Scanner won't move and it makes a funny noise. Where would I find the traction belt to see if it's slipped?
  • 113 Answers
UNLOCK THE CIS UNIT FIRST
Posted on Apr 11, 2011
Loud grinding noise when back wheels slip
your on ice, when it slips to much the lamps come on
when not read the operators guide, it explains all this is detail.
RTM , yes, read the manual. do so. now.
on my car, i can turn off the traction controls, and direction controls
that to is in that same funny manual nobody reads.
that funny noise is the skid controls ABS and all, modulating the
brakes to stop the skid
guess what on 31.5deg F ice it cant , there is no way for
MAGIC electroinics to stop a skip on slippery ice, not now or ever.
tell me how it,can?????? throw down sand?
ok so the lamp means, DANGER i can NOT save you from yourself
that is what it means, in pure true words,,
the oper guide will dance around that but tell it.
on my car it can be a pain with the lamps all going nuts
so i disable it. RTM.
you can not disable ABS. just the other magic.
Jan 21, 2014 | Toyota Sequoia Cars & Trucks
Doesn't want to go onto spin cycle just makes funny noises
Possible that there is slippage when the program comes to the spin mode. Please check the drive and see if the belt is slipping or the drive is jammed. If not check the motor drive.
Jan 21, 2013 | Beko Washing Machines
Olympia Startype electric typewriter , make a funny noise and won't move carriage. Can not get it to work.
Turn it off and see if the carrier will move back and forth by hand if it will but feels a little gummy spray a little WD40 on the silver shafts that it slides on. If it won't move by hand look for debris in the carrier area.
DickyO
Sep 19, 2011 | Olympia Office Equipment & Supplies
When plugged in via usb, the LIDE 600F scanner makes a high pitched buzzing noise and will not start up.
Hi
The scanner is not able to find the home position to start.
Hence open the scanner and check to make sure the scanner assy. is moving to the end and when it senses the home position it will try to move a little away from it and then return back. But if the sensor is dirty or broken it will make a loud noise like belt slipping.
Try to find the sensor on back of the Tube assy. and try to fix it.
Jul 23, 2011 | Canon CanoScan LiDE 600F Flatbed Scanner
Scanner won't scan. the light is on but the scanner part won't move. makes a lot of noise. the belt is not brokern
depending on the scanner the belt may not be broken, however the gear that it rides on may not be moving, or the belt is slipping. Some scanners the glass can be removed for you to visially see the gear and evaluate from there
Jul 15, 2011 | Office Equipment & Supplies
Have a Lexmark X5650 printer/scanner that won't scan at present. Trying to scan my work (comic book artist) to a memory chip then into photoshop on the laptop for tweaks before turning them in and the...
ok. if its making a grinding noise its the belt slipping. you may not have the print cartridges installed properly. kit could also be the scanner belt that may be slipping. Basically if its not the print cartridges then the scanner is stuffed. Unless you are handy and are prepared to pull thing apart to get to the scanner belt I'd say it has gone to god.
Jan 17, 2011 | Lexmark Office Equipment & Supplies
Dryer doesn;t spin
Sounds like the belt has broken. The terrible noise was probably the belt slipping until it gained traction.
May 17, 2009 | Dryers
Traction control problem!
bad wheel bearing.will make noise and mess with sensors,or if had a brake job done caliper maybe loose to cause noise,if a drum which most are not you have parts rolling around in it,have seen it all.
traction control and abs use same sensor,you could have debris in caliper a little pebble between brake shoes and rotor will cause issues.
Feb 07, 2009 | 1999 BMW 323 Series
Scanner Bar won't move
Try first unplugging the power cables for ten minutes, also restart the computer.
Check if this model has a lock button to secure the scan, this is usually indicated with a lockpad, and is a small tab, if there is one is indicated on the manual.
Plug it back and do the following:
This sounds like an hardware fault, since the scanner starts, but just in case , ensure the drivers are working fine by reinstalling software from scanner disk. And eventually test the scanner on a different computer, for example a laptop. Use the scanner CD to do intall scanner drivers before connecting the scanner.
If it still does not work.
Check if the scanner lamp goes on when you send a scan, if not the lamp must be replaced.
The most likely is that the traction belt had slipped out, one of the mechanichs are stuck, or the motor is faulty.
In this case the scanner must be taken apart, the job can be done at any local repair shop.
Dec 14, 2008 | Sharp AL 1631 Copier
11 people viewed this question
k24674
jasbo
jasbo
