Question about Camp Chef TB-90LWG (NG) Grill
I connect the propane valve to the stove and it doesn't work, i just bought a new propane and still it doesn't work, my grandfater didn't use it for almos 4 years. what could happened?
    Brigadier General:
  • 4,736 Answers
Here's an easy solution. Turn the Tank Valve OFF, disconnect the hose from the tank and wait 5 minutes. Reconnect connect the hose to the tank and turn the Tank Valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the burner farthest from the grill first. Once it lights, turn it to it's highest setting and light the remaining burners the same way. Once all are lit, does the flame height look as it should? Is so, you solved the problem. If not, then you need to replace the grill hose/regulator assembly. You can purchase one from any home center or hardware store that sells gas grills and accessories. Take you old one with you for comparison purposes.
If what I suggested solved the problem, remember to always turn the tank valve ON Very, Very Slowly.
Hope this helped you solve the problem.
Posted on Apr 09, 2011
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
Feb 20, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
Gas pressure is very low and quickly subsides then flame goes out.
Try the following:
Reinstall propane with fresh full propane canister. If problem persists then check tubing in stove for blockages. Make sure you open valve all the way for lighting.
If this doesn't work you may have a defective unit and need to replace it or send it for repair.
Thomas
Nov 03, 2013 | Coleman 2 Burner Propane Stove 5430E700
The pilot light won'jt light in my warm morning propane gas stove
If you dont have gas coming thru while holding down the button, you have one of the following; no gas, main valve off, or a bad gas valve.
Jul 21, 2017 | Heating & Cooling
Why does my coleman stove regulator leak gas from the hole on the top of the regulator
Its a safety feature of the regulator. The regulator is designed with a pressure release valve. This has happened to me twice: once with a carbon dioxide tank for my kegerator and once on my propane stove. In both cases I left the regulator (designed with a max pressure rating of X psi) attached to a full bottle in the sun. The heat caused the pressure to exceed the limit of the regulator and the release valve popped. A welding supply store may be able to reset/replace the mechanism but in my case I just bought a new regulator for about $15.
Aug 14, 2011 | Coleman 2 Burner Propane Stove 5430E700
Gas oven gas not shutting off
sounds like you got some debri in the safty valve, teflon tape or pipe dope. they don't come apart so you will probly have to replace it. sorry! disconect lines and blow out good befor replacing it so it don't happen to the new one
Dec 25, 2009 | Ovens
I bought a used direct vent vermont castings radiance model 2600 set up for natgas. I have been trying to get it converted to propane, with no luck. All dealers are telling me that the conversion kit is no...
if you know a lot about it you could convert it your self....you need to get rid of the Propane regulator....you need a Natural Gas Valve and you need to change the orifices....should be stamped on the rating plate the size of orifice for natural gas....I wouldn't recommend you do it yourself unless you have a license....or as I said know a lot about it...I wouldn't have a problem doing it in my own house...however you run into Insurance implications should anything happen if it's not an approved kit from the mfg.
Oct 19, 2009 | Heating & Cooling
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Jan 10, 2009 | Coleman Propane Grill Stove 9921-700
Camp Chef TB-90LWG (NG) Grill Logo
409 people viewed this question
Top Camp Chef Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Camp Chef Grilling Expert? Answer questions, earn points and help others
