIOS setting are also confusing I don't know where to start looking. Please assist me
    Sergeant:
    Champion:
  • 207 Answers
Have u tryed cable select, and somtimes the hard drive is the issue try a different one....
Posted on Apr 09, 2011
Trying to upgrade ram, only reading 512 instead of the gig i put in, can i reset jumpers or is there any other way. i don't have motherboard manual
you can only have the gig stick the board is older and can only utilize 1 gig at most take out the 512 and your gig will show up i promis
May 10, 2010 | EPoX EP-3WTM3 Motherboard
Epox 8K9A2 motherboard ? hangs @ POST CODE "26"
Gday mate , you will have to start with BIOS settings on boot when it detects the drives at the bottom of the screen will be a press ( this button) to enter setup probably delete or F8 go to there and probably set standard defaults would be the best option in the list do tha and follow the prompts back to startup screen, unless it comes up with NTLDR missing which is in the OS files
Apr 07, 2010 | EPoX EP-8K9A Motherboard
Epox ep-8kta3pro want to add ram procedure
That is the correct memory type, max of 1.5GB, and not the 2 you would expect. You can use 64/128/256/512 modules, but when using 512, only 3 are recognized, the 4th slot is disabled.
Jun 24, 2009 | Asrock 845GV (P4I45GV) Motherboard
Motherboard specification not available.
Are you uning the recovery CD or a new OS?
A new Os (XP) will allow the second drive even if the old one will not. Of course you can always add a USB hard drive and a USB PCI card to make it all work. What are you using this pc for seems a little old for todays applications. Suggestion If your going to use this that you Replace the main hard drive with a 120GB or larger, new video card at least 256MB if not 512 and at least 1 gig of memory as I believe it will only take a max of 1 gig. you cannot use vista as it requires more resources than this Pc can give to support the OS. you may want to try XP LITE as well one you get XP installed to speed it up a bit!
Joe
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
4 gigs of ram on xp 32 bit
Depends on how much memory your motherboard can accomodate. If *********** board can support 4 gig then just plug your ram and it should work.. xp supports up to 4 gig of ram so even if you connect an 8 gig,it will only recognize the 4gig. Hope this help,
May 11, 2008 | Microsoft Windows XP Professional
New Maxtor SATA drive into computer with OS on IDE drive?
try to change your master as the 300gig then secondary master 40gig then your slave 20gig. then check it to the bios
Dec 20, 2007 | IBM (02R4087) Motherboard
K8 Neo-2 V-2.0
Please connect jPw1 to 4 Pin 12v, this supplies power to CPU. Than enter Bios & find Boot settings. Set the cdrom as boot 1 & hd as boot 2. Check the jumper on the cdrom, as it is the only device on secondary IDE controller it should be set as a master.
It is better to install a fresh copy of windows with a new motherboard. Put your windows CD in the cdrom & the system will boot to it. And your on your way. You can install the drivers for the board after windows has been installed.
Enjoy!
Plaease vote..
Dec 05, 2007 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Win XP Service Pack 2
-TRY TO CHANGE THE CD\DVD-ROM AND THE DATA CABLE
Nov 07, 2007 | Matsonic MS9158EP (DSMTSMS9158EP)...
EPoX EP-8K9A2+ Motherboard Logo
102 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
