2005 Mercury Montego Logo
Posted on Oct 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TSB data for: 2005 MERCURY MONTEGO Bulletin Number: 0662 Sequence Number: 10019951 Date: 20060101 Component Name: 117000 DIGITAL INSTRUMENT PANEL Make: MERCURY Model: MONTEGO Year: 2005 Summary: INTERMITTENT INSTRUMENT CLUSTER GAUGE SWEEP/RESET - MULTIPLE WARNING LIGHTS ON - REVERSE LIGHTS ON does anyone know how to repair this problem?
fordexpert
Level 3:
  • Mercury Master 5,692 Answers
  • Posted on Oct 14, 2017
fordexpert
Mercury Master
Level 3:
Answers
5692
Questions
Helped
1973280
Points
17063
I can contribute this much. The TSB for repairs should have remedies stated in the notice. You should be able to look up the TSB by number and read its' process for the repairing Dealer. One site, "aboutautomobile.com" has some TSB info that may add to what you already know. You might ask a Dealer for a printout of the TSB.
5 Related Answers
Brian Anderson
  • 399 Answers
  • Posted on Mar 28, 2009
SOURCE: Change the oil on a 2005 Mercury Montego
Go to a automotive store and tell them you have a 2005 Mercury Montego and what engine it has if there is more then one model and get an oil filter and the oil. Put the car up on ramps and secure it making sure it won't roll back or fall while you are under it. get under the engine and look for the oil pan which should have a bolt in the bottom of it where you can drain the oil. Drain the oil in a proper container and then put the drain plug back in the pan. Then find the oil filter and unscrew it and remove it.. It could be full of oil so watch out and make sure the pan is underneath the filter. Wipe the base where the oil filter screws on and make sure the gasket from the old filter is not still on the engine. Get your new filter and take your finger and put it in one of your new containers of new oil and spread that on the gasket of the new filter. Screw on the filter until the gasket touches the base and then turn only a little more then a 1/4 to 1/2 turn tops. Do not over tighten the filter. Find out what oil the vehicle needs (probably 5-30) and look for the oil cap on a valve cover under the hood. It probably takes 5 quarts but check for sure in your manual or ask when you are at the automotive store. Put the oil in and put the filler cap back on. Now go start the vehicle and make sure you have oil pressure by either the oil pressure guage showing pressure or the oil pressure idiot light goes off and while running check under the car for any signs of leaks. If no leaks then back the car off the ramps and shut the car off on a level surface. Let it sit 10 minutes and check for leaks underneath the car and check the oil dipstick to make sure the proper level of oil is in the engine. Then you are set.
Always check your air filter when changing oil to make sure it is clean as that helps your engine run better and you save gas in the process. Good luck
It is also best to change oil when your engine is warmed up as well.
Anonymous
  • 82 Answers
  • Posted on May 01, 2009
SOURCE: 1992 Mercury Grand Marquis - The odometer stopped working.
Go to a auto recycler or ebay.com ..... you have to remove the woodgrain trim panels and the radio ... then the bezel ... a string that attaches to the steering column to the gearshift selector in the gauges then the guages ...
Anonymous
  • 1959 Answers
  • Posted on May 30, 2009
SOURCE: Need to replace alternator
Here's a link to the alternator diagram:
http://www.chiltonlibrary.com/content/images/0601/images/06017-FREE-g02.gif
Instructions:
  1. Disconnect the negative battery cable.
  2. Raise and support the vehicle.
  3. Rotate the drive belt tensioner counterclockwise and remove the accessory drive belt.
  4. Remove the right lower splash shield.
  5. Disconnect the crankshaft position sensor.
  6. Disconnect the wiring harness locators from the alternator splash shield.
  7. Detach the alternator wiring connector.
  8. Remove the positive cable nut.
  9. Remove the alternator splash shield and the alternator.
Here's a link to a website to put the serpentine back on, just insert the year,make,model, and engine size to get the "Routing Diagram" for your car.
http://www.mvreader.com/multiview/dayco/index.php?bgInterchange=1&l=n
All the best on your repair.
Greg
Brian Anderson
  • 399 Answers
  • Posted on Dec 15, 2009
SOURCE: Oil change light
Look up the light on the part of your owners manual that explains what each idiot light is for on your dash. That should give you a page where more information on it is available. Part of that section should state that if maintenance is done by someone other then your Mercury dealer, then do the following to reset the light. That should take care of ya.
Good Luck
Anonymous
  • Posted on Nov 27, 2010
SOURCE: Instrument Cluster lights do not go on, emergency lights steady- Sable 2002
I think I have a solution to this problem.
It started with the alarm going off intermittently in my 2001 Sable. About a week ago my instrument panel lights started doing the same thing (cutting out and the flashers would come on with no flashing). After I disconnected the alarm sensors under the hood and in the trunk, the instrument panel problem went away and my alarm no longer goes off at all hours of the night. Hope that helps!
2005 Mercury Montego. I need a wiring diagram for the stereo
2005 Mercury Montego with Audiophile Audio Car Stereo ...
www.modifiedlife.com > 2005-mercury-montego-with-...
The Modified Life staff has taken all its Mercury car radio wiring diagrams, Mercury car ... and we'll do our best to find you the information you need for your mobile audio installation. ... 2005 Mercury Montego Car Radio Stereo Wiring Diagram.
Mercury Montego ' Stereo Wiring Diagram
stereowiringdiagram.info > category > mercury-montego
October 20th, 2017 ' Comments Off on 2005 Mercury Montego ' Posted in Mercury Montego · 2006 Mercury Montego. October 20th, 2017 ' Comments Off on ...
https://www.google.com/search?q=2005+Mercury+Montego.+I+need+a+wiring+diagram+for+the+stereo
Need entry code for used 2005 mercury montego dealer went out of business
contact the manufacturer( ford) , engineer department and as them for the code
you will need vin number , year , rego number engine make etc
Why do I have all these codes on in my 04 Pontiac grand prix gt. U1000,u1300,u1016,u1064,u1096
There is a Pontiac Technical Service Bulletin addressing your exact issue, right down the the same exact codes you are getting. Here is the information I gathered and I will place a link to the page where I found it. You will need to scroll down the list of TSBs to find your specific one. Apparently this is a problem for the Grand Prix.
Here is the basic data:
TSB Number: 0308116001 NHTSA Number: 10002880 TSB Date: February 1, 2004 Date Added to File: September 30, 2003 Failing Component: Electrical System Summary: Diagnostic trouble code (DTC) U1000, U1016, U1064, U1096 or U1305 set in error. This bulletin replaces previous bulletin dated 06/01/2003.
Here is the Link:
http://www.aboutautomobile.com/TSB/2004/Pontiac/Grand+Prix/Electrical+System
851 obd2
Bring it to dealership, this code is listed in Subaru TSB and should be free to fix it.
2005 Subaru Forester Engine TSBs
1 TSB Number: 166806 NHTSA Number: 10020531 TSB Date: October 9, 2006 Date Added to File: November 13, 2006 Failing Component:
Engine And Engine Cooling:Engine Summary:
Vehicles equipped with 4 eat diagnostic procedures for P0851/P0852.
2006 chevy cobalt(85000 miles) check engine light comes on and stays on. I am getting the check engine light code p0420. Engine seems to be running smoothly.
http://www.obd-codes.com/p0420
TSB Number: 3316 NHTSA Number: 10017210 TSB Date: n/a Date Added to File: October 27, 2005 Failing Component:Electrical System Summary:Diagnostic trouble code P0420 may set on low mileage vehicles, or shortly after catalytic converter replacement
there is a service bulletin for this.
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/results.cfm?start=1&SearchType=DrillDown&type=VEHICLE&year=2005&make=CHEVROLET&model=COBALT&vehtype=PC&typenum=1&component_id=0&summary=true
1helpful
3answers
2008 f150 shakes when braking, chaged brakes and
makes no sense other than maybe the anti lock system is messing up
Asked before about a rattling sound i hear coming from the left of the steering wheel at around 1500rpms, had a mechanic check the exaust system and did not find anything, but I just came across this, CAN...
you can find out for yourself what the tsb is. go to http://www.alldatadiy.com/
costs less than 20 bucks to buy a 1 year subscription to your vehicle, which includes full listings of tsbs. i use it all the time on vehicles i need info on
1helpful
Off the track
Unsure if this is specifically related to your actual problem but there is a TSB on the side door sliders for 2004, I had mine replaced under warranty.
Service Bulletin Number: 82 NHTSA Number: 10015268 Model Years Affected: 2002, 2003, 2004, 2005 Date of Bulletin: 07/2005 Bulletin Summary: IMPROVED CENTER SLIDING DOOR ROLLER ASSEMBLY.
8helpful
3answers
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
