Question about Dishwashers
Error code 16 on winterhalter gs302, any ideas please?
    New Friend:
Error 16 on (E) versions is low water flow, recommend checking the water inlet pipes and water supply is fully turned on, that the water solenoid valve is functioning ok and that it is not blocked with debris (they have a filter on the water hose connection side), and that the inlet water pipe is not blocked, squashed or kincked.
Posted on Feb 13, 2017
4 Suggested Answers
SOURCE: could you please tell me what error codes 21 and 6
error 6 relates to a blocked drain pump. if the drain pump is working ok check if the tank level sensor is operating or if the air chamber in the wash tank is blocked.
error 21 relates to the drain pump being activated. normally related to error 6.
also check water inlet solenoid valve is working correctly. ie not blocked or passing.
all parts of the machine can be activated manually by entering service mode.
when machine is off press service button or switch on main pcb.
p00 appears. press and hold main wash button. --- appears. using the long and short wash buttons you can scroll through parts of the machine. displayed as a01 a02 a03 etc.drain pump is a12 solenoid valve is a13. these are activated by pressing the button. when activating the drain pump the display will count down. this number is the water level in the wash tank. if it's counting down the level sensor is ok.
hope this helps
jarv
Posted on Sep 28, 2010
  • 3247 Answers
SOURCE: Hi my winterhalter gs302 was
The problem is likely related to overheating. The thermostat/ temperature sensor of the boiler could be faulty.
See top of page 18 of user manual.
The part could be order # 400666 on page 6 of this catalog. The actual boiler heating element is order # 416395 on page 10 of the catalog. Also check order # 416394 on page 11 which is the boiler element with safety device. Depends which one is used in your model.
Hope this helps fix the problem.
Posted on Dec 07, 2010
SOURCE: winterhalter gs502 dishwasher-error code 15?What's
The float switch/level sensor in the rinse boiler has not activated. This could be a faulty solenoid not letting the water in(assuming the isolating valve is turned on), or a faulty float switch/level sensor. This would result in water overflowing through the rinse arms and the overflow in the rear of the wash tank.
Posted on Mar 29, 2011
What does error code 35 mean on the winterhalter dishwasher
Error 15 = on the GS502/515 is a Main Water Stop Valve Blocked or Closed
Apr 28, 2015 | Dishwashers
Winterhalter error codes 23
Call customer support
Jul 07, 2014 | Dishwashers
Winterhalter gs502 and getting error 11
Klix-on on motor has failed. (This is often due to overheat) Clear dust and dirt from around motor to restore cooling may be the answer. .
www.cearcommercial.co.uk/.../winterhalter/winterhalter-wps-reminder-er...
May 21, 2014 | Dishwashers
Winterhalter gs 302 error Code 15
haw can i chainge a float switch on a winterhalter gs302 ?
please any one can hellp
Mar 17, 2013 | Dishwashers
Error code 23 on winterhalter gs 502
hi i a have a problem with dish washer it shows error 23 .and the ,model is GS 502,GS 515 .So how can i rectify the problem .thanks in advance.
Dec 28, 2012 | Dishwashers
Winterhalter gs502 dishwasher-error code 15?What's mean fault code 15?
Mar 18, 2011 | Dishwashers
DISHWASHER INSTRUCTION MANUALS
please contat winterhalter regional office or headquorter on
info@winterhalter.biz
Nov 14, 2007 | Washing Machines
Dishwashers Logo
1,514 people viewed this question
Top Dishwashers Experts
