Question about Samsung SyncMaster 550S Monitor
How do I open cover of Acer AL2021 Monitor ?
No Display on My Acer 2021 LCD Monitor, Someone told me I may have to replace capacitors, But i dont have clue to open the monitor cover. Please help. ( there is no screws, I can see only one hole KEY LOCK pic on top.
Please help me
    New Friend:
  • 3 Answers
This is a bit tricky, but not impossible.
1. Remove the two visible screws near the bottom. 2. Pull the plastic covers off the stand: Pull from the inside (nearest where the stand is attached to the monitor. 3. Undo the screws and remove the bracket. 4. Under the bracket is the final screw. 5. Try pulling the front off the back starting at the bottom. It'll require a little force. 6. Now you should be able to get a knife in to pull the rest of the case off. Leaver by pushing the front outwards and back inwards and the clips should come off ok.
Posted on Jan 17, 2011
SOURCE:
Power is ok but when i connect vga cable display not come
The monitor has faulty capacitors. Capacitors have a job to hold power long enough for your display. Faulty capacitors will only hold power for at least 2 to 8 seconds and a dead one will actually not hold power at all. The only solution is to replace the faulty capacitors. Get a computer technician to open up the monitor for you and locate the faulty, leaking, or bulged capacitors located on the circuit board where you connect the power supply. Note the polarity of the capacitors as you replace them.. (+) and (-)
Feb 22, 2012 | Acer AL1717 17" LCD Monitor
Display for a few second
That is because your monitor has faulty capacitors. Capacitors in your monitor have a job to hold down power as it comes from the source long enough for a proper display. The only way to get around this problem is to open up the monitor (You can get a computer technician to do this for you if you can not do it by yourself). Or you can get a sharp - flat object and start opening (splitting) the two covers apart from the bottom of the monitor. You will notice finger-like structures that are holding the covers together. Make sure you do not break any of those. When you open it up, then check the circuit board where the power supply cable is connected. Check for any bulged or leaking capacitors. When a capacitor is bulged or leaking, it only holds power for at least 2 to 8 seconds then looses it. Buy the same type of capacitors and replace the faulty ones. Make sure you note the polarity of the capacitors before replacing (+ and -). This will definitely take you out of your trouble
Feb 20, 2012 | BenQ FP567s 15" LCD Monitor
Acer 2016W - When powered on, it shows colored lines (blue, green, red, yellow - vertical) and then goes to a blueish-green display color, no deskktop display at all, have tried switching out monitor...
Yep,
When the capacitors start to go out it causes the power supply to not provide the correct voltages. You monitor has the back light power but the 5v power going to the video driver board is not working correctly. Here is a link to a repair guide that will show you how to open the unit, remove the power supply board and what capacitors need to be replaced.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2016w-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 13, 2011 | Acer AL2016W 20" LCD Monitor
I start my PC monitor display after 10 to 15 minutes, I have tested with another monitor its start immediately, what is the reason with my sync Master540n Samsung monitor
you have to open the back cover of your monitor have a visual check on the capacitors at the power board.replace any bulging capacitors on it and resolder the board..good luck!
Jun 11, 2011 | Samsung SyncMaster 540N 15" LCD Monitor
Monitor flashed a few times and the display went dead. No display.
Service manuals: http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1916W&kategoria=monitor&kat2=schematics
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 30, 2010 | Acer AL1916W 19" LCD Monitor
Philips 170S4 white screen not display.
its in the power suppy section,most of the lcd monitor has this problem,try to check the capacitor electrolytic or replace all th 16v capacitor
Apr 03, 2008 | Gateway FPD2275W LCD Monitor
Monitor flickers and then goes blank
I had exactly this problem.
I fixed my AL2021 by replacing the output caps on the power board. $4 repair. Pull the thing apart (I posted somewhere on fixya how to do it, but it's simple) and replace the 1000uF, 680uF and 470uF caps on the end of the power board.
Jun 19, 2007 | Acer AL2021M (Silver) 20" LCD Monitor
Acer AL2021
I fixed my AL2021 by replacing the output caps on the power board. $4 repair. Pull the thing apart and replace the 1000uF, 680uF and 470uF caps on the end of the power board.
Jul 10, 2006 | Acer AL2032WD 20" Flat Panel LCD Monitor
Samsung SyncMaster 550S Monitor Logo
409 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
