NEED TO CHANGE BLACK CARTRIDGES, HOW CAN I DO THIS?
    Brigadier General:
  • 10,406 Answers
Turn the printer on.
Lift the lid that covers the print-head mechanism.
In a few seconds, the print-heads will slide to a position where the ink-cartridge can be removed.
Then, "unlock" the ink-cartridge from its socket, and gently remove it.
Replace it.
Then, "lock" the ink-cartridge into place, and close the lid.
Print a test-page.
Posted on Apr 09, 2011
  • ranc Apr 09, 2011
    It took several times before it worked. The printheads did not stop automately at first, it kept goin into the left hand corner. After turning the printer off several times it finally stop and then the cartridge was inserted. Then I had to wait several more minutes before it would respond that a new cartridge had been inserted. Finally I was able to print a test page.
    Thanks
I have two expired color cartridges in my D7160. I only need to print in black,and have a brand new black cartridge inserted. The printer keeps telling me to replace the expired color cartridges, yet I...
They believe expired cartridges will damage the printer. If you change the date back on the printer and computer this will solve the problem and allow you to print.
Regards GM
Please rate this answer below Thank You for supporting the Fix Ya Community
Apr 17, 2011 | Office Equipment & Supplies
I just replaced my black inkjet cartridge for my S305 printer. It tells me I need to also replace my majenta & cyan cartridges in order to print. Why won't my printer print in black only without...
Hi, the same occurs to me today, I went to Walmart in Barceloneta, Puerto Rico at night, I brough the Black cartridge for $18.00 I was really happy about it, I went to my home and install it, then say the same It can't print without mangenta and the others ****. WELL, but I still love lexmark so I realice a solution, it will be inminent to buy the others colors, but then do not use them, just keep them fulled; use only black, and then you will be able to change black only, since the colors will be always full. ALWAYS CHOICE PRINT IN BLACK AND WHIT. Hope you find this a little usefull. Go to: josiqvideos09 on youtube channel. Thanks.
Nov 02, 2010 | Lexmark Office Equipment & Supplies
Have a c1900 but no disk for utility management to change toner cartridges, how do I get around this and change toner cartridges? Drivers are installed and printer in operation hence need to change...
You go through the menus :
Press Right arrow once,
Then down arrow 5 times (to Reset Menu)
The Down arrow 5 times to Change toner C (Cyan)
Then down arrow again to Change toner M (Magenta)
Then down arrow again to Change toner Y (Yellow)
Then down arrow again to Change toner k (Black)
Select your colour to change and press the right arrow. The engine durns, open the door and remove the cartridge
Jul 01, 2010 | Epson AcuLaser C1900 Printer
Hp officejet 5610 All-in-one having 'cartridge error', need help to solve it. thank you.
Remove both cartridges and clean the electrical contacts with a dry cloth. Clean the contacts in the carriage, inside the product too. Put the cartridges back in.
If that doesn't work, remove the black cartridge from the printer and try to print something. If the color one prints, you need to change the black cartridge. If the color one won't print, and the black does, then you need to change the color cartridge.
Apr 11, 2010 | HP Officejet 5610 All-In-One InkJet...
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
New cartridges don't work.
Most likely the printer needs to be sent for repair. Talk to HP and get them to fix it and take your cartridges and bills with you as they have to fix this.
Nov 18, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP color laserJet 2840
If you've tried 2 black cartridges and you cleaned/aligned them then I think the black cartridge bay is likely malfunctioning. This doesn't sound like a driver/PC issue to me, but something physically wrong with the printer. You could try a local printer repair service
Did you update your printer drivers just for giggles?
Mar 25, 2008 | Office Equipment & Supplies
Cannot print in black only
It is not wise to leave the cartridges empty, causes permanent print-head damage on the empty color area. However, if you want to use the other color, say "black", bypassing the cartridge check is simply resetting the counter of the printer... download the utility file "sscserve.exe" you can search it on the internet. Install it then choose your printer on its list box, then by right-clicking on the printer icon of the utility at the bottom right of your window... you should be able to see what you need. Happy printing!!!
Oct 23, 2007 | Epson Stylus Photo R220 InkJet Printer
16 people viewed this question
jasbo
jasbo
