SOURCE: I have a Toshiba A105 Laptop, Screen goes blank after windows....
Here are some easy things that can sometimes resolve this problem:
1) Sometimes there can be a static buildup on the mother board. Power off, remove the battery, remove the power cord and hold the power button in the on position for at least 30 seconds.
2) If that didn't work- Power down, remove the battery, remove the Hard Drive and memory modules and reinsert them. Try to power back up
If these things don't work, get back to me for some more ideas.
Ron
SOURCE: l355d toshiba dvd v1.20.10 region change
here is how you do it: go to my comp. slect the drive for your dvd rom i.e, "D" whatever your letter might be, right click on it, select properties , again, selcet the drive, and again, select properties, and click on the "region" tab. CAUTION: don't be changing regions too frequently, you can only change it up to 6 times...then,, you won't be able to change it.
let me know how that works
SOURCE: toshiba laptop drivers wifi satellite l355d-s7809
Hi please click HERE for the Windows Driver for wifi.
SOURCE: Toshiba Satellite L355D wont connect to the wireless internet
i am having the same problem and its not software related as i have my laptop dual booting with sabayon 5.0 and im getting the same result in that OS so this tells me that the hardware is failing
if your problem is the same as mine have you exposed your computer to cold or humid atmosphere?
mine sat in my trunk for a week this newyears
