Question about Air Tools & Compressors
I would like to no who the hell got a crush on me rithg now.right back
  • 43,501 Answers
Here is a tip that will help you to get better results from your question onFixya.
How to ask a question on FixYa
heatman101
Posted on Apr 09, 2011
My iphone won't sync to Facebook, to Candy Crush. i get a message, "Sorry you cannot access the kingdom right now. I cannot sync, so the level is advanced on iphone compared to FB.
With any iOS device, the first troubleshooting step is always to completely power down the device. Shut it off and restart it. That often fixes a lot.
If that doesn't do it for you, go to the Settings and find the Facebook setting. Turn off permission for the Facebook app to access the Candy Crush account. Delete the Facebook app.
The next part may seem a bit scary, but don't worry; your Candy Crush data is safe. Delete the Candy Crush app,. the restart the iPhone again.
Redownload Facebook and sign into it. Then redownload Candy Crush. Open Facebook app and search for Candy Crush. When asked, allow Candy Crush to access your profile info. Give it about 20 minutes to filter down, it should right itself after that.
May 23, 2014 | Apple iPhone Smartphone
Maytag MSD2651KES delivers crushed ice but no cubed
There is an metal arm that extends out behind the ice bucket that moves up and down when you press the cubed/crushed ice buttons. You need to take the ice bucket out and check the hardware. It's possible that some ice has managed to form in the unit and are blocking the motion. Remove any ice and check if the arm moves freely when you press the buttons on the refrigerator. Similarly, you should check if there is ice blocking the forward and back motion of the plunger in the freezer that bar sits on. This plunger is right next to the auger motor.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MSD2651KES/3048/0165000/W0703730/00013 has a picture of the ice bucket parts.
Dec 06, 2013 | Freezers
How to do level 76 candy crush
Search for a solution on Youtube. All levels of candy crush take some luck, and lots of tries to finish.
Sep 05, 2013 | Kitchen Appliances - Others
1998 taurus, tps went out, i replaced it runs rithg, now the service engine light os on code says tps. how do get the light out
If your TPS has slotted mounting holes then it is adjustable. It may be out of adjustment.
What needs to be done is the signal wire needs to be back probed to a reading of about .5 volts. But if you don't have a digital multi meter you may just try adjusting one way or the other and driving for a bit so the PCM can run through its test and see if the light goes out.
Sep 01, 2011 | 1998 Ford Taurus
Only puts out crushed ice
Pull out the ice bin and set aside. On the back wall of the freezer where the auger drive coupling is, to the right and down below the locator pin, is a square opening....make sure that the actuator is in the down position. if stuck in up position, it will always crush the ice. We have had the same problem with our frigidaire. The actuator is connected to the "crushed ice" solenoid.
Aug 18, 2009 | Frigidaire Professional Series PHS68EJSB...
Can't make ice cubes only crushed ice
Hi: There is a flap right where the ice dispenses. When you remove the bin you will see it when inverted. This flap has to open for the ice to be cubed. You might rember a slap as it swung open when it worked. There is a bar that runs from the flap to the back of the dispenser. Work it manually to see if it's jammed or broken. If not look at the back of the freezer and remove the metal panel if neccessary, to find the jam or defective part. I hope this helps, Jeff
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker will only make crushed ice
There is a rod on the back of the ice cube bin. It goes below a plastic slide in the back of the fridge. If yoiu pull the bin out and it does not engage right, you will be 'stuck' on crush. Pull the bin part way out and see whether the rod is going below or above the horizonal rung in the rear. If it is above, rotate the metal control until it will slip under the rung.
Apr 17, 2009 | Frigidaire Refrigerators
My ice-maker keeps switching to crush on it's own.
There is a long rod on the right side of the ice dispensing bucket.
This rod goes through a hole in the back wall of the freezer where a solenoid should pull up on the rod allowing the ice cubes to dispense without being crushed.
If this solenoid goes bad or ice forms around the plunger, it cannot pull up on the rod.
Check out that solenoid and the rod assembly.
https://www.repairclinic.com/Frigidaire-Refrigerator-Parts
appliance parts, help & more
Apr 13, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice crusher has stopped crushing
There is a little bar that is on the ice bucket. That bar has to go into the middle of the plastic square that is on the back wall of the freezer. Try Pulling out the ice bucket, get a hair dryer and run the hair dryer on the back wall of the freezer right above the hole where that little bar goes. After you run the hair dryer for about 10 minutes or so put your finger in the hole and pull down on the plastic square. Make sure when you put the ice bucket back in the freezer, the bar goes inside the square hole, not under it, not over it. In it. If that doesn't fix the problem you probably just need a new solenoid. Part number 5304404333
Let me know how you make out. Good Luck
Bill
Jan 13, 2008 | Frigidaire FRS-26DR7D Side by Side...
Air Tools & Compressors Logo
218 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
