Question about Maytag Washing Machines
My parents bought a maytag washer a couple of months ago they are in tere 70 and 80's and they have had nothing but problems first the water would not come in right she keeps having to adjust it from warm to cold, Now it will not spin the clothes dry it is very frustrating for her. I called Lowes where they got the machine and they said call the manufacture. They live out in the country and it is driving them nuts they thought Maytag was the best.
  • 30 Answers
Base on the information you provided--I'am confident that your washer is in need of some adjustments. If you are still under the warranty period, I recommend you contact the manufacturer of your washer and request that they send a warranty service provider to fix your washer for you.
When you call the manufacturer have your washer model number, serial number, and the warranty information handy.
Posted on Aug 06, 2008
Maytag NFW7200TW leaking
The door seal is leaking and it is either installed incorrectly or just needs to be replaced. If the machine is under warranty, call the service people now. Hope this helps
Mar 28, 2010 | Maytag NFW7200TW Front Load Washer
Error "LE" on the display after initial water load
just perform the tub cleaning operation as advised. nothing else. getting soiled
Mar 18, 2010 | Washing Machines
The water is coming in very slowly. This started
There are screens inside the water inlet valves. Remove the water hoses and you will see them.
Jan 17, 2010 | GE Washing Machines
Mildew smell
PLEASE KKEP IN MIND THAT THE MAYTAG NEPRUNE FRONT LOAD WASHER IS WHAT GOT MAYTAG IN TROUBLE!!!!!!
Whirlpool bought MAYTAG about 3 year ago.
THe mold is because of the rubber boot in the front of the door. PLEASE check to see if the rubber seal has a small hole in the lower bottom of the seal to let small portions of water drain out. If you DO NOT have this small hole, you need to replace the rubber boot with one that has a hole.
NOW, WORD TO THE WISE and this is what I tell ALL FOLKS that have a FRONTLOAD WASHING MACHINE:
AFTER you washer in the washer LEAVE THE DOOR OPEN so that the washer can ventilate and remove any moisture that is within.
ALSO, every 2 months, get a WHITE CLOTH with WARM WATER and a littl;e bit of BLEACH and CLEAN THE RUBBER BOOT!!!!!!
Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water/ ice issue
this problem is either low water pressure or a faulty water inlet valve. if u have good pressure, change the valve. repairclinic.com
Jul 25, 2009 | Maytag 25.6 cu. ft. Side-By-Side...
Washer discharges Water during Agitation
you might consider raising the washer about 6 inches to make this work. it's vital to the operation of the machine..
Mar 09, 2008 | Maytag MTW5600TQ Top Load Washer
Just hooked up and it won't keep water
The drain pipe is one of the following
a) shoved wayyyyy to far the drain pipe
b) lower than the water in the tub
c) clamped tight to a drain line
Jan 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
ICE/WATER DESPENSER PROBLEM
The control board on the back of the fridge needs to be replaced. Call the customer service # in your manual. They have been making concessions for this problem.
Nov 17, 2007 | Maytag MFI2568AE Side by Side French Door...
Maytag Atlantis MAV6451AWW
turn off the water and remove the hoses from both the wall and from the back of the machine. check the screens inside of the machines water valve, they are probably clogged. do the same for the hose screens on the other end. replace the hose screens at the wall end and remove the screens from inside the machine. replace hoses and turn the water on and you should be good to go
Sep 19, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
