Question about LG WD14121 Front Load Washer
LG WM12220fd Hi , I have a fault coming up on my LG machine display and i can't find my manual fault is UE ? Can you please help
    Novelist:
  • 116 Answers
I believe that UE is the fault of an unbalanced load which caused the drum to hit the switch or faulty load balance switch.
If the switch is stuck you can try to shake the inner drum kind of violently up and down (you won't be able to hurt it).
If the machine exibits the same error code with the drum empty then it is possible that the switch is damaged and will have to be replaced.
Posted on Aug 07, 2008
What does code Uo mean on the dishwaher
It is a Vent problem. The vent aids drying at the end of the cycle.
Frigidaire Diswasher ER UO Error code [FIXED] - Appliance Repair ...
forum.partsdr.com > Forum > Appliance Repair Help > Dishwasher Repair
May 25, 2012 - 20 posts - ‎3 authors
The ER UO error code means "Vent Open". On the top back right corner of the dishwasher tub, there is a vent and fan that opens to help dry the ...
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-ho... Feb 18, 2016 - The error code will display where the usual numbers are on the display screen. .... Do you have an error code on your Frigidaire dishwasher and need ..... Can you tell me what do you mean by "knockout plug has been removed"? ... Frigidaire dishwasher manual says UO error code is vent assembly error.
Diagnose UO Error Code - Dishwasher - YouTube
? 3:15
https://www.youtube.com/watch?v=pvJTiTd35vI
Dec 22, 2016 - Uploaded by Byrd Appliance Specialists
Byrd Appliance Specialists 3825 Gilbert Dr., Ste. 342 Shreveport, LA 71104 www.byrdas.com 318-459-8745 ...
My Samsung washing machine is showing a UE code during a spin ...
www.samsung.com/uk/support/skp/faq/1025292 Jul 5, 2016 - Your appliance will display a UE code when it has detected an unbalanced load and has stopped the ... If the door remains locked and the machine is displaying UE error, please run a drain program. ... What does this mean?
LG Help Library: Error Codes - Dishwasher ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library May 10, 2017 - An error code on the display of the dishwasher can usually be resolved by performing a few simple troubleshooting steps.
LG Help Library: UE Error Code - Top Load Washer ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library Sep 1, 2017 - After 3 attempts to balance, the uE will change to UE, meaning the unit was unable to rebalance the load and requires assistance. To determine ... What does code UE mean on the dishwasher Google Search
Oct 31, 2017 | Dishwashers
Why do all loads in our Top Load HE Washing Machine - Model # WT5070CW - stop because of UNBALANCED LOAD ERROR?
1st check ur floor level if the floor level is not flat means sure the error will come.. and dont put a blanket with other clothes
Feb 26, 2015 | LG WT5070CW White Top-Loading Washer
Machine displays UE when spinning and turns off the machine, this occurs even when the machine is empty
UE means uneven for LG washing machine. Could you please using water level to make sure it is level. May I know if the drum is stable while spinning by not giving any banging sound. Used to happen to my LG direct drive, and solved by replacing the suspension that supporting the drum holder. Now all good like new.
Dec 24, 2013 | LG Washing Machines
Front of wash displays UE code
Hi
Code UE is an unbalanced load error, usually shown when there is a very small load where the machine cannot redistribute the weight to balance it .Either the load is too small, the appliance is tilted, laundry is gathered to one side, or non-distributable things have been put into the machine.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | LG WM2301HW Front Load Washer
LG front loader washing machine UE error displayed
Imbalance error
Causes:
Load too small
Appliance is tilted
Laundry gathered to one side
Non-distributable thangs are put into washer.
Here is the WM2277 Service Tech Manual
You will find a list of fault codes on page 17 of it.
Note: This is is not a user manual it is the repair manual.
I have assembled some common problems and the solutions on the washer HERE
Nov 17, 2010 | LG WM-2277HW Front Load Washer
I have a LG TROMM WM2277HS front load washing machine. Error code UE displays when there is 3-5 minutes left in the cycle. I have tried rearranging the load, making it lighter or heavier. I have also ran...
Hi.. UE error means unbalance error..Check your floor level and machine legs... after u checking ur floor level and legs also perfect means change the suspension rod.
Sep 25, 2017 | LG WM2277H Front Load Washer
Error code UE
UE Refers that the Unit is Unbalanced. Take out the clothes out of the washer and then Run the washer. Does it Spin?
If yes, then it might be Unbalanced Load. Try to Load Small Clothes. If not, or if the Error is Appearing again and Again, Control Board or the Sensor is at Fault. You cannot Test the Control Board or the Sensor but usually Sensor is the Common Problem with Most of the LG Washers.
So, First Change the Sensor. If Problem Persists, Change the Control Board. On Most Models, Sensor would be Located near the Front of the Unit on the Side of the tub.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 26, 2009 | LG WM2496H Front Load
Ue code Help help
HI. this is a Imbalance error
Possible causes
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Jul 12, 2009 | LG WM1812C Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
Ue error code on the display
For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
Sep 23, 2007 | LG WM1814CW Front Load Washer
LG WD14121 Front Load Washer Logo
386 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
