When turning on the computer WindowsXP will not boot and I get a message to start from the last good configuration is highlighted along with 2 other safe mode. I can not even get to the desktop. Please help.
  • Patty H 6663 Aug 12, 2008
    This was very helpful, but what if you don't have the CD's that came with the computer nor did you create a back -up CD. How would you fix the problem.
    Problem Solver:
  • 25 Answers
To boot your pc using the windows cd... boot into the recovery console, once at the command prompt type chkdsk /r
Posted on Aug 06, 2008
My pc laptop does not start due to error 2000-03000
Try using the Last Known Good Configuration:
  • Remove any CD or DVD from your computer, power down, then power up.
  • Do one of the following:
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start, and then press F8.
  • On the Advanced Boot Options screen, use the arrow keys to highlight Last Known Good Configuration (advanced), and then press Enter.
  • If your computer has more than one operating system installed, use the arrow keys to highlight the operating system that you want to start by using Last Known Good Configuration, and then press Enter. Windows will then resume starting normally
  • Nov 13, 2013 | Dell Computers & Internet
    My laptop screen is black but it turns on
    Why Windows Vista Boots to Black Screen?
    • The MBR file is corrupt
    • Partition table is corrupted
    • NTLDR is corrupted
    • Registry is corrupted
    • Boot sector of Windows is damaged
    Follow the tips below to fix the problem:
    • Scan PC for Viruses
    • Clean Registry
    • Run Last Known Good Configuration
    • Repair Windows
    To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you
    see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows
    Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
    Keep in mind that you get only one shot with the Last KnownGood Configuration feature. In other words, if it fails to
    revive your WindowsXP on the first attempt, the backup copy is also corrupt.
    Use system utility software like RegInOut after restarting windows.
    Jan 03, 2012 | Compaq Presario CQ56-115DX Laptop
    Pc wont boot up
    Restore to last known Good Configuration:
    To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
    Keep in mind that you get only one shot with the Last KnownGood Configuration feature. In other words, if it fails to revive your WindowsXP on the first attempt, the backup copy is also corrupt.
    Jan 01, 2012 | Computers & Internet
    My compaq computor wont boot up
    Dec 29, 2011 | Compaq Computers & Internet
    I have hP mini 1000 that won't boot up windows. Just shows me Hal.dll error message. How do I fix that if it won't start.
    you will need a copy of windows and an external disk drive then have it boot from the cd when it boots select install windows then leave the current drive intact with no changes or if the repair option comes up you can select that. do not select the repair at the first menu unless you are an expert in dos, always go to the install.
    Jun 30, 2011 | HP Mini 1000 Netbook
    Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
    Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
    Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
    Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
    Please select an option:
    Safe Mode
    Safe Mode with Networking
    Safe Mode with Command Prompt
    Enable Boot Logging
    Enable VGA mode
    Last Known Good Configuration (your most recent settings that worked)
    Directory Services Restore Mode (Windows domain controllers only)
    Debugging Mode
    Start Windows Normally
    Reboot
    Return to OS Choices Menu
    Use the up and down arrow keys to move the highlight to your choice.
    As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
    Will running the Last Known Good Configuration delete anything?
    No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
    Jan 27, 2010 | NEC Versa VX Notebook
    Shutting down incorrectly
    Hit F8 while booting up then start the computer using the last known good configuration. If this helps please rate me if not let me know so I can help. mysleuth
    I copied this from WinXP Help and Support you should be able to restore your system.
    To start the computer using the last known good configuration
    1. Print these instructions before continuing. They will not be available after you shut down your computer in step 2.
    2. Click Start, click Shut Down, and then, in the drop-down list, click Shut down.
    3. In the Shut Down Windows dialog box, click Restart, and then click OK.
    4. When you see the message Please select the operating system to start, press F8.
    5. Use the arrow keys to highlight Last Known Good Configuration, and then press ENTER.
    6. If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
    note.gif Notes
    • Choosing Last Known Good Configuration provides a way to recover from problems such as a newly added driver that may be incorrect for your hardware. It does not solve problems caused by corrupted or missing drivers or files.
    • When you choose Last Known Good Configuration, only the information in registry key HKLM\System\CurrentControlSet is restored. Any changes you have made in other registry keys remain.
    • NUM LOCK must be off before the arrow keys on the numeric keypad will function
    Mar 11, 2009 | HP Compaq Presario SR1830NX PC Desktop
    Media Center "video crash" after installing SP3 dhclaytonphd@msn.com
    (1)The first thing I would do is download video driver from dell.com/support. (2)You can remove SP3 and see if that works. (3) If not you can Start the computer using the last known good configuration I copied this from WinXP Help and Support you should be able to restore your system. If this helps please rate me if not let me know so I can help. mysleuth
    note.gif Notes
    Mar 11, 2009 | Dell Dimension E510 PC Desktop
    Computer won`t boot
    u will have to reformat the hard drive and load win 98 or win xp whichever u want to fix this
    you can have more detailed info at
    http://www.computerhope.com/issues/ch000474.htm
    Jan 31, 2008 | Computers & Internet
    Boot-up
    dot.gif How to load last known good configuration. Question: How to load last known good configuration.
    Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
    Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
    Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
    Please select an option: Safe Mode
    Enable Boot Logging
    Enable VGA mode
    Debugging Mode
    Reboot
    As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
    Dec 06, 2007 | Computers & Internet
    Computers & Internet Logo
    61 people viewed this question
    David Payne
    David Payne
