Question about Craftsman 3000 PSI 28 GPM Honda Powered Pressure Washer
While using my Brute 3000 powered by a Honda Gc190 with a MTP pump, it starting spraying white water and the sound of the pump changed. I thought immediately of oil from the pump mixed with the water. Now it only sprays water inconsistently - not full bore and continuous. Could the pump seal have gone? What all will I need to replace? where do I start
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I have a Brute 3000
Hi and welcome to FixYa, I am Kelly
It took a bit of research but I think I found the parts list here:
http://www.arkansas-ope.com/BRUTE_PW_020303.pdf (
There WAS a kit for this pump that the part number is B4182 and is no longer available. ( http://www.ppe-pressure-washer-parts.com/horizontal-replacement-pumps
The pump parts list you should be looking at is 020303-2
There are oil seal and water seal kits here: (Half way down the page)
http://www.ppe-pressure-washer-parts.com/brute-pressure-washer-020303-2-parts
You said you got a milky color then lost pressure. Until you tear it down you will not know if it is the water seals or the oil seals you need. Personally.... I was going to repair it for you I would install both sets of seals. What will be frustrating about the repair process is you usually do not get it going again on the first try. You will end up ordering other o-rings to complete the repair. If you get it by the 3rd attempt your doing great!
What may have caused this problem a lack of water supply due to a restriction somewhere. If for example there is an inlet screen to the pump and the supply line was mostly blocked the pump will cause a vacuum and draw the seals inward into the pump. ( I think this is what happened to your pump) Just make sure to check for any inlet strainers or screens. Who knows you might get lucky and just have to clean the screen / strainer.
Kelly
Posted on Apr 10, 2011
Govoner arm came off how to put it on in the right place
thats a honda engine
Search Results
Honda Engines ' GC190 Owner's Manual
engines.honda.com/parts/ownersmanuals/gc190 Download or purchase Honda Engine owners' manuals for the GC190.
Honda Engines ' GC190 4-Stroke Engine ' Features, Specs, and ...
engines.honda.com/models/model-detail/gc190 Official specs and features for the Honda GC190 OHC engine. ... is a small four-stroke gas engine designed for premium residential use. ... Owners Manual.
[PDF]honda 6hp gc190 repair manual.pdf
www.publicwalls.org/honda/honda-6hp-gc190-repair-manual.pdf
Apr 08, 2016 | Horizontal Engine 6 Hp Ohc Gc190mha2
How to adjust output voltage on Honda 3000 generator
Hal, you may be able to adjust some what by changing engine RPM(throttle *****) and playing with the governor if need be with no load and with load.
Portable generator voltage regulator
Onan generator adjustment run speed voltage
https://mtspowerproducts.com/admin/data_sheet/SS321Manual%20II.pdf
Mar 27, 2016 | Powerboss 020309 3000 psi 2.5...
How do I remove the connectors from the output hose?
Does it have brass quick connects or is it screwed directly into the pump? Feel free to email me.
Sep 26, 2014 | Karcher G 3050 OH 3000-PSI Honda Gc190...
Throttle linkage is loose and when started water does not come out the nozzle after BEING BLED OF AIR
The unloader on your pump is bad...this is causing both problems. Find your pump model # ...probably an AR pump ...they fit the Honda GC engines well and go to this site Pressure washer parts catalog quick links Pressure Washers High Pressure... they can guide you to the correct unloader... Good luck
Jan 19, 2014 | Powerboss 020309 3000 psi 2.5...
How to remove pump from a powerboss 020309 power washer
Remove the 4 mounting bolts and it will slide of the shaft if it's not rusted. If it's a little rusty it will take time and some good rust buster applied between the pump and engine onto the engine output shaft. Hope this helps, it's not always the easiest thing to do.
Sep 29, 2013 | Powerboss 020309 3000 psi 2.5...
HOW DO I DRAIN THE WATER FROM MY HP WASHER FOR WINTER
What I've always done is just disconnect the water hose then start the washer and pull the trigger till no more water comes out. You don't want to run it very long at all after there's no more water though, you can quickly overheat the pump if it is ran without a water supply for too long. I've been doing this for the past 3 years with one of my washers and haven't had any problems with the pump.
Oct 05, 2012 | Powerboss 020309 3000 psi 2.5...
Chemical wont siphon
In most cases this is because you have a high pressure tip, the red, white, yellow or green tip, on the wand. The detergent system will only work if you have the black, soap tip on the wand. With a pressure tip on the wand, there is too much back pressure for the syphon system to work. If you are using the soap tip, check the feed tube for the detergent for blockage, especially at the pickup filter and where it attaches to the water line.
Sep 16, 2012 | Powerboss 020309 3000 psi 2.5...
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Craftsman 3000 PSI 28 GPM Honda Powered Pressure Washer Logo
179 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
