Question about Whirlpool Duet Front Loading Dryer Rack W10121663
You have to unplug it and wait 3 or 4 hours and plug it back in and it will work.
Kolin inverter fault code E1
Congratulations, your air conditioner has hit 720 hours of use. In an attempt to push people to keep these things extra clean the built-in this annoying feature that spits out an alarm every 720 hours of operation.
Let's reset it and hope that she lasts long enough to give you this error many times to come. :-)
Two ways to get it done:
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
Feb 04, 2015 | Inverter Heating & Cooling
E1 flashing , a/c quit working
Good Morning, Lets see if we can get you back to being cool. Not all units this works on but most.
The e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
Let me know if this helps.
Aug 03, 2011 | Comfort-Aire Heating & Cooling
I have aquired a second hand Zanussi upright fridge freezer Z56/3 W, seen working. However after transporting ( back of my car on it's side ) and installing ( plugging into the mains ) it makes all the...
when you move a refrigerator laying down you are supposed to wait at least 3 hours before plugging the unit in to the wall in order for the oil inside the compressor to settle to the bottom of the compressor if you were to plug the unit in before this amount of time hopefully the oil did not stick inside the line or else you would have to call a compressor repair technician you can also try leaving the machine unplugged for 24 hours if you did plug it in before the 3 hour period which may allow the oil inside the compressor to settle back down to the bottom again if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
p.s if after waiting 24 hours it still did not get cold you would need to call a technician
Apr 19, 2011 | Zanussi Z56 / 3 Top Freezer Refrigerator
Cant turn it off, it seems to be locked?
hELLO THERE
On some of these ovens they have a internal reset device that needs to be reset and this is done by unplugging the oven and waiting for one hour then plugging it back in and waiting for 5 min befor you attempt to unlock it.
Now on some of the newer model ovens all you have to do is unplug wait 15 sec and plug it back in for 5 sec then repeat this step 3 times ok so please try these and let me know how this goes
Best regards Michael
Apr 26, 2010 | KitchenAid Architect Series KEBC107KSS...
The Open/close does not work. Power is on and it
First try resetting the player. Unplug for 1/2 hour-1hr., press and hold power button for 3 seconds, wait 1/2 hour, plug back in and it should work. Otherwise you can pry open the door with a paper clip. Slowly pull door as far back as it will go, then press eject button and see if everything aligns itself back on track.
Nov 23, 2009 | Panasonic DVD-RV31 DVD Player
Frequent signal drop offs-unplug router-wait-plug back in
hey
please follow this step
try to check that wether the router is away from radio ,from your computer,microwave oven.
because these device try to intreupt in the signals
or else try to increase increase the channel in your router page
Jul 06, 2009 | D-Link AirPlus DI-524 Wireless Router
New Refrigerator not working properly after being tilting while unloading
you NEVER plug a fridge in after its been tilted you have to wait 24 hours once theyve been tilted before you plug them in
Oct 23, 2008 | Refrigerators
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Whirlpool Duet Front Loading Dryer Rack W10121663 Logo
Dan Webster
Dan Webster
Sal DeAngelo
