Question about Sew Pro ZZ401 Sewing Machine
SEw Pro model ZZ-401. I can't get the bobbin thread to catch with the upper thread.
SOURCE: bobbin thread won't catch
I've just had this exact problem with my model 2037. The problem, according to 3 shops I've taken mine to, is that the shuttle hook (the metal piece that the bobbin sits in) is broken and needs replaced. Problem is, the piece is next to impossible to find.
Posted on Sep 06, 2008
talk2ginny
  • 34 Answers
SOURCE: I have rewound a bobbin
Welcome to FixYa. I always try the easiest fixes first - make sure your bobbin is inserted correctly, and that the bobbin thread is securely threaded in the bobbin case (sometimes the bobbin thread doesn't "catch" when you place it in the bobbin case). If all is well in the bobbin area, rethread your machine. Make sure that the presser foot is in the raised position when you thread. If it still isn't sewing correctly, change your needle. These last three steps fix most problems. But, if you are still having problems, look at the thread in the problem bobbin. It should be straight and tight. If it is kind of wobbly and a little loose, you'll need to wind the thread onto a new bobbin.
If are new to sewing, keep your manual close by and refer to it often. Simple mistakes can make a new sewer loose confidence, but it is all part of the process of learning your machine.
Good luck and happy sewing. If you have a sec, please rate my response so I know when I need to work on my responses.
Thanks for stopping in. Ginny
Posted on Jan 31, 2009
kent581
  • 87 Answers
SOURCE: Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Posted on Mar 18, 2009
Mongo32
  • 111 Answers
SOURCE: Bobbin wont feed
a. needle in backwards
or
b. needle threaded wrong
Posted on May 04, 2009
  • 1116 Answers
SOURCE: Purchased a HomeStyle sewing machine Model
Check the needle to see if the flat side is facing to the back of the machine. This is usually how the needle should be inserted.
Thread the machine with the presser foot up.
Hold onto the thread tail at the needle and hand walk the needle down and then back up to pull the bobbin thread up.
Take both threads under the presser foot and to the back of the machine before you begin to sew.
Posted on Feb 21, 2010
How do you thread the needle for the Sew Pro ZZ-401
have answerd this on another question befor you should look it up on here
Sep 05, 2012 | Sew Pro ZZ401 Sewing Machine
Euro-Pro # 361
try a new needle
try adjusting the top thread tension
make sure the bobbin is inserted correcty in the bobbin case
also possible that the machine could be out of time & would need to be serviced
Mar 16, 2012 | Euro-Pro Sewing Machines
I cannotl get my 270 D to even sew, it will not pick up the bobbin thread and do a thing. I have yet to sew the machine. donna
Picking up the bobbin thread has to be done by manually. Turn off the machine, open the bobbin door, lift the presser foot, hold the end of the upper thread and slowly turn the side wheel till the needle enters the bobbin race and on the way up it will catch the bobbin thread. Pull the upper thread till you lift the bobbin thread too. Put both threads to the back of the machine, close the bobbin door and you should be able to sew.
Apr 03, 2011 | Brother SE-270D Computerized Sewing...
My bobbin wont engage with the stich. it just keeps getting jammed up. i lost the manuel i have no idea what to set the tension.
Try these solutions
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 24, 2009 | Sewing Machines
I just purchased the sew pro portable zig zag sewing machine model zz 401 and it won?t work, the pedal makes this funny sound and the machine isn?t working. What do i do? I tried everything and tried...
Maybe the drive wheel is disengaged. Some machines have you pull out the wheel on the right to wind a bobbin and yours might be pulled out. Try pushing the wheel back in to engage the machine.
Nov 09, 2009 | Steam Fast ZZ-401 Mechanical Sewing...
Lower thread keeps jamming even though bobbin case is clean and tension on thread has been adjusted.
Here are some things to try.
* Re-thread your machine
sew.
Also, before you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
I hope one of these solutions help.
Sep 15, 2009 | Brother LS-2125 Mechanical Sewing Machine
I am having trouble with my bobbin . When I put into the sewing machine and begin to sew the cotton just bunches up and jams . Any suggestions
Here are a couple of things to try.
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
Hope this helps.
Sep 13, 2009 | Husqvarna Designer I
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
sew.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Sew Pro ZZ401 Sewing Machine Logo
168 people viewed this question
Top Sew Pro Sewing Machines Experts
Steve
ray gallant
Debbie
Are you a Sew Pro Sewing Machine Expert? Answer questions, earn points and help others
