Question about M&S Systems Local Audio Input Module - Xtreme Digital Music System Shelf System
I have M&S Systems MC602 interecom-radio unit. Has worked for 12 years. Now there is no power showing on the display. The power button does not turn the unit on at all. All the features appear to be dead. I have checked the circuit breaker for that area and other outlets in that area work. I have not pulled the unit out of the wall yet to see if there is a reset button. Looking for self help before I call in a technician. I do have a volt meter to do some trouble shooting. Thanks in advance.
2 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: I have a M&S Systems Model MC602 Master Unit.
the only way that this door bell is ringing is when you manually action it ...right>???so ...the issue is on the button (switch ) or there is a short on the wires that goes to the button ....so ..if I was in your place ..I will power it off..and open the switch button (the one from the door that it pressed to action it ) ..and see if it is still ok ..See that if yo remove one wire ..is stopping ..if does..this means it is the problem and it needs replace ..or checked for a short circuit ..if this will not stop it ..means that the wires are making contact somewhere on the way ...and you have to go along them and check ..until find the problems ..If you find no problem along the buttons wires..than move on the unit itself..and open it to check for a short circuit between wire that should not suppose to touch ....that's almost all you have to do ...if youdo not find the issue ..is probably internal one in the unit itself ..and probably the fastest fix is to change it ..
Posted on May 15, 2010
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
Need radio code for Chevy venture 2003
radioo
02-20-2006, 02:03 PM
Only a GM dealer can unlock the radio.
It is much smarter to disable lockout entirely, with MP3/WMA, DVD and XM-ready stereos, the regular CD, cassette, and radio-only units aren't so hot.
The following applies to an unlocked powered-on radio (2000 shown)
1. Do not disconnect the battery
2. Press the stereo's "1" and "4" buttons at the same time for five seconds with the ignition on and radio power off. he display will show "SEC", showing anti-theft is on
3. Press the MN button, the display will show "000"
4. Press the MN button until he last two numbers are the same as your secret code (how do you find this? you decide the code?)
5. Press HR until the first one or two numbers displayed match your code. The numbers will be displayed as entered.
6. Press "AM/FM", if the display shows "_ _ _ " you have disabled Theftlock, if "SEC" is shown, it is still in Theftlock
01-30-2010, 02:14 AM
I just tried this for my 1998 Chevy Venture and it works! press the 2 & 3 numbers at the same time for about 10 seconds; a 2 or 3 digit code will come up; press the am/fm button for about 10 seconds; another code will appear; dial 1-800-537-5140 and enter 106010 followed by the # sign; enter the 4 or 6 digit code from your radio followed by an *; the phone number will give you a 3 or 4 digit override code; enter this code into your radio just as your owners manual tells you to - use the hour and minute buttons to put in the unlock code, Press AM/FM button, "SEC"---" will display and You can turn on the radio. I had tried this with another dealer code and it wouldnt work, but with the 106010 dealer code it worked just fine, my unloc code was 0120
Jan 21, 2011 | Car Audio & Video
Have M&S systems Model MC602 Can't seem to reset after power outage.
I called the company and this is what they said:
Based on the problem description, there is nothing you can check to try and get the radio to work again. The most likely cause is a Tuner Module failure due to electrical surge. You will need to send the MC602 to us for service. We will need you full address, phone number, and the serial number or date code from the back of the MC602. The serial number/date code will be on a white sticker and may have a barcode on the sticker as well. When receive you information, we will issue you a Return of Product Authorization (RPA) number and instructions for returning the unit. There will be a repair charge and that can be provided with the RPA number.
Sincerely,
James Williams
Senior Applications Engineer
Linear LLC
Technical Services
(800) 421-1587
Sep 23, 2010 | M&S Systems Audio Players & Recorders
My radio on the mc602 stopped working. The entire system still works except for the radio. any ideas?
sounds like a internal fuse look in your manual and see if it may have a heatsink switch that disables the radio if the heat levels get too high.
May 27, 2010 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
My 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Apr 10, 2010 | Bose Wave Radio
MC602 intercom system locked up
I don't have a solution, however, I do have the same problem. When it happened originally, I smelled electrical wires burning. someone checked it and said that a wire had shorted. The electrician checked it out but could not find out what was wrong with it. The radio comes on, but we cannot use any of the buttons.
Sep 03, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
Bose Lifestyle 12 "no display" fix
There is a service available to fix the display at www.AnyoneCanFixIt.com They have fast service and way cheaper than Bose.
Nov 17, 2008 | Bose Lifestyle 12 System
M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
mc 602 system---volume stuck on 32 and not playing main speaker
Mar 05, 2008 | Audio Players & Recorders
Electrical problems with MST70 radio
Have you made sure the 12 volt hookup is good? If the power and grounds are good the radio has a microprocessor problem or the units dragging down the voltage regulator. Its an internal componet and should be sent out to thew factory. Theres a one year warrante from date of purchace and can be sent to Standard Horizon-Att: Marine radio repair-10900 Walker Street Cypress, CA-90630. Or you can go to there website at http://www.standardhorizon.com or call them at 1-800-255-9237 and folloew the promts. Good Luck
Jul 04, 2006 | Standard Horizon MST70 Cassette Player
M&S Systems Local Audio Input Module - Xtreme Digital Music System Shelf System Logo
219 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
woodzowl307
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
