Question about Canon Elura 65 Mini DV Digital Camcorder
My canon elura 65 won't charge. I have two chargers, and they both don't work. The light by the charge input does not light up like it used to. I tried different outlets as well. Same problem.
SOURCE: canon elura 65
Same here. It used to happen occasionally (started last fall), now its all the time. When it did happen occasionally, turning it off and removing the battery helped a few times, but that may have been coincidence since I don't see why that would have any effect.
Posted on Mar 28, 2007
SOURCE: Disabling the Auto-Off Power Function on Canon Elura Camcorder in Record Mode
Take the tape out. The Camera should stay on.
Posted on Apr 18, 2008
SOURCE: Elura 60 Zoom Problem
Guys, so weird but on another site it offered this suggestion: banged the base of your camera against something hard and it will become unstuck. So bang the base of your camera against something hard and it will work again, at least it works like it did but not sure for how long. Good luck. I can't believe that worked. Give it a try. I didnt hit it too hard either.
Posted on Sep 21, 2008
SOURCE: zoom
My zoom problem was a combination of the software and hardware when it came to the neutral position for the zoom slider. When the camera is first turned on, if the physical zoom slider (hardware) is in the neutral position (you are not touching it) the camera software does nothing, but if you are pushing the physical zoom slider when you turn on the camera, the software resets the "zero zoom" position into memory. The solution to my problem was to push and hold the physical zoom slider towards the wide position and the software realize reset the "zero zoom" neutral position. This may take a few tries to get it right (if you over compensate, do the opposite and push the slider towards "T" when you turn it on), but I hope this will solve your problem and save you a few bucks.
Ryan
Posted on Nov 15, 2008
SOURCE: Canon Elura 65 Camcorder USB input?
I tried to look over the camera for 20 minues and could not find any slot to put the USB cable in. I looked over the camera just one last time before giving up and and i found a little pull tab on the front of the camera. I pulled the tab and it opened showing a circular insert (for hookup to a TV) and a USB slot!
Posted on Sep 07, 2009
Canon Elura 90 camcorder
If the battery do not have any current after removing it from the charger, you can use 6 volt adaptor bust the battery before charging
Nov 03, 2011 | Video Cameras
Our Canon Elura 65 Camcorder won't focus. The
First off I don't condone or advise hitting an electronic device but, from the advice of another post I did it and it worked. It shouldn't have but it did. I hit the bottom of the camcorder with the palm of my hand and it worked perfectly afterward.
Jun 28, 2010 | Canon Elura 65 Mini DV Digital Camcorder
Sep 07, 2009 | Canon Elura 65 Mini DV Digital Camcorder
Do not know how to use charger for camcorder its a canon elura 60
Turn the camera off and put the battery in and connect the charger you will see a red light blinking. when the red light is on steady the battery is fully charged.
Dec 20, 2008 | Canon DC10 DVD Camcorder
Canon Elura 60 won't power up
The same thing happened to mine soon after I got it. Turned out the plug I was using to plug it into the wall to charge had gone bad. The replacement was over $100 so I went with a (cheaper) wall battery charger that you conect the battery to.
Nov 09, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Download movie to computer
I have an elura 65 and I believe this model does not let you download your movies onto the computer in full motion. you can only do it through quicktime or some other similar program using less frames. the higher models: elura 70 etc. are supposed to be capable of transferring full motion film. that's what I understood from the owners manual. hope this helps
Jun 09, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Canon elura 65
Hi There, Did you get any resolution for this problem? Even I have the same problem with my canon elura 70. Pls. share your thoughts. Thanks... Pradeep
Feb 08, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 65 Mini DV Digital Camcorder Logo
37 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
