Turn on spa which is set to 100 but only heats to 86 even all lights are on on the Aqualink monitor.
  • 1,420 Answers
Make sure you clean the filter and all jets are open. Heaters work by circulation and if the flow is restricted, it will not heat. If that does not effect the heat, you will now have to open up the control in the spa and test the fuses using either a test light or multimeter.
Posted on Apr 09, 2011
I can't get my spa to heat up using my Aqualink RF4.
check to see if red light on aqualink on for heat make sure heat is enabled make sure gas is on make sure ignitor is lighting otherwise need more info
Mar 29, 2017 | Pool & Spa
Heats to 72 degrees
try setting heater all the way to 104 the aqualink should control the heat
Jan 03, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jet pump and spa heat enable on their own
Check your time settings. It sounds like the Spa Mode has been set to run at given times and with heat enabled the heater will automatically turn on when the the spa is activate.
Jan 09, 2013 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I have an Aqualink system, spa set to 104, it will heat to 94 and stay there, temp sensor is working, took water sensor out of line, plugged line, assumed heater would just keep heating, it did heat a
The heater may be wired just fine. The aqualink uses its water temp sensor to call for heat based on what you've set the thermostat to on the aqualink. However, most heaters have built in thermostats that over-ride the aqualink. Those thermostats come factory defaulted not to go over 94. Check your heaters manual on how to adjust the thermostat on the heater. Your heater should have its thermostats set to 104 and the aqualink will control the actual temp of the water by calling for heat based on what you've set the thermostat on the aqualink for. Hope this helps.
Oct 16, 2012 | Jandy Aqualink Rs4 One Touch Control...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy aqualink 8
check spa side remote remove plug if still happens bad board if it goes away replace spa side remote shorted or bad wire
Apr 08, 2010 | Jandy AQUALINK RS TELELINK KIT
I have a Jandy AquaLink R54. Lights going haywire!
Software or hardware failure at the mother board. Call your local Jandy repair facility...
Mar 28, 2010 | Pool & Spa
I have an aqualink rs and my spa heater isn't working. I checked the propane and it is full. The heater was working 2 days ago. Now I turn spa and spa heat on the filter pump comes on and the red light...
If the Aqualink is calling for heat then the problem is most likley in the heater. Without more information I can't tell you much more but if nothing has changed in the last couple of days. Before you call anyone be sure to clean your filter and baskets. The heater need a set amount of pressure to run and if things are dirty it won't get that pressure. Good luck.
Mar 12, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
My spa will not heat. The heater shows that it's working but it will not heat the water.
When you say that the heater shows that it is working is it the heater that shows this or the Aqualink. If it is the aqualink it could be a temp sensor, probally the water sensor that is in a pipe comeing from the pump. But the first thing Iwant to think of is your temp is set on the Aqualink but the temp is not turned up on the heater. If your heater is not compatiable with the link you need to keep the thermostat at max and set to pool or spa to have it work. If it is compatiable it could be in the wireing between the two or you just may need to be sure the Aqualink is set to read and override the heater. Your menu can walk you through this or your book on the unit. Let me know how you do and we can check for further problems in your heater. If so let me know brand and model of same. Good luck.
Oct 24, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
