Question about KitchenAid KSRA25CNBT / KSRA25CNBL / KSRA25CNWH Side by Side Refrigerator
My KSRA25C side by side refridgerator will not make ice. I went on vacation and left the fridge switched on. I turned of the water supply to the house because of the cold weather. when i returned the icemaker won't work I turned off the fridge and the water connection for 24 hrs to see if it was frozen I moved all the hoses around I exchanged the water dispenser and icemaker lines so I know it is not the water valve. still no ice no water is coming to the icemaker
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
xMadx
  • 64 Answers
SOURCE: LD refridgerator icemaker not making ice
I personally have never heard of your particular model ( LD ) - bearing in mind that most fridges with these types of added extras should be somewhat similar, on one i looked at - they have small electronic valve that should open and close on demand, but as with most valves and the quality of water available in some areas, they do sometimes fail to open on demand ( ie: when the tray tips over, the valve should open to fill the next tray ) - being blocked, or faulty would prevent any water from running in.
I myself have not worked on these types of appliances much recently, and technology changes all the time, so it could be worthwhile to have either:
  • A repair center come take a look at it for you.
  • Allow time for a second solution to be offered by other fix ya experts.
Now people with more relevant experience in these areas may also tell me i don't know what i'm talking about, and rightly so, but this is just one solution offered and i can't always be spot on, especially if the make & model is not specified.
In my opinion, usually a little expertise can go a long way and save some hard earned dollars also, so bearing in mind - sometimes we have little or no option but to place ourselves at the mercy of repair centers, who just so happen to deal with these kinds of problems on a daily basis.
Posted on Feb 05, 2008
Techsim
  • 59 Answers
SOURCE: Icemaker makes ice, but doesn't dump it.
If you have a steady blinking light when you open the door then the sensor is working. I these cases the problem is usually in a bad motor or thermostat in the icemaker. If you need I can give you instructions on how to change these parts.
Posted on Nov 03, 2008
  • 531 Answers
SOURCE: blinking red light on ice maker
check icemaker
Posted on Apr 07, 2009
  • 6 Answers
SOURCE: Ice maker stopped working-can still get water from door dispenser
there are two water valves to the unit replace it
Posted on May 04, 2009
Lg refrigerator can i turn water supply off but leave fridge freezer on when i go on holiday
How long of a vacation are you planning?
I would not mess with the fridge/freezer.
Leave the water supply on.
Jul 05, 2017 | LG Refrigerators
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
Water and ice have a funny taste
Try flushing out with bi carbonate of soda.
May 17, 2010 | KitchenAid KSRS25ILSS Side by Side...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag fridge no water to icemaker any suggestions
Pour about 2/3 cup of water into ice maker . If it freezes and dumps , replace the water valve . If it does not dump , replace the icemaker . Also make sure the coils are clean beneath refrig , and the clear fill tube , which fills the icemaker , is clear of ice (not frozen up ).
Sep 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker not working went on vacation and turned water off. seems the watr guide into the Ice maker is blocked. Was wondering why this happens, as action should be similar to stopping Ice making with...
When the water is shut off by the lever, it is shut off at bottom of fridge. When you shut it off, it is allthe way to the tray as it gave water permission to travel and what was left filled the line. Unplug fridge for an hour. Should be fine
Aug 09, 2009 | Whirlpool ED5FTGX Side by Side...
We have a KitchenAid Side by Side Refrigerator (KSRA25C). The ice maker will not work. We have replaced the "in the grill filter" water valve, but that didn't fix the problem. All other features of the...
Pour about 1/2 cup of water into the icemaker . If it dumps then water valve is the problem . If not , then icemaker is the problem . Make sure the laser switch on r/side of freezer is on . and the coils at the bottom of fridge are clean ( icemaker must be 5 degrees to operate ).
Jul 18, 2009 | Refrigerators
Frigidaire FRS26ZSH no water at dispenser or ice maker
  1. I would remove both solenoids (one at a time-not to mix them up) pay attention and mark all parts- try cleaning or replacing them. Most are fairly common supply items. Paying attention to wiring and proper installation is important during re assemble. JOHN-LA
Aug 31, 2008 | Frigidaire FRS3R5EMB Side by Side...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
KitchenAid KSRA25CNBT / KSRA25CNBL / KSRA25CNWH Side by Side Refrigerator Logo
73 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
