Setting up external monitor when enternal monior is not working?
    Sergeant:
    Champion:
  • 207 Answers
Do u have a dual video card.
Posted on Apr 09, 2011
Monior displays vertical instead of horizontal
Nothing wrong with your mon. It is your windows display setting.
Go to display properties and change it back to normal.
Nov 13, 2011 | LG Flatron L1751S-SN 17" Flat Panel LCD...
Monior comes on and says "No Signal". Can't
MAKE SURE THE POWER IS OFF AND CHECK ALL YOUR CONNECTIONS IF YOU CAN LOOK INSIDE THE UNIT TO SEE IF THE VIDEO CARD IS ALL THE WAY IN.I WOULD TRY ANOTHER MONITOR FIRST.THAT'S WHY I'M GLAD TO HAVE MORE THAN ONE PC IN THE HOUSE LOL
Oct 10, 2011 | E-Machines eMachines Desktop PC
Monitor will not recognize laptop.
Did you use the Fn key and either F5, 6, or 7 (depend on brand and model of the laptop) to select which displays (internal, both, external only) for the laptop to use?
You should also try this monitor with other PC to make sure it is not the monitor problem.
Apr 08, 2010 | Computers & Internet
Lg crt monior display cable wire circuit diagram
Pin Signal 1 Red Video 2 Green Video 3 Blue Video 4 Monitor ID - Bit 2 5 Ground 6 Red Ground 7 Green Ground 8 Blue Ground 9 [KEY] 10 Sync Ground 11 Monitor ID - Bit 1 12 Monitor ID - Bit 0 13 Horizontal Sync 14 Vertical Sync 15 N/C (Reserved)
Feb 11, 2010 | Computers & Internet
I cant transfer my laptop screen to my pc monitor.. how i can transfer it???
Press Fn key + F5 once or twice. Usually Fn+F5 will toggle you between 3 options: internal LCD - Both internal & external - Enternal only. Wait a moment after changing the mode, as the monitor has to detect the signal and react to it.
Once you are on external only, you can change the screen resolution to better suit the external monitor's capabilities.
With the laptop and monitor active at the same time, both will operate at the same resolution.
Nov 20, 2009 | Acer Aspire 4530-5889 Notebook PC
I have a rainbow of vertical lines on my gateway m675 and tried all the suggestions and nothing is work. It does show up on an external monitor.
The lines do show up on the enternal monitor? or do you mean that your video shows up fine on the external monitor? If your video DOESNT show up then your motherboard is toast, or at least the video card part of it, if your video card is embedded into your mobo(90% of them are) then you will need to replace the entire motherboard. There is no shortcut around it that is going to magically make it work, just go on ebay and look for a new one.
If it is not showing up on the external monitor then you probably need a new LCD screen. Again, go on ebay and find someone who is selling a new one. And again, there is no magical solution that will make it suddenly start working.
There is a small chance that it is just a loose video cable, but if that were the case then it would only happen periodically.
Jul 17, 2009 | Compaq Presario M2000 Notebook
When I turn on my laptop on ...The screen stays black.But it is on.
try using an external monitor, some machine have an button which allows you to swicth between different monior usely  f4 and fn
Nov 28, 2008 | Computers & Internet
Monitor Problem
This is probably the result of using the wrong display driver. It may even be set for an external monitor. If it was used with an enternal monitor, connect it up to the same one (or something similar) and use the display settings to get the computer to use the LCD as the primary.
Jul 09, 2008 | Acer Aspire 5002WLMi Notebook
Monitor problem
It is the problem of command section.Check menu button for shorting.if it is ok then check command ic or component related ith it.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Aug 20, 2007 | Acer AC713 17" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
