Question about Polk Audio AMR50 Computer Speakers
I have windows xp, my speakers are Polk Audio HP-3, I am not getting any sound, but they play in other things..can you help me please?
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 09, 2011
Polk audio sound bar 4000 comes on no sound
try to re-installing the driver .
if not solved , may be the speaker damaged .
May 25, 2014 | Polk Audio SurroundBar 4000 IHT Virtual...
I have polk audio speakers that came with my old hp f50. I just purchased a new hp but can't get my speakers to work
The old speakers are not compatible. Your new computer is looking for an external power source for the speakers, the older polk speakers that came with Hp computers have none.
Sep 15, 2010 | Polk Audio AMR50 Computer Speakers
I just upgraded from a hp pavilion to a dell computer with windows xp.I have polk speakers but they do not work. Don't know their model no. They worked fine on the H.P. HELP!
Hi , make sure you have correctly , installed the drivers for the sound card or Motherboard you are connecting into your laptop...and make sure it is compatible with XP
Happy new year
Hope you come right bud :D
Dec 27, 2009 | Polk Audio AMR50 Computer Speakers
My monitor quit working. I plugged up my old one but it has no on board speakers. I plugged in my old speakers (Polk Audio) but I can't make them work. Does anyone have a fix? Thank you.
Yes, just download or update your audio drivers from windows. You can probably just update your windows and it will do it for you. Just go to programs > windows update.
Next thing you can check is that all the cords are plugged up right.
Then right click on your speaker icon on the task bar (its usually by your clock on the computer) and click on Properties or Playback Devices (whichever you see on pop up menu. You can also get to the same place by opening Control Panel and clicking on the Sound icon).
So now you just click on the tab called Playback and make sure you pick the speakers that you want. Choose the plug, or place where the speakers are plugged in (front headphone jack, rear audio jack, or where ever you plugged them) and set them as the Default playing device by right clicking on it and choosing that option from the pop up menu.
You can explore around these tabs and can test your speakers out and what not. Just look under all these tabs and explore. Hopefully this will help you get them working.
Dec 06, 2009 | Polk Audio Audio Players & Recorders
I did something on the internet and now my speakers don't work anymore. The icon at the bottom right hand corner is gone. What can I do to hear again? I don't have the manual for the speakers to refer back...
Looks like your audio drivers have gone. have you tried system restore? Go to start, all programs, system tools system restore, then choose a previous date when your sound was still ok.
Sep 16, 2009 | Polk Audio AMR2 Computer Speakers
Changed computer but using same speakers but no volume
Hello there:
if the volume controle is not on the taskbar try to go under controle panel and go to sounds and the adjustments for the speakers will be there. than click on add to taskbar and click apply when finished ok?
best regards mike
Aug 18, 2009 | Polk Audio Audio Players & Recorders
Polk speakers play very low sound on youtube etc. windows xp
maybe the problem is on the files you play but not your device.
Apr 27, 2009 | Polk Audio AMR50 Computer Speakers
Speakrs don't work on new HP Pavilion desktop.
If you're using Windows XP, go to the Control Panel, then double-click on Sound, then go to the Audio tab and make sure the playback device is set to your Realtek output.
If you're using Windows Vista, go to Control Panel and click on Hardware and Sound, then click on Sound. Make sure your Realtek device is selected with a green check mark. If it isn't, just click on it and then click the Set as Default button down below. Vista sound configuration is kinda quirky, and it does do some kind of detection when you plug a cable into an audio jack, so you might leave this screen up while you plug your speakers into the green audio jack in the sound card and see if it pops anything weird up.
Apr 17, 2009 | Computers & Internet
My speaker sound
If you are using Windows XP, click >Start>Control Panel>Sound, Speech and audio devices> again >Sound, Speech and audio devices> then check the "Device Volume" control. Also check the controls under "Advanced" button.
Feb 15, 2009 | Polk Audio AMR50 Computer Speakers
Open Questions:
Polk Audio AMR50 Computer Speakers Logo
83 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
