Question about Raypak 2100 Pool Heater Gas 266000 BTU' (Pilot Light) ()
Ilo display when trying to turn on heater - Raypak 2100 Pool Heater Gas 266000 BTU' (Pilot Light) ()
    Champion:
  • 305 Answers
Ignition lockout. heater has tried to fire up 3 times without success. after three attempts unit will temporarily lock itself out
Posted on Mar 13, 2014
What does ILO mean?
Ignition lock out
This happens when a safety feature kicked in and the heater tried to start up again. Turn the power off at the breaker for 10 seconds and try again.
It should fire up or give an error code for possible issues
Aug 04, 2014 | Raypak Rheem RP2100 399K BTU Natural Gas...
Tip
Howdy, Doc; I was wondering if you've got any more help to give an iLO owner. A...
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
on Dec 01, 2008 | iLO (2 GB) MP3 Player
Heater shuts off and ILO shows on the screen
ILO stands for Ignition Lock Out.
This heater must be on a propane gas system as that is the only model that supports the ILO feature.
This either means that the gas supply is insufficient, or is turned off, OR...
the ignitor / flame rectifier have failed.
As long as you know that the pilot orifice is clean and free of debris, and the gas supply is turned on and correct, you simply need to purchase and install a new ignitor for this heater. I would normally list the part number and a place to buy it for you, but there was no model listed on this post.
On raypak heaters, the ignitor is actually the same part as the flame rectifier (flame sensor) .
What this means is that even if the ignitor portion is working, and your heater is igniting, the ILO code is telling us that the flame sensor is not sensing that it is lit. This is when it shuts down and gives the ILO code.
If you lost your manual and need a part number contact me @ : adamh@newconceptchem.com
I have most raypak ignitors in stock if you are interested.
Dec 07, 2010 | Raypak Pool & Spa
ILO shows in display. Heater will restart but shuts off again.
This error code is means your "low" on water pressure moving thru the heater. This function is one of the many safety switches that protect your heater from damage. Your filter more then likely is the cause. When was the last time you cleaned it? A dirty filter will slow the water circulation and trip the pressure gauge and shut the heater down.
Screen is frozen and displaying," this is an encrypted channel." I unplugged it for a few hours, turned off and on....what do I do next
hook up your sat/cable box and reset the tuner; place the set into "setup" then: "add channels" the tuner will look for and install active channels
Apr 25, 2009 | iLO 3200 32 in. LCD Television
My ilo player
you have to delete a song a song that you dont want
Oct 18, 2008 | iLO (2 GB) MP3 Player
ILO 32inch TV
ILO 32" lcd hdmi tech support Eastern Time
8:30 am - 9:00 pm (monday through friday)
9:00 am - 5:00 pm (saturday)
1-800-428-1105
my 8 month old tv doesnt even turn blue. just blinking red light where on/off light display appears. very discouraged cause wallmart will not help. trying techsupport. i found this number from my purchase paperwork. hope it is helpfull to you.
Dec 10, 2007 | iLO 3200 32 in. LCD Television
ILO MP3-New problem just ocurred..... Turning the unit on the display logo just blinks off and on.
The company no longer supports the player, so the firmware upgrade is no longer available
Jun 13, 2007 | iLO (2 GB) MP3 Player
Raypak 2100 Pool Heater  Gas 266000 BTU' (Pilot Light) () Logo
116 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
