Question about Garden
Wiring Digram for Lionel model Rail Road Locomotive
  • Nick Apr 09, 2011
    Thank you for your help. I failed to mention that this Blue Comet Locomotive has an "E" unit. and 3 wire that go back to the Tender.
  • Nick Apr 09, 2011
    I will look in these places
    Thank you for all your help.
  • 8,404 Answers
Center rail is one pole and the wheel rails are the other pole. Of course power is provided to the rail by a special piece of rail or a special connector with two screws that snaps to a standard rail. Your transformer has two terminals and there should be one wire from each transformer terminal to each of the two screws on the special connector. Depending on the direction you are going, one is + and the other is - from your transformer. The pick ups (the wheels on the outside rails and the center roller) send the variable voltage power to the motor which runs forward or in reverse, depending upon polarity. This shouldn't be any more complicated. The Light and Smoke (if any) don't care about the actual voltage (+ and - or - and +), just that there is voltage, while the motor is sensitive to the direction the power is actually going.
Always make connections between the transformer and rail with the transformer unplugged from the power source.
I hope this answers your question about your Lionel Train Locomotive.
Thank you for your quesito0n @ FixYa.com
Posted on Apr 09, 2011
  • A Miller Apr 09, 2011
    Have you looked here at all? http://www.lionel.com/CustomerService/se...
    Here is another resource - I think your answer will be here: http://www.lionel.com/media/servicedocum...
    My Lionel is not nearly as sophisticated as is yours. I am using "poles" in my response to help explain the operation but of course, yours is a AC train and doesn't actually have "poles".
    Thank you for your evaluation. Glad I could point you in the direction of your answer.
    Please consider FixYa.com for all your information needs.
The value of a train set 1953 Locomotive 1130
A Lionel 1130 is a "Scout" type locomotive....they are not particularly valuable even to collectors. They were a part of the low end starter sets Lionel made. Now if you had a similar vintage 736 Berkshire or a 681 or 682 Turbine they are worth considerably more.
Aug 10, 2016 | Crafts & Hobbies
Help please. Lionel (30190) Thomas & Friends remote O gauge. Train won't move. Light comes no, nothing. I took the roof off and made sure the switch was in the on position. ??
First, check to make certain that the batteries in the remote are good.
Second, if the train has been running and the problem is new, clean your wheels and pick up roller on the locomotive, then clean the track.
Make certain that when you use the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If none of the above helps, contact the Lionel Service Department.
586-949-4100
Oct 07, 2013 | Lionel (31956) Thomas The Train Set
No smoke tryed every thing
Follow the link to the Lionel Service Document/Manual
http://www.lionel.com/media/servicedocuments/6299711323250LEGACYMallet.pdf
This link is for the customer Service Product Video:
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6371
Feb 16, 2013 | Lionel 628076 Nickel Plate Usra 2662...
Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
I am using a standard 80 watt transformer (not command control), but the rail sounds do not work on this unit at all. I have checked the on/off switch and played with the volume, but still no sounds. At...
Many of the MTH Protosounds 1 and 2 and Trainmaster will not work with the Lionel CW-80 electronic power source. The output waveform is so non-like sinusoidal. The electronic sound systems will not usually respond to this waveform and when they do, the sound will be garbled. Use another power source.
Sep 01, 2011 | Rio Grande Lionel 34500 Ft Diesel...
3 year old Lionel 4-4-2 (road number 8632) that will not run on antique track. Does anyone have any insight into whether this locomotive needs a digital power source or if it would have an issue running on...
you may have to use a Lionel transformer for this because some older trains worked on AC current not the DC current that this train uses
Jan 02, 2011 | Toys
How the power is transfered to the train?
the power from the wall outlet is ( transformed) to 17voilts AC and comes out on posts on the transformer that red and black wires then are connected to the track The rails on the track are entergized and the wheels and the center pickup ride on the track and transfer the power ot the locomotive. the center rail is common and the outside rail is motor power or whisle power.
Dec 25, 2010 | Lionel Trains The Polar Express O Gauge...
Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Dec 08, 2009 | Lionel The Polar Express Train Set
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
