The door catch has broken where do I get a new one? I open it with a screwdriver at the moment
    Brigadier General:
  • 6,277 Answers
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
Please score this solution accordingly.
Thanks and good luck,
John C
Posted on Apr 09, 2011
1999 Chevy truvk passenger door will not shut
Has the catch been operated with the door open? Is the door just banging against the keeper? If so put a screwdriver or even a pen in the catch and operate the door handle and slide the screwdriver away to simulate the keeper on opening the door.
Dec 31, 2013 | Cars & Trucks
Whirlpool duet dryer model #wed9400swo Dryer door pops open, stopping the cycle. Dryer is about 2 years old. Can I fix this myself?
The most probable thing causing the door to pop open isa weak/broken door catch, its very easy to replace. To find it look on the mid center door rim opposite the hinged side,you will see a rectangular shaped plastic piece,thats the door catch.To remove it use a screwdriver and pop it out by placing the screwdriver on the inside rim of it and prying it out. To install the new one line it up and pop it in by pressing on it with your thumb,when you get the part it will come with the rectangle peice and the peice that fits in door,the part that fits in door is probably going to be good and no reason to replace. The part # is 279570 it could be found on line by simply entering that part# in a google search
Good luck,i hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Dryers
The locking mechanism on the drivers side door,is locked in the closed positin.Cant get door to shut?
cheffenwolfb, What you need to do is to take a screwdriver and put it in the catch in place of the locking striker. Pull the door handle to the open position and pull the locking catch open with the screwdriver. Try the door a few times to be sure that it doesn't do it again. A little lubrication on the catch wouldn't hurt. Good luck with this.
May 08, 2011 | Chevrolet Blazer Cars & Trucks
Its cold and the door was frozen stuck. But after unlocking it, I pried it open and when I got in the drivers seat to close the door. The latch is stuck in the down position and the door wont close or...
spray the latch catch with oil or silicone to loosen the latch mechanism than stick something [a screwdriver/ pen ] that u can use to push the catch upward to open push on catch while lifting handle if catch falls back either latch spring still frozen or latch spring broken and needs replacement
Jan 11, 2011 | GMC Yukon XL Cars & Trucks
How to open the door of 773 model for replacing the damaged latch.? Hook like thing of the latch at the upper part is damaged and i have to replace it witha new latch. But I am not open the door.
To open the door, remove the appliance case and with a long small diameter screwdriver, gently lift the catch holder assembly up to release the door catches.
When you replace the door catch, ensure that the door fits correctly.
Oct 28, 2010 | Panasonic Microwave Ovens
How do i open the door on hotpoint WD440, latch is broken?
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Onix front loader door wont open
I removed the top of the machine and pushed the catch back with a screwdriver. I found that the plastic catch was broken and that was why it wouln't open.
Sep 04, 2009 | Washing Machines
Can't open the kick plate of my samsung j845 washing machine
Happened to me too today. As I was pulling the handle, a piece inside snapped. The handle felt loose, as though it wasn't pulling the catch. To get the door open, I used a screwdriver. I pulled the handle as far out as I could, so that I could get the screwdriver in. The dark black metal part has to be levered away from the washing machine - in the direction the door would open. That will release the catch and then the door will open.
After the door is open, the challenge is to remove the handle. You'll need to undo all 10 (or so - from memory) of the little screws, so that the inner part of the door comes off. Be careful as you get to the last one - things will fall away. The handle and the small broken tab just fell out for me. Once the handle is out, you can put the door back together again. I use a small hex key to help open (and close) the door. With no handle, the catch springs a bit too far over for the door to close, so you'll need something (e.g. 1/8" hex key) to hold it over a little. So now, I can use the washing machine while I try to find a new part.
Apr 11, 2009 | Washing Machines
Hi We have a Zanussi Turbodry and when i tried to open the door it wouldn't move and i have now broken the handle off!!! How do we open the dooe?? Thanks Lynsey
Get a thin screwdriver and poke it in between the door frame and the front of the washer where the door latches in, push hard and see if it will release that way..
If no go, then remove top of washer , and with a long screwdriver or similar try to release the door catch from inside the front of washer, you may have to lever it open, and possibly break the door lock in the process.
There really is no other way of releasing door.
You obviously will have to replace the whole door handle assy, and the door lock.
Plz rate my solution.
Thanks.
Jan 18, 2009 | Washing Machines
Hotpoint Aquarius w.machine door catch broken.
easy way is to cut or break away the handle so the start of the door peg is exposed and use a screwdriver on the peg to lever it out
Aug 30, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
