Question about Kenmore Washing Machines
I have a kenmore elite mod #220056102 it is digital! it will not show any sign of life. im an electrician so it has to be some type of reset or something? there is power to the plug but no lights will cone on! please help.
  • bpetersavage Apr 09, 2011
    i have a kenmore elite mod # 220056102 i get no digital display just after a wash! there is power to the machine! is there a fuse or some type of reset to get it back on? thanks
    thank you, i am an electrician so i have testers how can i get a diagram on disasemmbling the washer and where the board is? thanks
  • 6,993 Answers
There is no reset of any kind as this is not a reset issue. The machine is having a power problem. As long as the machine is refusing to power up, then it is certainly a power fault or issue.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Apr 09, 2011
  • Walesarumi
    Walesarumi Apr 09, 2011
    To be frank, I don't have a diagram for this unit. But you can get to the power panel/board from the power outlet wire.
    Trace the power cord straight into the unit. The board where the power cord is soldered inside the machine is the power panel/board. Or the board close the wire is soldered.
    You will identify it by the fuse, capacitors, transformer, etc, that is on the board.
    Good luck,.
  • Kenmore Master
  • 1,902 Answers
Hello & Welcome to FixYa
The control board is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
How to remove Control Locked
www.appliancerepair.net/kenmore-washing-machine-repair.html
Jul 27, 2014 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 dryer- can I change the plug from the present 4 pronged utility plug to a standard 3 prong plug and still work safely?
NO, You will need to get an electrician to install a NEMA 14-30R outlet for your dryer, the electrician will know what you need, in anycase a 240V 30amp outlet is needed if you dont already have one. DONT replace the plug.
Jun 20, 2010 | Kenmore Elite HE4 Electric Dryer
I need owners manual to a kenmore dryer mod 110.60902990
Go to managemyhome.com and type in the model number you provided under the "Manuals" link. Your owner's manual is available in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Oct 27, 2009 | Kenmore Elite HE4 Electric Dryer
Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Mod #76523
The problem is the fan unit that pushes cold air up to the fridg, usually located nere the back of the freezer.
Aug 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Washing Machines Logo
16 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
