Question about Remington Precision HC-8017 Hair Trimmer
Need to find guide combs for HC-8017B - clippers that are square on the back side - cannot use the combs that have a rounded edge. Lost the guides during a move. Clippers called Precision.
SOURCE: my electric dog clippers don't cut well
if the problem arrears to be with one blade on several clippers it sounds like you need to send the clipper blades for sharpening.
Posted on Sep 27, 2009
philschneide
  • 448 Answers
SOURCE: Bought Oster Golden A5 clippers new but did not
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Posted on Oct 03, 2009
SOURCE: Remington HC-921 Mens Clipper Kit Pulling hair not cutting
no but I can't wait until someone does- having same problem. They worked fine then didn't
Posted on Apr 26, 2010
EwingElect
  • 276 Answers
SOURCE: remington precision clippers i need guards...
Locate the Remington Appliance website for your country at http://www.remington-products.com/country/
For Europe, try http://www.remington-europe.com/gateway/gateway_com.php?
For Latin America try http://www.productosremington.com/
Posted on May 19, 2010
  • 10 Answers
SOURCE: wahl hair clippers
lol This is unfortunate! I set these day in, day out, you have the right idea. Use the lever to push the cutter all the way forward, then push the comb down using your work surface, then use you free hand to tighten the screws. If your clipper is in factory condition this will have aligned them perfect. Give up? May or may not be wiorth it for you but try www.sheareaseltd.com Get postage details there, send your clipper to them (I work for them), pay the postage for them to get there, put a note in your box to Ash, asking me to align your blades, and I'll sort it for you but I'd have to charge return postage at £5!
Hope this helps!
Posted on Aug 03, 2010
How do I change the blade?
There is a small button at the bottom edge of the blade, push it in and at the same time push the blade teeth away from the clipper. The blade will hinge away from the clipper, you then lift the blade up off the tongue. When fitting another blade pop it onto the tongue, turn the clipper on and snap the blade shut.
Mar 31, 2015 | Oster Turbo A5 2-speed Dog Pet Clipper...
I have a Remington Model HC-912A hair clippers and need to find a 1.8 inch attachment. Where do I find one?
The Remington Model HC-912A has adjustable blade with a lever on the side, you can use the Wahl attachment comb. You can this this at
Manny's Sharpening
Jun 11, 2012 | Remington Precision HC-8017 Hair Trimmer
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
I need a clipper guide comb for an Oster model 606B hair trimmer. Where can I buy one?
Buy one on e-bay. I have the same clipper and needed the guide combs, so I went out on a limb and bought the Oster combs that fit the 76 models. It says "universal" on them, and they fit my old 606B perfectly!
Apr 15, 2010 | Oster Health & Beauty
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
Mar 21, 2010 | Oster 76974-160 Hair Trimmer
How to use clipper attachments...
Used against the scalp, around the ear, on the left and right side... working against the growth direction from behind the ear to the front of the ear.... The angle of the back of the taper guide comb makes it easy to create a smooth, progressive, natural taper along the edge of a men's clipper cut. Do this after you have used a regular guide comb to take down the general perimeter length and you will have a nice tapered edge to the clipper cut around the ears.
May 28, 2008 | Health & Beauty
Remington Precision HC-8017 Hair Trimmer Logo
120 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
